[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(caf5eaea7227b6931b8c40827edb4b6c.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/caf5eaea7227b6931b8c40827edb4b6c.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/caf5eaea7227b6931b8c40827edb4b6c.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/caf5eaea7227b6931b8c40827edb4b6c.png): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(f901621ba24ef9560fcf3ebae754a30e.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/f901621ba24ef9560fcf3ebae754a30e.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/f901621ba24ef9560fcf3ebae754a30e.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/f901621ba24ef9560fcf3ebae754a30e.png): No such file or directory
[phpBB Debug] PHP Warning: in file /generate_feed.php on line 295: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3768)
Latest posts from topic “Rete con BS” Latest posts from topic “Rete con BS” on “ElectroYou”. 2018-01-23T13:32:26Z https://www.electroyou.it/forum/viewtopic.php?f=1&t=72417 Re: Rete con BS https://www.electroyou.it/forum/viewtopic.php?f=1&t=72417#p752006 MarkyMark 2018-01-24T07:30:31Z 2018-01-24T07:30:31Z
Sì, intendevo resistenza nel senso di resistore :mrgreen:
Solitamente le chiamo, sbagliando, resistenze. Devo perdere questa abitudine. Grazie.
Già che ci sono aggiungo una cosa a cui non avevo pensato
Le due tensioni del teorema di Miller devono essere riferite allo stesso nodo.
Re: Rete con BS https://www.electroyou.it/forum/viewtopic.php?f=1&t=72417#p752000 claudiocedrone 2018-01-24T01:24:31Z 2018-01-24T01:24:31Z
[quote="MarkyMark"] ...R3'' non è una vera resistenza, non può esistere da sola...
:-) Da ignorante quale sono mi permetto di obiettare in parte su tale affermazione; a mio parere una resistenza negativa è una resistenza "a tutti gli effetti" benché atipica; non confonderei la resistenza che è un fenomeno fisico, con il resistore che è un componente passivo che allora sì che non può esistere come "resistore a resistenza negativa"... quindi "non può esistere da sola" lo ritengo corretto in quanto serve un circuito attivo che la generi mentre "non è una vera resistenza" non lo ritengo corretto. O_/
Re: Rete con BS https://www.electroyou.it/forum/viewtopic.php?f=1&t=72417#p751990 IlGuru 2018-01-24T00:11:12Z 2018-01-24T00:11:12Z
Applausi! E' una goduria seguire discussioni di questo livello. >-O-<
Re: Rete con BS https://www.electroyou.it/forum/viewtopic.php?f=1&t=72417#p751980 pwm 2018-01-23T23:37:55Z 2018-01-23T23:37:55Z
Perfetto
Re: Rete con BS https://www.electroyou.it/forum/viewtopic.php?f=1&t=72417#p751961 MarkyMark 2018-01-23T21:22:08Z 2018-01-23T21:22:08Z
Mi sono dimenticato di indicarlo nello schema #-o
Ho calcolato la resistenza di ingresso a valle della Rs; Rs non compare da nessuna parte nei conti.
Normalmente Rs rappresenta la resistenza di uscita della sorgente e non fa parte dell'amplificatore. Non entra nei conti della resistenza di ingresso ma va considerata per il calcolo del guadagno.
Re: Rete con BS https://www.electroyou.it/forum/viewtopic.php?f=1&t=72417#p751958 pwm 2018-01-23T20:46:51Z 2018-01-23T20:46:51Z
Grazie anche per questa dimostrazione, molto pratica!
Ho notato una cosa. Nel tuo metodo includi la resistenza Rs e viene una certa Rin. Ma se nel metodo di IsidoroKZ, lui non avesse inserito il generatore equivalente all'inizio, la Rin come sarebbe venuta ?
Re: Rete con BS https://www.electroyou.it/forum/viewtopic.php?f=1&t=72417#p751954 MarkyMark 2018-01-23T20:17:52Z 2018-01-23T20:17:52Z
Il metodo del transistor equivalente secondo me è il più veloce in questo caso. Possiamo definire un "nuovo" transistor nel seguente modo
Si devono calcolare i parametri del transistor equivalente
Dallo schema si vede che r_{\pi eq} = R_3 // r_{\pi} e [unparseable or potentially dangerous latex formula]
[unparseable or potentially dangerous latex formula] quindi \beta_{eq} = \beta \frac{R_3}{R_3 + r_{\pi}}
Ora si può sfruttare la nota relazione che fornisce l'impedenza che si vede dalla base del BJT
Come check puoi fare il limite per R_3 \rightarrow \infty (circuito aperto) e troverai il valore che si ha per il classico circuito senza bootstrap.
Come valore numerico dovrebbe venire molto simile a quello ottenuto da Foto UtenteIsidoroKZ in [13] dato che l'approssimazione di Miller è molto buona.
[quote="PWM"]- ma R3", essendo negativa, presa da sola non ha alcun senso ?
[quote="PWM"] E' raro poterlo usare.
