[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(c70e3dd4b2b83e4c523a189bd44fd453.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/c70e3dd4b2b83e4c523a189bd44fd453.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/c70e3dd4b2b83e4c523a189bd44fd453.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/c70e3dd4b2b83e4c523a189bd44fd453.png): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(d25c2700895105bbee150eabc8fe6984.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/d25c2700895105bbee150eabc8fe6984.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/d25c2700895105bbee150eabc8fe6984.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/d25c2700895105bbee150eabc8fe6984.png): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(488fd862bca5e366eba119869f980e97.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/488fd862bca5e366eba119869f980e97.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/488fd862bca5e366eba119869f980e97.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/488fd862bca5e366eba119869f980e97.png): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(feebb261939e3460c8d6851db9219aed.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/feebb261939e3460c8d6851db9219aed.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/feebb261939e3460c8d6851db9219aed.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/feebb261939e3460c8d6851db9219aed.png): No such file or directory
[phpBB Debug] PHP Warning: in file /generate_feed.php on line 295: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3768)
Latest posts from topic “Transitorio del primo ordine” Latest posts from topic “Transitorio del primo ordine” on “ElectroYou”. 2016-10-17T20:37:47Z https://www.electroyou.it/forum/viewtopic.php?f=2&t=66227 Re: Transitorio del primo ordine https://www.electroyou.it/forum/viewtopic.php?f=2&t=66227#p674300 g.schgor 2016-10-18T15:13:42Z 2016-10-18T15:13:42Z
Scusa, ho ricontrollato l'andamento di [unparseable or potentially dangerous latex formula] per t>0:
tutto OK.
Re: Transitorio del primo ordine https://www.electroyou.it/forum/viewtopic.php?f=2&t=66227#p674298 pietro1990 2016-10-18T15:06:58Z 2016-10-18T15:06:58Z
In che senso la differenza?Nella condizione iniziale [unparseable or potentially dangerous latex formula] mi trovo come lei
Re: Transitorio del primo ordine https://www.electroyou.it/forum/viewtopic.php?f=2&t=66227#p674253 pietro1990 2016-10-18T10:05:59Z 2016-10-18T10:05:59Z
Si ha ragione mi scusi. Avrei quindi [unparseable or potentially dangerous latex formula]
Re: Transitorio del primo ordine https://www.electroyou.it/forum/viewtopic.php?f=2&t=66227#p674250 g.schgor 2016-10-18T09:52:37Z 2016-10-18T09:52:37Z
Nelle espressioni del fasore e del seno,
\varphi deve essere in radianti!
Re: Transitorio del primo ordine https://www.electroyou.it/forum/viewtopic.php?f=2&t=66227#p674243 pietro1990 2016-10-18T09:31:23Z 2016-10-18T09:31:23Z
Se intende numericamente ho considerato tutto in gradi, passando in radianti mi trovo -0,166. Oppure non è corretto lo svolgimento?
Re: Transitorio del primo ordine https://www.electroyou.it/forum/viewtopic.php?f=2&t=66227#p674242 g.schgor 2016-10-18T09:25:15Z 2016-10-18T09:25:15Z
Non capisco come tu abbia calcolato l'angolo del fasore I_L.
(dovrebbe essere -0.166 rad. quindi con una differenza di \pi)
Transitorio del primo ordine https://www.electroyou.it/forum/viewtopic.php?f=2&t=66227#p674170 pietro1990 2016-10-17T20:37:47Z 2016-10-17T20:37:47Z
Salve, avrei bisogno di una mano con questo esercizio non se il procedimento che ho utilizzato è corretto.Determinare iL(t) per t<0 e t>0 , sapendo che l'interruttore si apre in t=0, R1=R2=5, R3=10, L=0,002H, J=30 A ,e(t)=220sin(314t)
Per t<0 ho applicato il principio di sovrapposizione degli effetto, iL(t)= iLe(t)+iLj(t)
Z1=Z2=5 ,Z3=10 ,ZL=jWL=0,628J. Posto Zs=Z2+Z3=15 ,ho calcolato [unparseable or potentially dangerous latex formula] = \frac {220}{5+0,626j} = 43,3-5,45j .A questo punto ho calcolato I_{L}=I1\cdot \frac {Z_S}{Z_L+Z_S} = [unparseable or potentially dangerous latex formula] = 43-7,2J = S=43,6 e^{-9,6J} ,da cui [unparseable or potentially dangerous latex formula]
Ho ricavato I_L=iJ\cdot \frac {R_3}{R_3+R_2} = 30\cdot \frac {10}{10+15} = 30 A . Per cui [unparseable or potentially dangerous latex formula], e la cond. inziale [unparseable or potentially dangerous latex formula].
Per t>0
Ho applicato Norton
Ricavando
R_N=R_1+R_2=15
I_2=J \cdot \frac {R_3}{R_3+R_2} =20A
Per cui [unparseable or potentially dangerous latex formula] , con [unparseable or potentially dangerous latex formula] e [unparseable or potentially dangerous latex formula] , con 7500=\frac {1} T_{au} .Posto [unparseable or potentially dangerous latex formula] , ho ricavato K=-7,3 da cui [unparseable or potentially dangerous latex formula] per t>0
