[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(172f4e253d8c48e6f2dcd6560ff83c13.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/172f4e253d8c48e6f2dcd6560ff83c13.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/172f4e253d8c48e6f2dcd6560ff83c13.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/172f4e253d8c48e6f2dcd6560ff83c13.png): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(dfd5958345c802d1532ab856e5789902.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/dfd5958345c802d1532ab856e5789902.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/dfd5958345c802d1532ab856e5789902.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/dfd5958345c802d1532ab856e5789902.png): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(c41403c0d89d9c96f2cd9f04f08b5748.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/c41403c0d89d9c96f2cd9f04f08b5748.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/c41403c0d89d9c96f2cd9f04f08b5748.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/c41403c0d89d9c96f2cd9f04f08b5748.png): No such file or directory
[phpBB Debug] PHP Warning: in file /generate_feed.php on line 295: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3768)
Latest posts from topic “Calcolo frequenza di taglio” Latest posts from topic “Calcolo frequenza di taglio” on “ElectroYou”. 2015-10-29T20:41:26Z https://www.electroyou.it/forum/viewtopic.php?f=1&t=60956 Re: Calcolo frequenza di taglio https://www.electroyou.it/forum/viewtopic.php?f=1&t=60956#p613765 IlGuru 2015-11-15T21:04:39Z 2015-11-15T21:04:39Z
Re: Calcolo frequenza di taglio https://www.electroyou.it/forum/viewtopic.php?f=1&t=60956#p613759 IsidoroKZ 2015-11-15T20:34:12Z 2015-11-15T20:34:12Z
[quote="IlGuru"]...chi mi sa aiutare in una dimostrazione più rigorosa?
Adesso qui puoi trovare una rassegna di metodi per calcolare la resistenza vista guardando nell'emettitore di un BJT.
Re: Calcolo frequenza di taglio https://www.electroyou.it/forum/viewtopic.php?f=1&t=60956#p610867 IlGuru 2015-10-30T15:44:10Z 2015-10-30T15:44:10Z
Grazie innanzitutto per la spiegazione. Queste cose le avevo fatte a scuola 20 anni fa, quando le si fanno a scuola le si imparano a memoria (la resistenza Re sull' emettrtore vista dalla base è uguale ad beta + 1 per Re, ed il discorso reciproco) e se impari a memoria le procedure operative e certe nozioni poi gli esercizi, i compiti, gli esami ecc vengono anche bene, ma non significa che le cose tu le sappia davvero, infatti quando ti fai due domande cercando il perchè delle cose che dai per scontate scopri che non sai un bel nulla, o quasi. Se poi consideriamo che passati 20 anni in cui hai fatto altro molte cose le hai anche dimenticate, capirai i dubbi che ho nelle questioni che pongo sul forum.
Sto ri-studiando le cose che avevo imparato, anche se non mi servono nè nella vita nè nel lavoro che faccio attualmente, perchè questa dopotutto è sempre stata una passione che mi ha accompagnato fin dall'infanzia e che ha guidato la scelta del mio percorso di studi per il diploma.
Il nick che uso qui, mi è stato attribuito in RL sul lavoro, mi accompagna su altri furum ed in altri ambiti ludici.
Se qualcuno pensa che uno sappia tutto per il nome che porta forse il problema è suo, quindi penso che per il momento me lo terrò.
Re: Calcolo frequenza di taglio https://www.electroyou.it/forum/viewtopic.php?f=1&t=60956#p610854 IsidoroKZ 2015-10-30T15:18:22Z 2015-10-30T15:18:22Z
Avendo tolto Thevenin va gia` meglio, ma non e` ancora preciso.
C'e` almeno una mezza dozzina di modi di calcolare questa impedenza, quello che segue e` il piu` diretto.
Prendiamo il circuito iniziale e mettiamo un generatore di prova sull'emettitore, dopo aver spento tutti gli altri generatori indipendenti (parte a sinistra della figura)
Visto che si sta cercando un risultato "nuovo" sul transistore (nuovo nel senso che si suppone di non conoscerlo ancora) e che si tratta di un transistore solo, si sostituisce al transistore il suo circuito equivalente, schema a destra. Il generatore dipendente del transistor rimane vivo e vegeto.
