[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(788250d2353de4f2ba0c757d8b10aaee.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/788250d2353de4f2ba0c757d8b10aaee.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/788250d2353de4f2ba0c757d8b10aaee.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/788250d2353de4f2ba0c757d8b10aaee.png): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(2379f0db803b3865fdd17d7b77897c9b.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/2379f0db803b3865fdd17d7b77897c9b.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/2379f0db803b3865fdd17d7b77897c9b.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/2379f0db803b3865fdd17d7b77897c9b.png): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(2f5a840abcd5340c2dd0e51312e11d5d.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/2f5a840abcd5340c2dd0e51312e11d5d.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/2f5a840abcd5340c2dd0e51312e11d5d.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/2f5a840abcd5340c2dd0e51312e11d5d.png): No such file or directory
[phpBB Debug] PHP Warning: in file /generate_feed.php on line 295: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3768)
Latest posts from topic “Fasori , da forma algebrica ad esponenziale” Latest posts from topic “Fasori , da forma algebrica ad esponenziale” on “ElectroYou”. 2017-08-08T12:59:10Z https://www.electroyou.it/forum/viewtopic.php?f=2&t=70316 Re: Fasori , da forma algebrica ad esponenziale https://www.electroyou.it/forum/viewtopic.php?f=2&t=70316#p723902 StudDisperato 2017-08-09T19:30:37Z 2017-08-09T19:30:37Z
Grazie gac , allora vorrà dire che si tratta dell'ennesimo errore
AHAHAHAHAHAHAHAH stesso pensiero caro sebago
Già da domani tornerò a rompervi
Un Saluto a tutti :D
Re: Fasori , da forma algebrica ad esponenziale https://www.electroyou.it/forum/viewtopic.php?f=2&t=70316#p723886 sebago 2017-08-09T17:25:12Z 2017-08-09T17:25:12Z
[quote="StudDisperato"]...vi posto il compito della prof :
Detto in OT, ma non poteva usare un editor di testi appena un po' più decente?
Re: Fasori , da forma algebrica ad esponenziale https://www.electroyou.it/forum/viewtopic.php?f=2&t=70316#p723844 gac 2017-08-09T11:05:42Z 2017-08-09T11:05:42Z
In effetti anche io mi trovo come ti sei trovato tu, cioè con -\frac{\pi}{2}
Scrivo il fasore della tensione come
\textbf{V}=-j V_m e ^{j a_v}
Quello di corrente come
\textbf{I}=I_m e ^{j a_i}
Quindi la potenza complessa risulta
[unparseable or potentially dangerous latex formula]
A questo punto puoi ovviamente "scomporre" l'esponenziale complesso con la formula di Eulero.
Re: Fasori , da forma algebrica ad esponenziale https://www.electroyou.it/forum/viewtopic.php?f=2&t=70316#p723776 StudDisperato 2017-08-08T16:32:41Z 2017-08-08T16:32:41Z
Grazie mille ad entrambi per la risposta ,
Speravo che rispondeste così perchè stavo per perderci la testa .
Vi rompo le scatole ancora un poco nel tentativo di salvare la mia autostima in elettrotecnica :
Qui ho proceduto con la classica formula della potenza complessa come semi-prodotto fra il fasore tensione ed il coniugato del fasore corrente , tuttavia il risultato che viene dovrebbe essere quello della risposta c) ma ponendo
\phi = a_{v}-a_{i}-\frac{\pi}{2}
Cosa ne pensate ?
Scusate ancora il disturbo
Un saluto
Re: Fasori , da forma algebrica ad esponenziale https://www.electroyou.it/forum/viewtopic.php?f=2&t=70316#p723775 IsidoroKZ 2017-08-08T16:30:50Z 2017-08-08T16:30:50Z
A me sembra che la prof abbia dimenticato di calcolare l'arco tangente e che quindi tu abbia ragione, come pure dice Foto UtenteMax2433BO
Re: Fasori , da forma algebrica ad esponenziale https://www.electroyou.it/forum/viewtopic.php?f=2&t=70316#p723772 Max2433BO 2017-08-08T16:14:12Z 2017-08-08T16:14:12Z
Non ricordandomi più come si trasforma un numero complesso dalla forma a \pm ib, e con questo caldo non ho la forza di andarmi a cercare il mio vecchio libro di matematica delle superiori, ho provato ad inserire il tuo risultato, [unparseable or potentially dangerous latex formula] nel mitico Wolframalpha e, guardando il grafico nel piano complesso si nota che il risultato è corretto perchè corrisponde a -2 + i3, per cui penso che i risultati nelle risposte che ti sono stati forniti siano errati...
... se poi ho preso una madornale cantonata, sicuramente chi mastica mooolta matematica più di me :mrgreen: , te lo farà presente.
O_/ Max
Fasori , da forma algebrica ad esponenziale https://www.electroyou.it/forum/viewtopic.php?f=2&t=70316#p723745 StudDisperato 2017-08-08T12:59:10Z 2017-08-08T12:59:10Z
Salve a tutti ,
scusate se vi disturbo ad Agosto . Dunque stavo studiando il regime sinusoidale ma vengo messo in crisi da questo esercizio , vi posto il compito della prof :
Procedo così :
Calcolo il modulo : [unparseable or potentially dangerous latex formula]
Adesso vedo che la parte reale è negativa mentre il coefficiente dell'immaginaria è positivo allora la fase dovrebbe essere : [unparseable or potentially dangerous latex formula]
Pertanto la forma esponenziale dovrebbe essere : [unparseable or potentially dangerous latex formula]
Questo è il mio procedimento e non capisco dove abbia sbagliato , magari c'è qualche semplificazione che mi sfugge .
Grazie in anticipo a tutti
Un saluto
