[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(20219a4d3a7d9ded76ef13ef6ac07488.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/20219a4d3a7d9ded76ef13ef6ac07488.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/20219a4d3a7d9ded76ef13ef6ac07488.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/20219a4d3a7d9ded76ef13ef6ac07488.png): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(2edc02cc80a8457089b71560668130b6.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/2edc02cc80a8457089b71560668130b6.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/2edc02cc80a8457089b71560668130b6.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/2edc02cc80a8457089b71560668130b6.png): No such file or directory
[phpBB Debug] PHP Warning: in file /generate_feed.php on line 295: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3768)
Latest posts from topic “Aiuto circuito dinamico del 2° ordine in regime sinusoidale” Latest posts from topic “Aiuto circuito dinamico del 2° ordine in regime sinusoidale” on “ElectroYou”. 2016-06-19T19:26:47Z https://www.electroyou.it/forum/viewtopic.php?f=2&t=64717 Re: Aiuto circuito dinamico del 2° ordine in regime sinusoid https://www.electroyou.it/forum/viewtopic.php?f=2&t=64717#p656004 admin 2016-06-20T00:07:30Z 2016-06-20T00:07:30Z
Non esiste alcun passaggio che spiega le valutazioni che attribuisci al libro
Re: Aiuto circuito dinamico del 2° ordine in regime sinusoid https://www.electroyou.it/forum/viewtopic.php?f=2&t=64717#p655973 DLz 2016-06-19T20:37:31Z 2016-06-19T20:37:31Z
EDIT: Avevo sbagliato un segno, adesso trovo anch'io che \overline{Vg}= j8 V e quindi nel dominio del tempo [unparseable or potentially dangerous latex formula]. Però la mia domanda resta, perché [unparseable or potentially dangerous latex formula] e [unparseable or potentially dangerous latex formula], cioè qual è il passaggio, nel dominio del tempo, che porta ad avere valori nulli per i_L e V_1 ?
Aiuto circuito dinamico del 2° ordine in regime sinusoidale https://www.electroyou.it/forum/viewtopic.php?f=2&t=64717#p655956 DLz 2016-06-19T19:26:47Z 2016-06-19T19:26:47Z
Salve a tutti :-) , questo è il circuito:
L'interruttore K, si chiude a t=0. L'esercizio vuole, sapendo che la rete è in regime prima della chiusura di K, l'andamento di [unparseable or potentially dangerous latex formula] .
Prima di tutto porto tutto nel dominio dei fasori e poi inizio studiando le condizioni iniziali per t=0^- (quindi interruttore ancora aperto)
Trovo come risultato \overline{Vg}= \overline{V_1} + \overline{V_L} = 8 V (sono nel dominio dei fasori)
E, passando al dominio del tempo ho [unparseable or potentially dangerous latex formula] allora a t=0 ho [unparseable or potentially dangerous latex formula]
Il libro invece, dopo aver trovato il fasore della corrente nell'induttore \overline{I_L} ed il
fasore della tensione nel resistore R_1, ossia \overline{V_1}, uguali a quelli da me
ottenuti, scrive, passando nel dominio del tempo che
[unparseable or potentially dangerous latex formula] allora [unparseable or potentially dangerous latex formula]
e
E quindi ha la condizione iniziale [unparseable or potentially dangerous latex formula]
Ma perché [unparseable or potentially dangerous latex formula] e [unparseable or potentially dangerous latex formula]
Grazie :D