La tensione di prova Vt e` applicata alla serie r_\pi+Z_b dove Zb e` l'impedenza totale collegata alla base. La corrente di base Ib vale I_b=\frac{V_t}{r_\pi+Z_b}. La corrente di base Ib fa scorrere una corrente di collettore Ic pari a I_c=I_b \beta_0=\frac{V_t \beta_0}{r_\pi+Z_b} La somma di queste due correnti da` la corrente di emettitore It, quindi [unparseable or potentially dangerous latex formula] e quindi il rapporto Vt/It che da` l'impedenza di ingresso vista guardando dentro l'emettitore del transistore vale
[unparseable or potentially dangerous latex formula] che si legge "l'impedenza vista guardando nell'emettitore di un transistore e` pari a tutto quello che c'e` sulla base piu` r pigreco il tutto diviso per beta zero piu` 1". Imparata cosi` dal mio prof e sempre utile!
Al posto di un generatore di tensione di test si poteva metterne uno di corrente e trovare la tensione ai suoi capi, ma forse era meno immediato.
PS: ho scelto un verso comodo per le correnti di base e di collettore, in questo modo evito dei segni negativi, basta che le due correnti siano coerenti fra di loro. Ovviamente non c'entra un accidente che siano entranti o uscenti o ancora che il transistore sia pnp o npn.
PS2: hai mai considerato di cambiare nick? Presentandosi come "ilguru" dai l'idea di sapere tutto e anche di piu` :-)
Re: Calcolo frequenza di taglio https://www.electroyou.it/forum/viewtopic.php?f=1&t=60956#p610837 IlGuru 2015-10-30T14:49:35Z 2015-10-30T14:49:35Z
Voglio misurare la resistenza R_{ue1} vista dall'emettitore.
La sostituisco con un generatore di prova Ve
Il generatore Ve eroga una corrente pari ad [unparseable or potentially dangerous latex formula]
Ai capi della serie [unparseable or potentially dangerous latex formula] ho una tensione di -Ve quindi [unparseable or potentially dangerous latex formula]
La resistenza vista dall'emettitore quivale al rapporto fra Ve ed Ie
Re: Calcolo frequenza di taglio https://www.electroyou.it/forum/viewtopic.php?f=1&t=60956#p610704 IlGuru 2015-10-29T22:47:43Z 2015-10-29T22:47:43Z
Grazie Foto UtenteIsidoroKZ, preciso e chiaro come sempre.
Re: Calcolo frequenza di taglio https://www.electroyou.it/forum/viewtopic.php?f=1&t=60956#p610686 IsidoroKZ 2015-10-29T21:39:25Z 2015-10-29T21:39:25Z
Metti sull'emettitore un generatore di test di tensione e calcoli la corrente che esce dal generatore. Il rapporto tensione di prova applicata diviso per la corrente che esce dal generatore da` l'impedenza vista guardando dentro l'emettitore (che e` anche quella di uscita).
Oppure, se prendi per buono il fatto che I_b=\frac{I_e}{\beta_0+1} metti un generatore di prova di corrente sull'emettitore e calcoli la tensione che si forma sull'emettitore. Tensione diviso corrente indovina un po'... da` l'impedenza di ingresso vista guardando nell'emettitore.
Ho usato \beta_0 al posto di h_{fe}, ma e` lo stesso.
Calcolo frequenza di taglio https://www.electroyou.it/forum/viewtopic.php?f=1&t=60956#p610671 IlGuru 2015-10-29T20:41:26Z 2015-10-29T20:41:26Z
Scusate, sto studiando il circuito di figura X.5.1 sul "Manuale di Elettronica e Telecomunicazioni" - Hoepli - Biondo/Sacchi (4 ristampa del lontano '96) (ISBN:88-203-1951-9) e non riesco a trovare una dimostrazione per il fatto che dall'emettitore l'impedenza sulla base viene vista come amplificata di un fattore pari circa ad Hfe.
Lo so che queste sono le basi del BJT, non mi insultate :=)
La porzione di circuito è questa:
Nel punto B in cui analizza il comportamento alle basse frequenze penso che la porzione di modello sia questo:
dice che \tau_{e1}=C_{e1} \times R^*_{e1}
con [unparseable or potentially dangerous latex formula]
Allora, su [unparseable or potentially dangerous latex formula] e R^*_{e1}=R_{e1}  || R_{ue1} d'accordo, ma come si dimostra che [unparseable or potentially dangerous latex formula] ?
[unparseable or potentially dangerous latex formula] è attraversata da I_b e la tensione ai suoi capi vale [unparseable or potentially dangerous latex formula] che ad intuito è equivalente ad una ipotetica R_{ue1} attraversata da I_e con l'approssimazione che I_e = h_{fe} \times I_b
per cui uguagliando la tensione sarebbe [unparseable or potentially dangerous latex formula]
e semplificando I_b
Ma è una spiegazione un pò troppo sportiva, chi mi sa aiutare in una dimostrazione più rigorosa?
