[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(2617fc9f67ca59afb8f96204453a54b3.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/2617fc9f67ca59afb8f96204453a54b3.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/2617fc9f67ca59afb8f96204453a54b3.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/2617fc9f67ca59afb8f96204453a54b3.png): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(21e3ae3b10b4d4375fb9092586a7f648.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/21e3ae3b10b4d4375fb9092586a7f648.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/21e3ae3b10b4d4375fb9092586a7f648.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/21e3ae3b10b4d4375fb9092586a7f648.png): No such file or directory
[phpBB Debug] PHP Warning: in file /generate_feed.php on line 295: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3768)
Latest posts from topic “Circuito in regime stazionario” Latest posts from topic “Circuito in regime stazionario” on “ElectroYou”. 2021-05-17T11:15:10Z https://www.electroyou.it/forum/viewtopic.php?f=2&t=84076 Re: Circuito in regime stazionario https://www.electroyou.it/forum/viewtopic.php?f=2&t=84076#p887999 EdmondDantes 2021-05-20T12:50:00Z 2021-05-20T12:50:00Z
Da notare la perfetta dualità tra la V3 e la I3 calcolata da Foto UtenteRenzoDF.
Re: Circuito in regime stazionario https://www.electroyou.it/forum/viewtopic.php?f=2&t=84076#p887754 EdmondDantes 2021-05-17T19:56:30Z 2021-05-17T19:56:30Z
L'esercizio si puo' risolvere applicando una sola volta la regola di Millman.
Vediamo come.
Disegniamo la rete duale
A questo punto applichiamo la regola di Millman per trovare \text{V}_{3} che corrisponde, numericamente, alla corrente \text{I}_{3} del circuito originale.
\text{V}_{3}=\frac{\frac{\text{R}_{4}\text{J}_{E}}{\text{R}_{2}+\text{R}_{4}}+\frac{\text{E}_{J}}{\text{R}_{1}}}{\frac{1}{\text{R}_{1}}+\frac{1}{\text{R}_{2}+\text{R}_{4}}+\frac{1}{\text{R}_{3}}}
Calcolata \text{V}_{3} ritorniamo nel circuito originale, la solita LKC per trovare la corrente su \text{R}_{1} e quindi la potenza associata al generatore ideale di corrente.
In pratica l'esercizio si puo' risolvere maneggiando esclusivamente la rete data.
PS
Ricordiamo che nella rete duale i generatori di corrente si trasformano in generatori di tensione (e viceversa) e le resistenze in conduttanze. I valori numerici rimangono inalterati.
Una resistenza da 5 ohm nel circuito originale corrisponde ad una conduttanza da 5 siemens nel circuito duale.
Un generatore ideale di tensione da 5 volt corrisponde ad un generatore ideale di corrente da 5 ampere e cosi' via.
PSS
Trasformando tutti i generatori ideali della rete originale si puo' arrivare a disegnare un circuito con una sola maglia e pertanto calcolare la corrente \text{I}_{3}.
Re: Circuito in regime stazionario https://www.electroyou.it/forum/viewtopic.php?f=2&t=84076#p887706 RenzoDF 2021-05-17T13:32:22Z 2021-05-17T13:32:22Z
Rimossa R3, ricavato il circuito equivalente secondo Thevenin via semplice ispezione della rete
E_{Th}=JR_1+E/2=40 \text{ V}
R_{Th}=R_1+R_2/2=35/2 \, \Omega
avremo che
[unparseable or potentially dangerous latex formula]
Per questa ragione consigliavo di rivedere i calcoli numerici.
Re: Circuito in regime stazionario https://www.electroyou.it/forum/viewtopic.php?f=2&t=84076#p887699 EdmondDantes 2021-05-17T12:37:35Z 2021-05-17T12:37:35Z
L'unica vera incognita e' la corrente \text{I}_{3}.
Dovremmo riuscire a risolvere il circuito usando esclusivamente questa incognita.
Facciamo due trasformazioni sul generatore ideale di tensione \text{E}.
\text{R}_{A} e' il parallelo tra \text{R}_{2} e \text{R}_{4}.
Una LKC e troviamo la corrente di lato di \text{R}_{1}.
Una LKV nella maglia inferiore della rete e possiamo calcolare la corrente incognita.
La tensione ai capi di J e' pari alla c.d.t. su \text{R}_{1}.
Re: Circuito in regime stazionario https://www.electroyou.it/forum/viewtopic.php?f=2&t=84076#p887688 Klaudijus 2021-05-17T11:47:02Z 2021-05-17T11:47:02Z
Quindi u_1 e u_2 sono errati dal punto di vista numerico. Grazie mille per la risposta
Re: Circuito in regime stazionario https://www.electroyou.it/forum/viewtopic.php?f=2&t=84076#p887687 RenzoDF 2021-05-17T11:43:41Z 2021-05-17T11:43:41Z
Il metodo e la parte simbolica sono corrette, ma ti consiglio di rideterminare la soluzione numerica. ;-)
Circuito in regime stazionario https://www.electroyou.it/forum/viewtopic.php?f=2&t=84076#p887680 Klaudijus 2021-05-17T11:15:10Z 2021-05-17T11:15:10Z
Salve a tutti,
Vorrei che qualcuno mi correggesse questo esercizio perchè ho dei dubbi sul fatto che abbia seguito il ragionamento giusto:
Ecco il mio procedimento:
Ho inizialmente rischematizzato il circuito nella maniera seguente(anche qui vorrei sapere se il circuito che ho considerato è lo stesso di quello di partenza):
Ho poi applicato il metodo dei potenziali nodali al precedente circuito ponendo u_1 il potenziale del nodo a sinistra, u_2 il potenziale del nodo di destra e il nodo in cui incidono R_3, R_4 e R_2 lo considero come potenziale di riferimento (u_3= 0)
poi ho considerato le LKC al nodo di sinistra e al nodo di destra e ho
LKC nodo 1 : +i_3 + i_1 - J =0
LKC nodo 2 : -i_1 + J - i_2 - i_4 = 0
sapendo che
i_3 = u_1/R_3
i_2 = -u_2/R_2
ottengo:
mi ricavo u_1 e u_2 ( i quali mi vengono, a meno di errori di calcolo, u_1= 14,73 e u_2=-0,53) e determino poi sia i_3 tramite i_3 = u_1/R_3
e sia la potenza del gen, considerando la convenzione del generatore, tramite la relazione
vorrei sapere se il mio procedimento è giusto. Grazie anticipatamente per la risposta
