[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(777baf72597ecfeb8c82c16d3e100113.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/777baf72597ecfeb8c82c16d3e100113.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/777baf72597ecfeb8c82c16d3e100113.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/777baf72597ecfeb8c82c16d3e100113.png): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(8fb4cef1f8ebb40ca7c19f30aab2212a.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/8fb4cef1f8ebb40ca7c19f30aab2212a.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/8fb4cef1f8ebb40ca7c19f30aab2212a.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/8fb4cef1f8ebb40ca7c19f30aab2212a.png): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(07c7c3fbfd4b37b498e787fa51db6a1d.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/07c7c3fbfd4b37b498e787fa51db6a1d.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/07c7c3fbfd4b37b498e787fa51db6a1d.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/07c7c3fbfd4b37b498e787fa51db6a1d.png): No such file or directory
[phpBB Debug] PHP Warning: in file /generate_feed.php on line 295: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3768)
Latest posts from topic “analisi nodale circuito rlc” Latest posts from topic “analisi nodale circuito rlc” on “ElectroYou”. 2024-01-25T14:31:12Z https://www.electroyou.it/forum/viewtopic.php?f=2&t=89798 Re: analisi nodale circuito rlc https://www.electroyou.it/forum/viewtopic.php?f=2&t=89798#p963000 Madara02 2024-01-27T19:37:26Z 2024-01-27T19:37:26Z
[quote="RenzoDF"]Scusa ma per errore ho cancellato il tuo messaggio
Poco importa, basta che il contenuto sia comunque arrivato :-)
Ti ringrazio tanto per le informazioni/correzioni che mi hai fornito :D
Re: analisi nodale circuito rlc https://www.electroyou.it/forum/viewtopic.php?f=2&t=89798#p962961 RenzoDF 2024-01-27T12:17:51Z 2024-01-27T12:17:51Z
Ad ogni modo, rispondo alle domande che avevi posto.
...ci è stata fornita questa spiegazione su come trattare le lk e inserirle in forma matriciale.
Scrivere per ogni nodo le conduttanze riferite al nodo da analizzare (tra i nodi in cui si trova) sommarle ai generatori di corrente entranti/uscenti ed eguagliarle a zero. ...
Mah, il mio consiglio è quello di non imparare queste "regolette" mnemoniche, ma usare le relazioni circuitali di base; in questo modo sarà molto più difficile sbagliare. ;-)
...ti chiedo se questa "procedura" è valida anche per i generatori di corrente quando vado ad analizzare il circuito usando il metodo delle maglie e delle correnti di maglia, ho avuto le stesse difficoltà anche in questo altro caso. ...
Certo che sì, spesso, in quel caso, vi insegnano a introdurre come nuove variabili le tensioni ai morsetti dei generatori di corrente, ma non è assolutamente necessario, usando le relazioni che io chiamo "jolly" è possibile legare le correnti di maglia/anello alle correnti impresse dai GIC, come in questo tuo caso, i potenziali alle tensioni dei GIT.
Re: analisi nodale circuito rlc https://www.electroyou.it/forum/viewtopic.php?f=2&t=89798#p962960 RenzoDF 2024-01-27T12:16:51Z 2024-01-27T12:16:51Z
Scusa ma per errore ho cancellato il tuo messaggio #-o
Re: analisi nodale circuito rlc https://www.electroyou.it/forum/viewtopic.php?f=2&t=89798#p962956 RenzoDF 2024-01-27T11:08:48Z 2024-01-27T11:08:48Z
[quote="Madara02"]Ammetto di non capire il mio errore, ...
Scusa, ma prendiamo la tua prima equazione
[quote="Madara02"]... [unparseable or potentially dangerous latex formula]
come la spieghi?
Vuoi forse dire che e1=0 e anche che e3=0? :mrgreen:
E inoltre quel G1 non compromette il legame dimensionale fra i membri della stessa?
[quote="Madara02"] ... premetto che ci è stata data questa spiegazione. ...
Da chi? ... su cosa?
[quote="Madara02"] Come hai trovato quelle 3 equazioni? non capisco
Semplicemente osservando che, in presenza di generatori di tensione, nel metodo dei potenziali nodali, senza andare ad introdurre altre correnti incognite, si possono usare le tensioni di questi generatori per scrivere il legame fra i potenziali dei due nodi sui quali insistono.
