[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(f23af041690d9e1dc2161b71a944ac7d.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/f23af041690d9e1dc2161b71a944ac7d.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/f23af041690d9e1dc2161b71a944ac7d.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/f23af041690d9e1dc2161b71a944ac7d.png): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(7763a795c3c1944bf8b377bc8f65b93c.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/7763a795c3c1944bf8b377bc8f65b93c.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/7763a795c3c1944bf8b377bc8f65b93c.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/7763a795c3c1944bf8b377bc8f65b93c.png): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(a44ad48d70c2502accbe3b34e6c167be.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/a44ad48d70c2502accbe3b34e6c167be.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/a44ad48d70c2502accbe3b34e6c167be.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/a44ad48d70c2502accbe3b34e6c167be.png): No such file or directory
[phpBB Debug] PHP Warning: in file /generate_feed.php on line 295: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3768)
Latest posts from topic “Esercizio università Elettrotecnica sui generatori pilotati” Latest posts from topic “Esercizio università Elettrotecnica sui generatori pilotati” on “ElectroYou”. 2018-05-30T14:53:01Z https://www.electroyou.it/forum/viewtopic.php?f=2&t=74071 Re: Esercizio università Elettrotecnica sui generatori pilot https://www.electroyou.it/forum/viewtopic.php?f=2&t=74071#p773406 PietroBaima 2018-05-30T19:21:34Z 2018-05-30T19:21:34Z
Tutte le volte che c’è un generatore di corrente pilotato dalla corrente che scorre in una resistenza posta a lui in parallelo la rete esterna vede un resistore equivalente pari alla resistenza divisa per 1+k.
A pensarci è semplice, perchè l’insieme R e generatore di corrente drenano una corrente 1+k volte maggiore della corrente che può drenare la sola resistenza.
Sostituendo il generatore pilotato di corrente e la resistenza a lui in parallelo con una resistenza pari a 2 ohm/(1+k) (quanto NON mi piace questa notazione :!: ) si ottiene una rete facilmente risolubile con Millman.
Il valore di ia si ottiene poi dividendo la tensione di Millman per il valore della resistenza posta in parallelo al generatore pilotato.
Re: Esercizio università Elettrotecnica sui generatori pilot https://www.electroyou.it/forum/viewtopic.php?f=2&t=74071#p773397 gac 2018-05-30T18:54:45Z 2018-05-30T18:54:45Z
[quote="Exodus"]
La corrente a come vedi è moltiplicata per 2 , ovvero il valore della resistenza
Perdonami ma non avevo capito che quel 2 si riferisse ad una resistenza. La prossima volta potresti aggiungere l'unità di misura per evitare confusione.
Re: Esercizio università Elettrotecnica sui generatori pilot https://www.electroyou.it/forum/viewtopic.php?f=2&t=74071#p773396 Exodus 2018-05-30T18:39:16Z 2018-05-30T18:39:16Z
[quote="gac"]Dimensionalmente non torna proprio, in quanto stai sommando al numeratore una tensione ed una corrente.
La corrente a come vedi è moltiplicata per 2 , ovvero il valore della resistenza.
dalla legge di Ohm:
V=RI
si tratta di una tensione.
[quote="gac"]Io ho trovato queste due espressioni, definendo per le resistenze i valori generici R e \frac{R}{2}
Non c'è bisogno di definire delle espressione generiche, i dati delle resistenze ci sono,comunque non ci pensare troppo su il risultato che ho postato è giusto.. ;-)
Re: Esercizio università Elettrotecnica sui generatori pilot https://www.electroyou.it/forum/viewtopic.php?f=2&t=74071#p773382 gac 2018-05-30T16:52:02Z 2018-05-30T16:52:02Z
[quote="Exodus"]
[unparseable or potentially dangerous latex formula]
Re: Esercizio università Elettrotecnica sui generatori pilot https://www.electroyou.it/forum/viewtopic.php?f=2&t=74071#p773376 Ianero 2018-05-30T16:03:43Z 2018-05-30T16:03:43Z
[quote="marghez97"]Quindi l'approccio di risolvere l'esercizio con il principio di sovrapposizione risulta altrettanto corretto o non è proprio fattibile?
http://www.electroyou.it/admin/wiki/gen ... li-effetti
Re: Esercizio università Elettrotecnica sui generatori pilot https://www.electroyou.it/forum/viewtopic.php?f=2&t=74071#p773374 marghez97 2018-05-30T15:54:24Z 2018-05-30T15:54:24Z
[quote="Exodus"]Le 2 Resistenze da 4\Omega sono in parallelo quindi puoi semplificare in una unica resistenza da 2\Omega.
Considerando che il circuito ha solamente 2 nodi, applico la KCL al nodo 2.(il nodo 1 è quello dove c'è il generatore di tensione,l'altro è il nodo 2, la scelta del numero del nodo è arbitraria, puoi anche chiamarli nodo 10 e nodo 50)
Insomma applico la KCL:
\frac{v_{1}-2i_{a}}{2}+a-i_{a}-ki_{a}=0
Risolvo per i_{a}
i_{a}=\frac{a+\frac{1}{2}v_{1}}{k+2}
Calcolo la tensione al nodo 2
v_{2}=2i_{a}=\frac{2a+v_{1}}{k+2}
Adesso calcolo la v
:ok:
Grazie mille per la risposta :-)
A dire la verità non immaginavo potessi considerare in parallelo le due resistenze da 4\Omega (essendo i nodi non coincidenti, mi ha confuso le idee).
Re: Esercizio università Elettrotecnica sui generatori pilot https://www.electroyou.it/forum/viewtopic.php?f=2&t=74071#p773373 marghez97 2018-05-30T15:46:38Z 2018-05-30T15:46:38Z
[quote="Ianero"]Credo venga chiesta un'espressione simbolica.
Magari Foto Utentemarghez97 ci può confermare o, nel caso, fornire i valori.
Esatto, solo espressione simbolica!
Re: Esercizio università Elettrotecnica sui generatori pilot https://www.electroyou.it/forum/viewtopic.php?f=2&t=74071#p773370 Exodus 2018-05-30T15:20:15Z 2018-05-30T15:20:15Z
Risolvo per i_{a}
Adesso calcolo la v
:ok:
Re: Esercizio università Elettrotecnica sui generatori pilot https://www.electroyou.it/forum/viewtopic.php?f=2&t=74071#p773369 Ianero 2018-05-30T14:54:32Z 2018-05-30T14:54:32Z
Re: Esercizio università Elettrotecnica sui generatori pilot https://www.electroyou.it/forum/viewtopic.php?f=2&t=74071#p773368 g.schgor 2018-05-30T14:53:01Z 2018-05-30T14:53:01Z
Non vedo i valori di e ed a
