[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(2b6112fc48c754aa431fb37fb729a07b.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/2b6112fc48c754aa431fb37fb729a07b.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/2b6112fc48c754aa431fb37fb729a07b.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/2b6112fc48c754aa431fb37fb729a07b.png): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(a7ed7f88b3580e7366920436b47f3efe.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/a7ed7f88b3580e7366920436b47f3efe.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/a7ed7f88b3580e7366920436b47f3efe.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/a7ed7f88b3580e7366920436b47f3efe.png): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(ecb734f5c828fea2a1f50d750ce608c6.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/ecb734f5c828fea2a1f50d750ce608c6.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/ecb734f5c828fea2a1f50d750ce608c6.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/ecb734f5c828fea2a1f50d750ce608c6.png): No such file or directory
[phpBB Debug] PHP Warning: in file /generate_feed.php on line 295: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3768)
Latest posts from topic “Teorema di Shannon” Latest posts from topic “Teorema di Shannon” on “ElectroYou”. 2020-01-30T10:45:17Z https://www.electroyou.it/forum/viewtopic.php?f=1&t=79862 Re: Teorema di Shannon https://www.electroyou.it/forum/viewtopic.php?f=1&t=79862#p836290 nembro 2020-01-30T19:40:46Z 2020-01-30T19:40:46Z
Penso sia stato utilizzato solo come esempio, soddisfa infatti l'ipotesi di banda limitata ed è abbastanza comodo lavorarci.
Re: Teorema di Shannon https://www.electroyou.it/forum/viewtopic.php?f=1&t=79862#p836289 jayeffe 2020-01-30T19:38:25Z 2020-01-30T19:38:25Z
su questo mi trovo, io cercavo di capire come mai quando si parla di teorema del campionamento viene rappresentato il segnale triangolare? ci sarà qualche considerazione da fare che non ho colto, probabilmente .
Re: Teorema di Shannon https://www.electroyou.it/forum/viewtopic.php?f=1&t=79862#p836287 nembro 2020-01-30T19:35:54Z 2020-01-30T19:35:54Z
Con riferimento all'immagine riportata nel primo post, la formula (a cui ho aggiunto il pedice menzionato nel mio post precedente)
[unparseable or potentially dangerous latex formula]
descrive lo spettro del segnale campionato, che è costituito da una replica periodica dello spettro [unparseable or potentially dangerous latex formula] del segnale nei tempi a valle dell'operazione di campionamento.
Il segnale nei tempi a valle del campionamento dovrebbe essere un sinc^2.
Re: Teorema di Shannon https://www.electroyou.it/forum/viewtopic.php?f=1&t=79862#p836285 jayeffe 2020-01-30T19:15:18Z 2020-01-30T19:15:18Z
Manca gli indici della sommatoria che ho scritto vanno da -oo a oo . Il segnale che intendevo è proprio quello che hai citato.
Re: Teorema di Shannon https://www.electroyou.it/forum/viewtopic.php?f=1&t=79862#p836283 nembro 2020-01-30T19:09:05Z 2020-01-30T19:09:05Z
[quote="jayeffe"]
Premesso che non sono esperto in materia penso che a questa formula manchi un pedice ad una delle due
[quote="jayeffe"]Quindi questo segnale ha uno spettro triangolare?
Quale segnale intendi per "questo"?
Re: Teorema di Shannon https://www.electroyou.it/forum/viewtopic.php?f=1&t=79862#p836273 jayeffe 2020-01-30T18:09:39Z 2020-01-30T18:09:39Z
Il libro porta questo come spettro del segnale campionato , con la n che va da -oo a oo
Re: Teorema di Shannon https://www.electroyou.it/forum/viewtopic.php?f=1&t=79862#p836265 MarcoD 2020-01-30T17:44:01Z 2020-01-30T17:44:01Z
non sono riuscito a capire il perche l'utilizzo del segnale triangolare
Per segnale di solito si intende una funzione del tempo, quello triangolare è il modulo dello spettro del segnale.
Non saprei perchè è stato usato uno spettro triangolare, qualunque spettro a banda limitata va bene.
Forse è stato adoperato per facilità di disegno.
Poi si solito uno spettro (segnale) ha una quantità di energia maggiore a frequenze basse,
Che sagoma di spettro suggerisci? a coseno rianzato?
Sono curioso di leggere altri interventi.
Re: Teorema di Shannon https://www.electroyou.it/forum/viewtopic.php?f=1&t=79862#p836260 jayeffe 2020-01-30T17:34:17Z 2020-01-30T17:34:17Z
ho letto ma ancora non sono riuscito a capire il perche l'utilizzo del segnale triangolare
Re: Teorema di Shannon https://www.electroyou.it/forum/viewtopic.php?f=1&t=79862#p836254 g.schgor 2020-01-30T16:48:37Z 2020-01-30T16:48:37Z
Vedi qui
Teorema di Shannon https://www.electroyou.it/forum/viewtopic.php?f=1&t=79862#p836222 jayeffe 2020-01-30T10:45:17Z 2020-01-30T10:45:17Z
Salve a tutti , ho iniziato a studiare il teorema del campionamento di Shannon.
Ho capito che nell'ipotesi che è rispettata la condizione di Nyquist il segnale campionato è ricostruibile mediante un filtro passa basso ideale.
Il libro procede poi a spiegare perché il filtro resta ideale.
Volevo chiedere, come mai viene utilizzato un segnale triangolare?
