[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(17b82f0005e29c7771e7de6d6eef1f9d.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/17b82f0005e29c7771e7de6d6eef1f9d.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/17b82f0005e29c7771e7de6d6eef1f9d.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/17b82f0005e29c7771e7de6d6eef1f9d.png): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(bd39e60c3fbd5f0644244961d5d6ba1c.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/bd39e60c3fbd5f0644244961d5d6ba1c.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/bd39e60c3fbd5f0644244961d5d6ba1c.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/bd39e60c3fbd5f0644244961d5d6ba1c.png): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(daabf12d7010773cfd055c142c203e8f.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/daabf12d7010773cfd055c142c203e8f.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/daabf12d7010773cfd055c142c203e8f.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/daabf12d7010773cfd055c142c203e8f.png): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(3081c938abbf8a455e3adfc85f2b8a52.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/3081c938abbf8a455e3adfc85f2b8a52.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/3081c938abbf8a455e3adfc85f2b8a52.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/3081c938abbf8a455e3adfc85f2b8a52.png): No such file or directory
[phpBB Debug] PHP Warning: in file /generate_feed.php on line 295: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3768)
Latest posts from topic “trasformazione fasoriale” Latest posts from topic “trasformazione fasoriale” on “ElectroYou”. 2018-02-06T10:30:46Z https://www.electroyou.it/forum/viewtopic.php?f=2&t=72637 Re: trasformazione fasoriale https://www.electroyou.it/forum/viewtopic.php?f=2&t=72637#p754674 admin 2018-02-06T15:05:21Z 2018-02-06T15:05:21Z
Sì, la potenza complessa è un numero complesso la cui parte reale è la potenza attiva e l'immaginaria quella reattiva.
La sua unità di misura è il VA non il V Ar come scritto nel testo; var, tra l'altro scritto tutto in minuscolo, indica la potenza reattiva
Re: trasformazione fasoriale https://www.electroyou.it/forum/viewtopic.php?f=2&t=72637#p754669 Exodus 2018-02-06T14:48:33Z 2018-02-06T14:48:33Z
[quote="admin"]La potenza reattiva è un numero reale
In effetti, però il libro parla di potenza complessa e poi dà il risultato come "var".
Forse il libro intende questo?
[unparseable or potentially dangerous latex formula]
Re: trasformazione fasoriale https://www.electroyou.it/forum/viewtopic.php?f=2&t=72637#p754658 admin 2018-02-06T14:16:19Z 2018-02-06T14:16:19Z
La potenza reattiva è un numero reale. Quando la si calcola si usa il modulo della grandezza elettrica, non la sua rappresentazione fasoriale. Il suo segno è positivo se riguarda un'induttanza, negativo se relativa ad una capacità. A scelta si può considerare sempre qualsiasi reattanza positiva, quindi attribuire il segno nel modo precedentemente detto. Oppure si può considerare negativa la reattanza capacitiva, positiva quella induttiva.
Quindi
Q_c=-X_cI_c^2=-0{,}8 \times 0{,}25^2= -5 \, \text{var}
Re: trasformazione fasoriale https://www.electroyou.it/forum/viewtopic.php?f=2&t=72637#p754651 Exodus 2018-02-06T13:43:06Z 2018-02-06T13:43:06Z
[quote="kr94"]credo di avercela fatta
[quote="kr94"][unparseable or potentially dangerous latex formula]
E il segno meno che fine ha fatto ?
Forse intendi questo:
Re: trasformazione fasoriale https://www.electroyou.it/forum/viewtopic.php?f=2&t=72637#p754644 kr94 2018-02-06T13:11:22Z 2018-02-06T13:11:22Z
ho trasformato la funzione nel fasore 10j
col partitore di corrende ho trovato la corrente in R_2
x_c=-j1/\omega_c=-0{,}8 \text{j}
ora a giudicare dal risultato che mi ritrovo sembra che il libro abbia usato il fasore 10 e non 10j
Re: trasformazione fasoriale https://www.electroyou.it/forum/viewtopic.php?f=2&t=72637#p754641 kr94 2018-02-06T12:59:28Z 2018-02-06T12:59:28Z
R_1=R_2=5 \, \Omega
L_1=1 \, \text{mH}   \quad C=12{,}5 \, \text{mF}
a=0,5
Re: trasformazione fasoriale https://www.electroyou.it/forum/viewtopic.php?f=2&t=72637#p754640 kr94 2018-02-06T12:55:56Z 2018-02-06T12:55:56Z
Re: trasformazione fasoriale https://www.electroyou.it/forum/viewtopic.php?f=2&t=72637#p754622 admin 2018-02-06T11:16:03Z 2018-02-06T11:16:03Z
Devi imparare ad usare FidoCadJ per gli schemi e scrivere le formule matematiche usando LateX se vuoi continuare ad essere seguito su questo forum.
Le fotografie con il telefonino, oltre che inibire chi potrebbe risponderti e rendere difficoltosa la risposta a chi lo fa lo stesso, sono esteticamente molto brutte da vedere e deturpano l'immagine del forum.
Re: trasformazione fasoriale https://www.electroyou.it/forum/viewtopic.php?f=2&t=72637#p754620 kr94 2018-02-06T11:06:32Z 2018-02-06T11:06:32Z
ho risolto cosi questo esercizio, e se non erro sembra che i sia pari a 10 e non 10j come ho scritto io
Re: trasformazione fasoriale https://www.electroyou.it/forum/viewtopic.php?f=2&t=72637#p754609 jayeffe 2018-02-06T10:30:46Z 2018-02-06T10:30:46Z
Sul mio libro sta scritto che dividendo per la radice di 2 si usa la convenzione dei valori efficaci.
Infatti ad esempio la potenza alcuni la calcolano come VI
altri invece che non usano i valori efficaci usano VI/2
