[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(9dba1f9e0c1d466ec9e1762b4b9743d2.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/9dba1f9e0c1d466ec9e1762b4b9743d2.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/9dba1f9e0c1d466ec9e1762b4b9743d2.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/9dba1f9e0c1d466ec9e1762b4b9743d2.png): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(eb0309f54198d1d9daa30bd6059fa066.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/eb0309f54198d1d9daa30bd6059fa066.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/eb0309f54198d1d9daa30bd6059fa066.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/eb0309f54198d1d9daa30bd6059fa066.png): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(f347d5d27ac0edfb3152c3c149a6601d.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/f347d5d27ac0edfb3152c3c149a6601d.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/f347d5d27ac0edfb3152c3c149a6601d.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/f347d5d27ac0edfb3152c3c149a6601d.png): No such file or directory
[phpBB Debug] PHP Warning: in file /generate_feed.php on line 295: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3768)
Latest posts from topic “Risoluzione di un circuito in regime sinusoidale” Latest posts from topic “Risoluzione di un circuito in regime sinusoidale” on “ElectroYou”. 2017-05-23T21:21:53Z https://www.electroyou.it/forum/viewtopic.php?f=2&t=69259 Re: Risoluzione di un circuito in regime sinusoidale https://www.electroyou.it/forum/viewtopic.php?f=2&t=69259#p713302 gac 2017-05-24T14:17:13Z 2017-05-24T14:17:13Z
[quote="jayeffe"]
Quindi da \frac{1}{2} VI^* avro un P+jQ dove la parte reale è la potenza attiva..
Senza andare a stuzzicare le funzioni seno e coseno giusto?
Proprio così! :-)
Re: Risoluzione di un circuito in regime sinusoidale https://www.electroyou.it/forum/viewtopic.php?f=2&t=69259#p713295 jayeffe 2017-05-24T14:00:08Z 2017-05-24T14:00:08Z
Re: Risoluzione di un circuito in regime sinusoidale https://www.electroyou.it/forum/viewtopic.php?f=2&t=69259#p713294 gac 2017-05-24T13:40:20Z 2017-05-24T13:40:20Z
Noto il potenziale al nodo c sono noti i potenziali a tutti i nodi del circuito, quindi puoi calcolare tutte le differenze di potenziale e conseguentemente le correnti su ciascun ramo. Come al solito, si ha che la potenza complessa vale
\frac{1}{2} VI^*
mentre la potenza attiva è la sua parte reale. Credo che sia molto megio calcolare la potenza attiva (lo stesso vale per la reattiva) in questo modo, per evitare calcoli con funzioni seno e coseno.
Re: Risoluzione di un circuito in regime sinusoidale https://www.electroyou.it/forum/viewtopic.php?f=2&t=69259#p713217 jayeffe 2017-05-24T01:00:23Z 2017-05-24T01:00:23Z
quindi per la potenza attiva devo usare la formula
[unparseable or potentially dangerous latex formula]
e invece per la potenza complessa devo usare solo \frac12{V}{I}
Ovviamente ho solo V...posso usare la legge di kirkhoff per la corrente al nodo a e ricavo I del generatore, giusto? :D
Re: Risoluzione di un circuito in regime sinusoidale https://www.electroyou.it/forum/viewtopic.php?f=2&t=69259#p713208 gac 2017-05-23T23:30:54Z 2017-05-23T23:30:54Z
Calma, non è proprio così. Ho tracciato il supernodo e le correnti ad esso associate nel seguente schema e per esso ho definito una legge di Kirchhoff per le correnti, indicata dalle frecce in rosso.
Per semplicità, supponiamo che V_B = 0 \; \text{V}, che ne dici? :-)
la KCL risulta
\frac{V_C}{R_2} + \frac{V_C - V_A}{\frac{1}{j \omega C}} + \frac{V_D}{R_1 + j \omega L} + \frac{V_D - V_A}{R_S} = 0
con V_C incognita, V_D = e_1 - V_C e V_A = e_2.
La KCL del supernodo associato al generatore di tensione e_1 è nient'altro che la combinazione delle KCL associate ai suoi nodi, accomunati dalla corrente I_{e_1}, che nel mio svolgimento ho dimostrato essere inutile nel calcolo del risultato finale. In conclusione, si riottiene la stessa equazione per il calcolo del potenziale del nodo di interesse.
