[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(6eef655c597070837cdebc3332b99a16.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/6eef655c597070837cdebc3332b99a16.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/6eef655c597070837cdebc3332b99a16.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/6eef655c597070837cdebc3332b99a16.png): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(6caf360710d0516ca251fb5d063f3444.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/6caf360710d0516ca251fb5d063f3444.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/6caf360710d0516ca251fb5d063f3444.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/6caf360710d0516ca251fb5d063f3444.png): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(2f6caa082ceeeddb003b3955220e0e18.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/2f6caa082ceeeddb003b3955220e0e18.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/2f6caa082ceeeddb003b3955220e0e18.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/2f6caa082ceeeddb003b3955220e0e18.png): No such file or directory
[phpBB Debug] PHP Warning: in file /generate_feed.php on line 295: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3768)
Latest posts from topic “Circuito RLC, dubbio sulla soluzione di regime.” Latest posts from topic “Circuito RLC, dubbio sulla soluzione di regime.” on “ElectroYou”. 2018-01-06T21:16:04Z https://www.electroyou.it/forum/viewtopic.php?f=2&t=72205 Re: Circuito RLC, dubbio sulla soluzione di regime. https://www.electroyou.it/forum/viewtopic.php?f=2&t=72205#p748727 noisemake 2018-01-08T10:33:07Z 2018-01-08T10:33:07Z
OK grazie mille :)
Re: Circuito RLC, dubbio sulla soluzione di regime. https://www.electroyou.it/forum/viewtopic.php?f=2&t=72205#p748653 RenzoDF 2018-01-07T17:06:51Z 2018-01-07T17:06:51Z
E se si avesse E=0 per t>0 ?
Data per corretta la soluzione data del testo, le tue due ipotesi non sono ammissibili.
Re: Circuito RLC, dubbio sulla soluzione di regime. https://www.electroyou.it/forum/viewtopic.php?f=2&t=72205#p748648 noisemake 2018-01-07T16:32:53Z 2018-01-07T16:32:53Z
Affinché quel risultato sia corretto deve essere la tensione sul condensatore pari a zero.
Ma non solo perché se così fosse non troverei valori corretti di A e B.
Infatti imponendo
[unparseable or potentially dangerous latex formula]
otterrei 0=A+1 quindi A=-1
e che
[unparseable or potentially dangerous latex formula] ottengo
0=\alpha A+ \beta B quindiB=-0,57
ottenendo quindi [unparseable or potentially dangerous latex formula]
Se invece fosse la tensione sul condensatore pari a zero e E=-1V otterrei
Ma comunque non giungo al risultato.
Re: Circuito RLC, dubbio sulla soluzione di regime. https://www.electroyou.it/forum/viewtopic.php?f=2&t=72205#p748613 RenzoDF 2018-01-07T15:00:57Z 2018-01-07T15:00:57Z
Visto che quel dato E=1 non può che essere interpretato con e(t)=1 V, avrai che all'istante 0+, visto che i(0+)=0 A, la tensione ai morsetti del resistore sarà nulla e così pure la tensione ai morsetti dell'induttore, ne segue (che per l'equazione costitutiva dello stesso) anche la derivata della corrente (vL/L) sarà nulla e quindi la corrente per t>0 rimarrà identicamente nulla e di conseguenza la tensione vC identicamente uguale a 1 volt.
Dalla errata soluzione è comunque facile risalire all'errore nei dati che, una volta corretto, porterà anche la soluzione ufficiale ad essere corretta. ;-)
Re: Circuito RLC, dubbio sulla soluzione di regime. https://www.electroyou.it/forum/viewtopic.php?f=2&t=72205#p748564 noisemake 2018-01-07T11:23:25Z 2018-01-07T11:23:25Z
Potresti spiegarmi meglio RenzoDF?
Re: Circuito RLC, dubbio sulla soluzione di regime. https://www.electroyou.it/forum/viewtopic.php?f=2&t=72205#p748512 RenzoDF 2018-01-07T00:00:05Z 2018-01-07T00:00:05Z
Con le condizioni iniziali indicate, non serve risolvere nessuna equazione differenziale in quanto [unparseable or potentially dangerous latex formula] per t>0.
Circuito RLC, dubbio sulla soluzione di regime. https://www.electroyou.it/forum/viewtopic.php?f=2&t=72205#p748487 noisemake 2018-01-06T21:16:04Z 2018-01-06T21:16:04Z
Salve a tutti l'esercizio è un classico circuito RLC .
Non mi è chiaro perché nel risultato non c'è la soluzione particolare cioè quella di regime.
L'equazione differenziale del 2° ordine che mi permette di risolvere l'esercizio è:
l'omogenea associata è \lambda^2+10^6 \lambda+10^{12}=0
quindi \Delta <0 ed ottengo le due soluzioni \lambda_{1,2}=-10^6/2 \pm \sqrt{3}/2 *10^6 j
\alpha=-5*10^5 e \beta=8,7*10^5
ora l'integrale generale dovrebbe essere
dove V_{p} è un integrale particolare ,cioè la soluzione di regime per t->\infty ed in tal caso essendo il generatore stazionario otterrei V_{p}=1 .
Ma a questo punto se considero V_{p} non riesco a trovare i valori corretti di A e B.
