[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(bc98a05e3b14ec02b7c481bbac60c923.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/bc98a05e3b14ec02b7c481bbac60c923.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/bc98a05e3b14ec02b7c481bbac60c923.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/bc98a05e3b14ec02b7c481bbac60c923.png): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(8708ea402fbbe49270dad2da6db63a3d.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/8708ea402fbbe49270dad2da6db63a3d.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/8708ea402fbbe49270dad2da6db63a3d.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/8708ea402fbbe49270dad2da6db63a3d.png): No such file or directory
[phpBB Debug] PHP Warning: in file /generate_feed.php on line 295: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3768)
Latest posts from topic “Continuità funzione in due variabili definita per insiemi” Latest posts from topic “Continuità funzione in due variabili definita per insiemi” on “ElectroYou”. 2022-01-06T20:19:24Z https://www.electroyou.it/forum/viewtopic.php?f=7&t=85640 Re: Continuità funzione in due variabili definita per insiem https://www.electroyou.it/forum/viewtopic.php?f=7&t=85640#p909909 GioArca67 2022-01-09T17:07:19Z 2022-01-09T17:07:19Z
La continuità.
Diamo un'occhiata al dominio.
La funzione vale 0 ovunque risulti y>=(x+1)^2, cioè nella zona bianca più il bordo:
mentre nella zona fucsia vale l'esponenziale "negativa".
Diamo però ora meglio un'occhiata al segno dell'esponente
se y<(x+1)^2 allora y-(x+1)^2<0 e quindi -1/(-|z|) >0 cioè l'esponente è sempre positivo
In tutto il campo di sua esistenza sopra il dominio fucsia essa è monotona e o va a 1 o va ad \infty.
Per la continuità della funzione in un punto nell'intorno dello stesso i limiti da tutte le direzioni devono coincidere, basta che trovi una direzione particolare per cui non avviene ed hai anche trovato la discontinuità.
Poiché nella zona bianca la funzione per definizione vale 0 allora su tutto il bordo y=(x+1)^2 vi è sicuramente una discontinuità in quanto il limite per una qualsiasi direzione dalla zona fucsia non sarà mai 0 (tutti i valori sono compresi fra 1 e \infty).
Al contrario in tutti gli altri punti non del bordo non può esserci discontinuità perché l'esponenziale è una funzione continua come lo è la funzione costante (0).
Il punto in esame (-1,0) appartiene al bordo, la funzione vale 0 per definizione, ma c'è almeno un punto adiacente in cui è diversa da zero e quindi c'è una discontinuità, senza nemmeno scomodare i limiti.
Passare in coordinate polari, anche se in generale corretto, la vedo una complicazione per il modo in cui è definita la funzione.
Il limite direzionale.
dato un vettore normalizzato v={v1,v2} la derivata direzionale è definita come
[unparseable or potentially dangerous latex formula]
allora calcoliamo in (0,-1), se esiste, il
ovvero
che devi risolvere riportandolo ad una forma nota, ad es
\displaystyle \lim_{x \to 0}\frac{e^x-1}{x}=1
Metti in evidenza e^0.5 vedi cosa esce ad esponente e poi moltiplicando e dividendo tutto per \frac{1/\sqrt{2}-t/2}{4+t^2-2t/\sqrt{2}}
ottieni
\displaystyle \lim_{t \to 0}
\frac{1/\sqrt{2}-t/2}{4+t^2-2t/\sqrt{2}}e^{1/2}
\frac{e^{\frac{t/\sqrt{2}-t^2/2}{4+t^2-2t/\sqrt{2}}}-e^{1/2}}{\frac{t/\sqrt{2}-t^2/2}{4+t^2-2t/\sqrt{2}}} = \frac{e^{1/2}}{4\sqrt{2}}
La stessa cosa la ottieni moltiplicando il gradiente della funzione nel punto (0,-1) per il vettore direzione assegnato: [unparseable or potentially dangerous latex formula]
Ora [unparseable or potentially dangerous latex formula] la calcoli tu, sono 2 derivate parziali, per far vedere la tua buona volontà e impegno.
Re: Continuità funzione in due variabili definita per insiem https://www.electroyou.it/forum/viewtopic.php?f=7&t=85640#p909872 PietroBaima 2022-01-08T22:34:42Z 2022-01-08T22:34:42Z
[quote="quapakko"]Continuo però a non capire se procedo bene sia per la continuità che per la derivata direzionale dato il modo in cui è definita la funzione.
direi proprio di no.
Re: Continuità funzione in due variabili definita per insiem https://www.electroyou.it/forum/viewtopic.php?f=7&t=85640#p909871 PietroBaima 2022-01-08T22:33:49Z 2022-01-08T22:33:49Z
Calcola il limite facendo prima una sostituzione in modo che (x,y) tenda a (0,0) e poi passa in coordinate polari, facendo quindi tendere rho a zero.
Re: Continuità funzione in due variabili definita per insiem https://www.electroyou.it/forum/viewtopic.php?f=7&t=85640#p909860 g.schgor 2022-01-08T19:26:41Z 2022-01-08T19:26:41Z
Sicuro dei dati?
Come fa una funzione esponenziale a diventare negativa?
Continuità funzione in due variabili definita per insiemi https://www.electroyou.it/forum/viewtopic.php?f=7&t=85640#p909669 quapakko 2022-01-06T20:19:24Z 2022-01-06T20:19:24Z
Dire se la seguente funzione è continua in (-1,0):
Devo calcolare il limite
Sarei portato a dire subito che questo limite fa 0 (implicando la continuità) perchè per [unparseable or potentially dangerous latex formula], [unparseable or potentially dangerous latex formula] e quindi [unparseable or potentially dangerous latex formula]
L'esercizio continua chiedendo di determinare, se esiste, la derivata direzionale lungo la direzione [unparseable or potentially dangerous latex formula] nel punto [unparseable or potentially dangerous latex formula]. Io ho impostato il limite
lim_{t->0}\frac{e^{-\frac{1}{-t \sqrt 2/2-t^2/2}}}{t} che ancora una volta fa 0 . Continuo però a non capire se procedo bene sia per la continuità che per la derivata direzionale dato il modo in cui è definita la funzione.