Non mi ricordavo a dire il vero questo metodo,ti ringrazio. :D
Re: Risoluzione di un circuito in regime sinusoidale https://www.electroyou.it/forum/viewtopic.php?f=2&t=69259#p713200 jayeffe 2017-05-23T22:32:40Z 2017-05-23T22:32:40Z
[quote="gac"]Lo puoi risolvere col metodo dei nodi, in particolare calcolando il potenziale V_1 in figura
si può analizzare tutta la rete (in particolare come le correnti su ciascun ramo). Ho messo in evidenza anche la corrente del generatore e_1, che non andrà calcolata.
devi scrivere un sistema di due equazioni del tipo
\begin{cases}
-\frac{V_1}{R_2} - \frac{V_1 - e_2}{ \frac{1}{j \omega C} } - I_{e_1} = 0 \\
I_{e_1} - \frac{e_1 + V_1}{R_1 + j \omega L} - \frac{e_1 + V_1 - e_2}{R_3} = 0
\end{cases}
Risolvendo il sistema si ottiene che
Prodotti tensioni-ammettenze: check dimensionale verificato!
quindi
Purtroppo devo andare quindi non posso al momento sostituire i valori nella formula.
Puoi risolverlo anche con lo sdoppiamento del generatore di tensione e_2 (un generatore in serie alla capacità un altro in serie a R_3, elettricamente separati) e modificando il disegno della rete in modo tale da calcolare V_1 con Millman. Otterrai lo stesso risultato (se ho fatto bene i conti) ;-).
Per fare l'esercizio ho interpretato il Renzo Perfetti che mi spiega l'esercizio guidato quando vi è il supernodo. Io ho fissato il riferimento al nodo C
fissando al nodo c (spero di aver capito bene la teoria) il nodo d viene escluso perchè connesso al generatore tramite riferimento.
ora ho definito il supernodo impostando l'equazione V_A-V_b=E2
da qui l'esercizio guida di Perfetti che ho imitato dice di scrivere 1 equazione per il nodo a e b
e metterla a sistema con la relazione V_A-V_b=E2
le correnti le ho scelte io con la convenzione sul nodo b e ho fatto \frac{Vb}{Z_L+R1}+\frac{Vb}{R2}+\frac{Va}{Z_C}+\frac{Va-Vd}{R5}
ora VD=E1
E dall equazione VB-VA=E2 ricavo il resto..
ho Interpretato bene il metodo di perfetti?
Re: Risoluzione di un circuito in regime sinusoidale https://www.electroyou.it/forum/viewtopic.php?f=2&t=69259#p713197 PietroBaima 2017-05-23T21:52:49Z 2017-05-23T21:52:49Z
Puoi ridisegnare il circuito così:
e poi applicare Millman.
Pietro.
Re: Risoluzione di un circuito in regime sinusoidale https://www.electroyou.it/forum/viewtopic.php?f=2&t=69259#p713192 gac 2017-05-23T21:31:27Z 2017-05-23T21:31:27Z
[quote="jayeffe"]quando si usano i potenziali ai nodi con i fasori, potrebbe essere più conveniente calcolare le ammettenze, anziché le impedenze ?
Certamente, ma io sono abituato a calcolare le impedenze, a quel punto mi basta pigiare il tasto reciproco sulla calcolatrice (se lavora con i numeri complessi) :-)
Re: Risoluzione di un circuito in regime sinusoidale https://www.electroyou.it/forum/viewtopic.php?f=2&t=69259#p713191 jayeffe 2017-05-23T21:29:40Z 2017-05-23T21:29:40Z
Delle volte cerco di evitare Thevenin perchè spesso commetto errori, comunque quando si usano i potenziali ai nodi con i fasori, potrebbe essere più conveniente calcolare le ammettenze, anziché le impedenze ?
Re: Risoluzione di un circuito in regime sinusoidale https://www.electroyou.it/forum/viewtopic.php?f=2&t=69259#p713189 gac 2017-05-23T21:21:53Z 2017-05-23T21:21:53Z
\begin{cases}
\end{cases}
quindi
