[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(bcb78856b338a8cbf503680168788911.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/bcb78856b338a8cbf503680168788911.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/bcb78856b338a8cbf503680168788911.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/bcb78856b338a8cbf503680168788911.png): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(e93a20edf59f1be5b22b7712ef26e3ac.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/e93a20edf59f1be5b22b7712ef26e3ac.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/e93a20edf59f1be5b22b7712ef26e3ac.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/e93a20edf59f1be5b22b7712ef26e3ac.png): No such file or directory
[phpBB Debug] PHP Warning: in file /generate_feed.php on line 295: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3768)
Latest posts from topic “Teorema di Thevenin in regime misto” Latest posts from topic “Teorema di Thevenin in regime misto” on “ElectroYou”. 2021-12-21T20:55:12Z https://www.electroyou.it/forum/viewtopic.php?f=2&t=85519 Re: Teorema di Thevenin in regime misto https://www.electroyou.it/forum/viewtopic.php?f=2&t=85519#p908565 IsidoroKZ 2021-12-25T08:24:11Z 2021-12-25T08:24:11Z
Pioveva a dirotto, diluviava!
Re: Teorema di Thevenin in regime misto https://www.electroyou.it/forum/viewtopic.php?f=2&t=85519#p908562 claudiocedrone 2021-12-25T03:14:36Z 2021-12-25T03:14:36Z
?% Vergognarti sulla spiaggia di Santa Barbara? Dai su Foto UtenteIsidoroKZ per un mero fattore 3 non meriti di autopunirti in modo così efferato (:OO:)
Re: Teorema di Thevenin in regime misto https://www.electroyou.it/forum/viewtopic.php?f=2&t=85519#p908316 IsidoroKZ 2021-12-22T18:14:23Z 2021-12-22T18:14:23Z
Grazie! Mi sono perso il fattore 3 per strada :( vado a vergognarmi sulla spiaggia di Santa Barbara :D :D
Re: Teorema di Thevenin in regime misto https://www.electroyou.it/forum/viewtopic.php?f=2&t=85519#p908309 MARCODALUCCA 2021-12-22T17:03:27Z 2021-12-22T17:03:27Z
grazie RenzoDF : siete tutti molto gentili e disponibili . Spero di non aver abusato della vostra gentilezza.
Re: Teorema di Thevenin in regime misto https://www.electroyou.it/forum/viewtopic.php?f=2&t=85519#p908306 RenzoDF 2021-12-22T16:59:06Z 2021-12-22T16:59:06Z
Visto che Isidoro a quest'ora sta dormendo, partendo da v1 avremo che sull'induttore ci sarà una tensione 3v1 e di conseguenza la corrente attraverso L sarà -j3v1 che, sommata a quella attraverso il resistore, pari a v1/1, fornirà la corrente attraverso C e di conseguenza avremo vC=(-j)(v1/1-j3v1) e quindi la
[unparseable or potentially dangerous latex formula];
e
i_1=\frac{j3}{2+j}
di conseguenza hai ragione tu.
Re: Teorema di Thevenin in regime misto https://www.electroyou.it/forum/viewtopic.php?f=2&t=85519#p908295 MARCODALUCCA 2021-12-22T16:22:08Z 2021-12-22T16:22:08Z
scusa Isidorokz,
ma io ho rifatto i calcoli con i fasori ok per la componente continua della corrente ma per la componente alternata ho una sinusoide (coseno) di ampiezza \frac{3}{\sqrt{5}} e non \frac{1}{\sqrt{5}} :potresti controllare i tuoi calcoli? grazie
Re: Teorema di Thevenin in regime misto https://www.electroyou.it/forum/viewtopic.php?f=2&t=85519#p908214 IsidoroKZ 2021-12-21T23:17:11Z 2021-12-21T23:17:11Z
Si`, qualcosa del genere, se usi i fasori bisogna fare i conti separatamente per continua e per la sinusoide.
L'impedenza di uscita vale \frac{3R}{1+sCR} e quindi il circuito equivalente diventa
Il conto in continua e` immediato: l'induttanza, come giustamente hai detto, e` un cortocircuito, la capacita` un circuito aperto e V", la parte che dipende da I=1A diventa per s=0 (in continua) V"=3 R I quidi 3V diviso 3Ω fa proprio 1A.
Il conto per la parte in alternata e` piu` complicato, bisogna prendere il valore di [unparseable or potentially dangerous latex formula] indicato prima e dividerlo per l'impedenza complessiva, [unparseable or potentially dangerous latex formula] e si ottiene la funzione di trasferimento fra V' e la corrente in L
Il risultato letterale viene (non e` da farsi cosi`, meglio mettere i numeri subito, ma una volta tanto si puo` fare)
Nell'ultimo passaggio mi sono perso un 3 a numeratore. Il risultato e` V \frac{3}{s^2 L C R+s L+3R}
se si sostituiscono i valori dei componenti, e ad s si sostituisce \text{j}\omega e poi \omega=1\,\text{rad/s} si ha
Nel seguito mancava sempre lo stesso fattore, che ora ho corretto :(
[unparseable or potentially dangerous latex formula] da cui
[unparseable or potentially dangerous latex formula] quindi la corrente nell'induttanza e` pari alla tensione V divisa per \frac{3}{|2+\text{j}|\Omega} quindi \frac{3\text{V}}{\sqrt{5}\,\Omega}=1.34\text{A} e ha un ritardo di fase pari a [unparseable or potentially dangerous latex formula]
Re: Teorema di Thevenin in regime misto https://www.electroyou.it/forum/viewtopic.php?f=2&t=85519#p908192 MARCODALUCCA 2021-12-21T21:17:45Z 2021-12-21T21:17:45Z
si i fasori li ho fatti. comunque da tutte le repliche che ho avuto incluse le tue ho capito che :
per applicare il teorema di Thevenin debbo calcolare 2 circuiti equivalenti uno in DC e uno in AC : in uno ho un generatore equivalente sinusoidale( di pari pulsazione al generatore di tensione indipendente sinusoidale) la cui tensione, utilizzando i fasori, è la tensione a vuoto dopo aver azzerato il generatore di corrente da 1 A ; infine qui inserisco in serie una impedenza calcolata dopo aver azzerato entrambi i 2 generatori indipendenti e inserito un generatore di tensione sinusoidale unitario: da questo circuito equivalente collego l'induttanza L e determino la componente alternata della corrente i ; lo stesso faccio con un il circuito equivalente in Dc dove trovo un generatore indipendente equivalente di 3V e una resistenza equivalente in seriedi 3 ohm : collego l'induttanza, che in continua è un corto, e calcolo la corrente come componente in continua esattamente 1 A.
sommo i due valori e ottengo la corrente i che scorre in L
Re: Teorema di Thevenin in regime misto https://www.electroyou.it/forum/viewtopic.php?f=2&t=85519#p908190 IsidoroKZ 2021-12-21T21:00:07Z 2021-12-21T21:00:07Z
Pero` i fasori e i numeri complessi li hai fatti, altrimenti quel problema non e` risolvibile.
Con Laplace e` piu` semplice che con i fasori: al posto di jw si usa la variabile s, e la j torna in campo solo alla fine dei conti!
Re: Teorema di Thevenin in regime misto https://www.electroyou.it/forum/viewtopic.php?f=2&t=85519#p908188 MARCODALUCCA 2021-12-21T20:55:12Z 2021-12-21T20:55:12Z
mi parli del dominio di Laplace ...non sono ancora arrivato a quel capitolo..
