[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(81cc1bb172298d90c067b9507816c5a0.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/81cc1bb172298d90c067b9507816c5a0.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/81cc1bb172298d90c067b9507816c5a0.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/81cc1bb172298d90c067b9507816c5a0.png): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(9e78f803a32081eceab0b7ca9b9ccbcd.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/9e78f803a32081eceab0b7ca9b9ccbcd.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/9e78f803a32081eceab0b7ca9b9ccbcd.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/9e78f803a32081eceab0b7ca9b9ccbcd.png): No such file or directory
[phpBB Debug] PHP Warning: in file /generate_feed.php on line 295: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3768)
Latest posts from topic “Rete dinamica in regime costante” Latest posts from topic “Rete dinamica in regime costante” on “ElectroYou”. 2015-09-20T10:49:17Z https://www.electroyou.it/forum/viewtopic.php?f=2&t=60287 Re: Rete dinamica in regime costante https://www.electroyou.it/forum/viewtopic.php?f=2&t=60287#p602460 Giuls91 2015-09-20T16:02:17Z 2015-09-20T16:02:17Z
Quindi non ho bisogno di applicare metodi vari? Che sciocca :oops: che tra l'altro non mi hanno portata neanche ad un risultato corretto #-o
E per calcolare la tensione del condensatore quindi considero come se vi fosse una maglia a sè stante e scrivo la LKT. Giusto, non sapevo come comportarmi in questo caso. Fino ad ora ho trovato reti composte in modo diverso, ma mai così :?:
Poi, invece, per t>0, quando l'interruttore chiude, posso procedere utilizzando il mio amato Laplace, no?
Appena risolvo la seconda parte, posto il tutto così viene un esercizio completo :-)
Grazie RenzoDF ;-)
-----> mi sono accorta che non avevo aperto l'interruttore. Che sbadata che sono! #-o #-o
Re: Rete dinamica in regime costante https://www.electroyou.it/forum/viewtopic.php?f=2&t=60287#p602450 RenzoDF 2015-09-20T15:10:09Z 2015-09-20T15:10:09Z
Per t=0- l'interruttore è aperto (non chiuso) e di conseguenza [unparseable or potentially dangerous latex formula], essendo uguale a quella impressa dal GIC, mentre [unparseable or potentially dangerous latex formula] grazie ad una semplice KVL all'anello sinistro.
Rete dinamica in regime costante https://www.electroyou.it/forum/viewtopic.php?f=2&t=60287#p602414 Giuls91 2015-09-20T10:49:17Z 2015-09-20T10:49:17Z
Buongiorno a tutti! O_/
Stamattina ho a che fare con questo esercizio a regime costante
di cui devo trovare la corrente [unparseable or potentially dangerous latex formula].
L'interruttore S chiude all'istante t=0.
Per trovare le condizioni iniziali, visto che siamo in regime costante, approssimo l'induttore ad un corto circuito e il condensatore ad un circuito aperto. Ottengo, quindi, questa rete così fatta da studiare:
A questo punto, ho pensato di trasformare il lato alla Thevenin in lato alla Norton, con il generatore di corrente in parallelo ad R, di valore pari a \frac{V_g}{R}. In questo modo, i_L sarà data dal rapporto tra il potenziale del nodo corrispondente e il valore della resistenza presente nel lato dell'induttore. In questo modo:
in cui e_C=0 perchè nodo di riferimento.
Quindi i_L=\frac{e_A}{R}.
Utilizzando il metodo dei potenziali nodali e sostituendo i valori numerici, ottengo che [unparseable or potentially dangerous latex formula].
Il mio problema adesso è: come trovo la tensione [unparseable or potentially dangerous latex formula]?
Help meeee :?:
