[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(1df682d7c47bb8509a40054574b7d9a9.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/1df682d7c47bb8509a40054574b7d9a9.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/1df682d7c47bb8509a40054574b7d9a9.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/1df682d7c47bb8509a40054574b7d9a9.png): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(ea7f74be5f1616620464ef7a02060910.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/ea7f74be5f1616620464ef7a02060910.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/ea7f74be5f1616620464ef7a02060910.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/ea7f74be5f1616620464ef7a02060910.png): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(d02beac3500cd206053ff44223e1abe6.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/d02beac3500cd206053ff44223e1abe6.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/d02beac3500cd206053ff44223e1abe6.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/d02beac3500cd206053ff44223e1abe6.png): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(6039bbbcde0d3d9decdbea4cb1ad79af.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/6039bbbcde0d3d9decdbea4cb1ad79af.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/6039bbbcde0d3d9decdbea4cb1ad79af.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/6039bbbcde0d3d9decdbea4cb1ad79af.png): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(e5158e2cf85ae9c2991986f43389b5bb.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/e5158e2cf85ae9c2991986f43389b5bb.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/e5158e2cf85ae9c2991986f43389b5bb.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/e5158e2cf85ae9c2991986f43389b5bb.png): No such file or directory
[phpBB Debug] PHP Warning: in file /generate_feed.php on line 295: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3768)
Latest posts from topic “propagazione in cavo coassiale 28621” Latest posts from topic “propagazione in cavo coassiale 28621” on “ElectroYou”. 2022-03-19T12:05:51Z https://www.electroyou.it/forum/viewtopic.php?f=36&t=86116 Re: propagazione in cavo coassiale 28621 https://www.electroyou.it/forum/viewtopic.php?f=36&t=86116#p915944 Sinuous 2022-03-22T19:28:23Z 2022-03-22T19:28:23Z
Ti consiglierei solo di mettere un po’ d’ordine nei calcoli.
Il valore massimo della tensione totale nel dielettrico risente del cortocircuito a fine linea e sarebbe quindi 2 volte la tensione progressiva nel mezzo 1: analogo discorso per la corrente totale e la corrente progressiva.
Attenzione anche con la soluzione di tipo stazionario, dove V(z), I(z) sono le tensioni lungo la linea e V(0), I(0) sono riferite all’ingresso della linea.
Re: propagazione in cavo coassiale 28621 https://www.electroyou.it/forum/viewtopic.php?f=36&t=86116#p915831 dannywall 2022-03-21T13:32:40Z 2022-03-21T13:32:40Z
Quindi su ho sbagliato? Perché io ho preso la[unparseable or potentially dangerous latex formula] che ho ricavato dal campo...
Re: propagazione in cavo coassiale 28621 https://www.electroyou.it/forum/viewtopic.php?f=36&t=86116#p915830 Sinuous 2022-03-21T13:16:26Z 2022-03-21T13:16:26Z
[quote="Sinuous"]
Il suo valore massimo sarà:
Re: propagazione in cavo coassiale 28621 https://www.electroyou.it/forum/viewtopic.php?f=36&t=86116#p915811 dannywall 2022-03-21T10:08:33Z 2022-03-21T10:08:33Z
[quote="Sinuous"]
Ed esprimendo l’andamento della corrente con riferimento all’interfaccia fra i due mezzi, dove Gamma =1:
il primo massimo di corrente si otterrà a distanza lambda quarti dal riferimento.
cioè dovrei verificare quando [unparseable or potentially dangerous latex formula] sia massimo e quindi considerando fase nulla al Gamma ho che si verifica quando 2kz-\pi=2n\pi e quindi \frac{\pi}{2\beta_0} che in effetti ho controllato ed è pari a\frac{\lambda}{4}
poi dato che il dielettrico è senza perdite la I_{tot}è uguale alla [unparseable or potentially dangerous latex formula] giusto..
Re: propagazione in cavo coassiale 28621 https://www.electroyou.it/forum/viewtopic.php?f=36&t=86116#p915803 Sinuous 2022-03-21T08:24:40Z 2022-03-21T08:24:40Z
Allora, data la corrente in ragione di Gamma per ogni sezione:
propagazione in cavo coassiale 28621 https://www.electroyou.it/forum/viewtopic.php?f=36&t=86116#p915677 dannywall 2022-03-19T12:05:51Z 2022-03-19T12:05:51Z
Un cavo coassiale indefinito in aria, di impedenza Z0=50Ω , viene terminato su un conduttore
elettrico perfetto, e riempito nella parte terminale di lunghezza d con un dielettrico di permittività
εr 1=6 . Sapendo che l'ampiezza massima del campo elettrico totale nel dielettrico è di 2.5 V/m e
che la frequenza di lavoro è 2 GHz, calcolare:
• la minima lunghezza d, non nulla, tale da annullare il flusso di potenza reattiva
all'interfaccia aria-dielettrico;
• l'energia elettromagnetica immagazzinata nel dielettrico;
• la posizione del massimo del campo magnetico nel tratto in aria.
Dati ulteriori: ri=0.7 cm .
ho calcolato i vari parametri...
\beta_0=\frac{40\pi}{3}
z_1=25 \beta_1=\frac{80\pi}{3}
\lambda_0=\frac{c}{f}=0.15
\lambda_1=\frac{lambda_0}{\sqrt[2]{\epsilon_1}}=0.06123
ho descritto tensione e corrente con l'origine sul cc
e la potenza è [unparseable or potentially dangerous latex formula] affinchè sia nullo ho d=\frac{\pi}{2\beta_1}=0.01531m
poi per l'energia...[unparseable or potentially dangerous latex formula]
[unparseable or potentially dangerous latex formula] l'ho considerato dal campo elettrico... cioè ricavo la tensione totale e divido per l'impedenza della linea
\left | E_{tot} \right |_{max}=\left | V^{+} \right |\left | e_t \right |_{max}
e quindi w_e=0.2349pJ
adesso però mi sono bloccato... so la corrente totale nel dielettrico e so che il dielettrico si comporta come un trasformatore a \frac{\lambda}{4} quindi li avrei un circuito aperto e corrente nulla ....a fronte di un circuito aperto il coefficiente di riflessione è 1 e se tipo considero una cosa di questo tipo:[unparseable or potentially dangerous latex formula]
in modulo sarebbe nullo anche perchè al circuito aperto I=0...... come si procede?
essendo in aria il campo non sarebbe uniforme? cioè potrei calcolare H considerando la corrente all'interfaccia [unparseable or potentially dangerous latex formula] ? valutato al raggio interno