Teoricamente lo puoi usare sempre se hai una situazione di questo tipo
Nella pratica non sempre è possibile usarlo in forma approssimata e quasi mai è conveniente usarlo in forma esatta.
P.S.
Ho provato anche con il EET applicato a R_3 ma non è velocissimo dato che le due impedenze aggiuntive non si possono calcolare a occhio (almeno io non sono riuscito) :(
Se vuoi provare guarda l'articolo che ti avevo indicato prima :-)
Re: Rete con BS https://www.electroyou.it/forum/viewtopic.php?f=1&t=72417#p751891 pwm 2018-01-23T15:47:55Z 2018-01-23T15:47:55Z
Chiarissimo!
Altre domande:
- ma il BS si può usare solo in questo stadio CE ?
- perché qui si può applicare Miller ? E' raro poterlo usare.
Re: Rete con BS https://www.electroyou.it/forum/viewtopic.php?f=1&t=72417#p751874 IsidoroKZ 2018-01-23T14:29:59Z 2018-01-23T14:29:59Z
Grazie. Consideriamo il funzionamento in banda passante, quindi il condensatore CBS e` per il segnale un cortocircuito. Le resistenze R1, R2 ed RE sono in parallelo e la resistenza R3 e` in parallelo alla resistenza r_\pi del transistore. Si potrebbe usare il transistore equivalente, come ha detto Foto UtenteMarkyMark, ma risolviamolo con Miller applicato alla resistenza R3.
La resistenza R3, collegata tra due punti con guadagno in tensione, la si puo` millerare scomponendola il R3' e R3". Inoltre per calcolare il guadagno di tensione fra i due estremi della resistenza (base ed emettitore) conviene mettere un generatore di tensione sull'ingresso, che cosi` toglie la tentazione di considerare nei calcoli preliminare Rs.
Il valore del guadagno K=\frac{V_e}{V_x} sappiamo che e` positivo e poco minore di 1. Il suo valore dipende anche da R3", che non conosciamo, e che a sua volta e` funzione di K. Pero` c'e` una scappatoia. Il valore di R3" e` dato da [unparseable or potentially dangerous latex formula], se K e` poco minore di 1, il valore di R3" diventa molto maggiore di R3, in modulo, e anche maggiore del parallelo delle resistenze di emettitore e della resistenza vista guardando dentro l'emettitore.
Morale. R3" puo` essere trascurata. Da notare che R3" e` una resistenza negativa: messa in parallelo alle resistenze di emettitore ne AUMENTA il valore, quindi se si calcolasse K con R3" si troverebbe un valore maggiore del K che si calcola trascurandola. Questo ha perfettamente senso, perche' trascurando R3" in pratica si trascura il percorso del segnale "in avanti" attraverso R3, come tracciato in rosso in questa figura
Trascurare R3" vuol dire trascurare il fatto che il segnale di ingresso prende una scorciatoia attraverso R3 e arriva sull'uscita in fase a dare una mano a quanto sta facendo il transistore.
A questo punto il circuito e` il seguente, e bisogna calcolare Ve/Vx
Per la resistenza R3 e per Miller, questo e` uno stadio a collettore comune, con guadagno
[unparseable or potentially dangerous latex formula].
Non ha importanza che tutto lo stadio abbia ingresso su base e uscita su collettore, quindi sia un common emitter, la resistenza R3 e` collegata fra base ed emettitore e vede solo quello, non sa nulla di che cosa c'e` sul collettore.
A questo punto si puo` calcolare [unparseable or potentially dangerous latex formula] che viene molto maggiore di R3 originale, e l'impedenza di ingresso, vista ai capi del generatore Vx di prova diventa
Se poi vuoi anche calcolare il guadagno del circuito Vu/Vin, devi usare il circuito di partenza, con anche Rs, qui sotto.
Qui puoi fare in due modi, il primo piu` normale e lungo, il secondo piu` rapido.
Primo modo: calcoli Vx, tensione sulla base, in funzione di Vin, e` un semplice partitore resistivo
V_x=V_{in}\frac{R_{in}}{R_s+R_{in}}
Una volta che hai Vx, quello che segue e` un normale common emitter con resistenza sull'emettitore e ricavi Vu, che dovrebbe venire qualcosa del genere
L'altro modo, che consente di usare dei valori gia` calcolati e` quello di trovare Vx come prima, poi si trova Ve moltiplicando per K calcolato prima. Una volta che hai Ve dividi per il parallelo delle tre resistenze di emettitore, hai la corrente di emettitore, moltiplici per alpha del transistore hai la corrente di colletore, moltiplichi ancora per -Rc e hai la tensione di uscita. Piu` rapido a farsi che a scriversi
Adesso vediamo se Foto UtenteMarkyMark ha voglia di spiegare il metodo con il transistore equivalente.
Re: Rete con BS https://www.electroyou.it/forum/viewtopic.php?f=1&t=72417#p751862 pwm 2018-01-23T13:32:26Z 2018-01-23T13:32:26Z
Ecco qua