Re: analisi nodale circuito rlc https://www.electroyou.it/forum/viewtopic.php?f=2&t=89798#p962919 Madara02 2024-01-26T19:13:36Z 2024-01-26T19:13:36Z
Ammetto di non capire il mio errore, premetto che ci è stata data questa spiegazione.
forse ho capito, hai direttamente gestito i generatori?
Re: analisi nodale circuito rlc https://www.electroyou.it/forum/viewtopic.php?f=2&t=89798#p962916 RenzoDF 2024-01-26T18:50:03Z 2024-01-26T18:50:03Z
[quote="Madara02"]... ho trovato le seguenti equazioni:
[unparseable or potentially dangerous latex formula] ...
Scusa ma, premesso che non le capisco proprio, queste tre relazioni sono già errate dal punto di vista dimensionale, non credi?
Io direi che, assunto come riferimento a zero per i potenziali il nodo 2, ovvero e2=0, scriverei
e_3=-v_c
Re: analisi nodale circuito rlc https://www.electroyou.it/forum/viewtopic.php?f=2&t=89798#p962911 Madara02 2024-01-26T18:29:56Z 2024-01-26T18:29:56Z
Okay, Allora darò del Tu :D .
In ogni caso, ho contato 4 nodi e messo e2=0, inoltre ho eliminato Vg e R4(non sono totalmente sicuro di Vg, l'ho fatto perchè ho considerato entrambi collegati ad un circuito aperto)
e ho trovato le seguenti equazioni:
Ci è stato detto di considerare condensatore e induttore come due generatori indipendenti di tensione e corrente, ho trattato il condensatore come un generatore di tensione(il Vc della seconda riga della matrice che ho inviato nel precedente messaggio), ho ottenuto la seguente matrice:
MC=[G1, -G1, 0;
-G1, G1+G2, -G2;
0, -G2, G2+G3]
TN=[0, 0, Ig+il].
per quanto riguarda la gestione dei generatori di tensione, ho usato questo metodo:
Identificare nodi a e b a cui è connesso dove:
• a è il terminale positivo
• b è il terminale negativo
per la matrice MC, considerare la:
• riga a
• riga b
sommare i valori di b in a e annullare b(lo stesso per TN)
inserendo in b=-1, a=+1
lo stesso procedimento vale per i gen. controllati, ma inserire "+a" e "-a" a seconda del verso e azzerare la riga di TN;
Così ho ottenuto la matrice "r" che ho inviato sopra, ho provato una versione in cui non eliminavo Vg (perchè incerto se farlo o meno) ma il risultato non cambiava molto.
Re: analisi nodale circuito rlc https://www.electroyou.it/forum/viewtopic.php?f=2&t=89798#p962782 RenzoDF 2024-01-25T15:06:25Z 2024-01-25T15:06:25Z
Devi solo spiegarci come hai fatto a ottenere quella matrice. ;-)
... scrivendo le tue tre relazioni fra i tre potenziali incogniti.
BTW Qui non c'è nessun Lei, siamo tutti Tu :!:
Re: analisi nodale circuito rlc https://www.electroyou.it/forum/viewtopic.php?f=2&t=89798#p962781 Madara02 2024-01-25T14:56:41Z 2024-01-25T14:56:41Z
Salve Renzo, grazie per aver risposto, Potrebbe mostrarmi la sua risoluzione? se vuole mando la mia.
Comunque, anch'io ho scelto come nodo di riferimento il polo positivo del generatore di tensione, ma non capisco dove abbia sbagliato o nella gestione del generatore di tensione controllato o nella manipolazione della matrice d'incidenza.
Credo proprio che mi stia sfuggendo qualcosa
Re: analisi nodale circuito rlc https://www.electroyou.it/forum/viewtopic.php?f=2&t=89798#p962777 RenzoDF 2024-01-25T14:31:12Z 2024-01-25T14:31:12Z
Premesso che non capisco quale sia la tua scelta per i nodi, direi che è semplice intuire quale sia stata la scelta usata nella soluzione, in quanto, assunti entrambi i deviatori nelle posizioni 2, è evidente che il nodo di riferimento a zero sia stato assunto sul morsetto positivo del generatore dipendente, il nodo 1 sul morsetto destro di R2, il nodo 2 sul morsetto sinistro di R2 e il nodo 3 sul morsetto sinistro del generatore dipendente.
Comunque la tua matrice è di certo errata, vista la mancanza della conduttanza G2, fondamentale per la tensione del generatore dipendente.
