[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(5bbd079a44235989ee502aa6ed1930cd.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/5bbd079a44235989ee502aa6ed1930cd.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/5bbd079a44235989ee502aa6ed1930cd.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/5bbd079a44235989ee502aa6ed1930cd.png): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(d730d7f9b681b0ef0d4f3e280b32b11d.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/d730d7f9b681b0ef0d4f3e280b32b11d.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/d730d7f9b681b0ef0d4f3e280b32b11d.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/d730d7f9b681b0ef0d4f3e280b32b11d.png): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(6b078d06a91733ccf3d032c02cbdf0c2.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/6b078d06a91733ccf3d032c02cbdf0c2.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/6b078d06a91733ccf3d032c02cbdf0c2.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/6b078d06a91733ccf3d032c02cbdf0c2.png): No such file or directory
[phpBB Debug] PHP Warning: in file /generate_feed.php on line 295: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3768)
Latest posts from topic “Circuito dinamico del secondo ordine - evoluz.libera” Latest posts from topic “Circuito dinamico del secondo ordine - evoluz.libera” on “ElectroYou”. 2017-08-26T16:50:37Z https://www.electroyou.it/forum/viewtopic.php?f=2&t=70506 Re: Circuito dinamico del secondo ordine - evoluz.libera https://www.electroyou.it/forum/viewtopic.php?f=2&t=70506#p726106 Carlo1 2017-08-27T08:17:45Z 2017-08-27T08:17:45Z
Ho capito la metodologia che usi, molto scorrevole.
Grazie :ok:
Re: Circuito dinamico del secondo ordine - evoluz.libera https://www.electroyou.it/forum/viewtopic.php?f=2&t=70506#p726084 IsidoroKZ 2017-08-26T20:48:09Z 2017-08-26T20:48:09Z
Evviva! Ho una tastiera e un mouse a disposizione :-)
Per questo genere di problemi uso questo metodo per scrivere le equazioni differenziali.
Comincio con scrivere una equazione per ogni elemento reattivo, con la derivata di i per le induttanze e quella di v per i condensatori.
Le tensioni sui condensatori e le correnti attraverso gli induttori sono le variabili di stato, le variabili importanti, le nostre incognite "vere"
Qui ci sono solo due elementi reattivi, e` facile
L\frac{\text{d}i_L}{\text{d}t}= \text{tensione su L}
C\frac{\text{d}v_C}{\text{d}t}=\text{corrente attraverso C}
Poi scrivo i termini destri delle equazioni, usando solo le tensioni sui condensatori e le correnti negli induttori, ed eventualmente le sorgenti di ingresso (in questo caso non ci sono).
Il circuito e` questo, in cui ho eliminato tutte le grandezze ripetute e ridondanti.
Nota che ho girato il verso della corrente su L in modo da usare le equazioni di L e C come utilizzatore (la corrente entra nel positivo).
La tensione ai capi dell'induttanza, il termine destro della prima equazione, la si ottiene con una KVL, scritta solo usando come variabili iL e vC vale quindi
L\frac{\text{d}i_L}{\text{d}t}=-R_si_L-v_C
La corrente attraverso il condensatore la si trova con una KCL, sempre usando solo le stesse variabili di prima.
C\frac{\text{d}v_C}{\text{d}t}=i_L-\frac{v_C}{R_u}
Eventualmente si possono spostare a destra i coefficienti delle derivate, in modo da avere a sinistra solo le derivate da sole
\frac{\text{d}i_L}{\text{d}t}=-\frac{R_s}{L}i_L-\frac{1}{L}v_C
\frac{\text{d}v_C}{\text{d}t}=\frac{1}{C}i_L-\frac{1}{R_uC}v_C
Le ho scritte in "forma matriciale" pronte per essere messe ad esempio in matlab con la matrice dei coefficienti gia` ordinata.
Se invece devi risolvere a mano, usando solo vC, puoi cominciare ad eliminare iL (non la sua derivata) dalla prima eq. Oppure meglio, mentre scrivi il termine di destra dell'equazione in diL/dt non usi iL. Il risultato e` lo stesso
[unparseable or potentially dangerous latex formula]
Poi si deriva la seconda equazione rispetto al tempo e sostituire la derivata di iL con il valore dato dalla prima equazione equazione che a questo punto contiene solo vC e la sua derivata.
Le trasformate di Laplace... un'altra volta :-)
Re: Circuito dinamico del secondo ordine - evoluz.libera https://www.electroyou.it/forum/viewtopic.php?f=2&t=70506#p726076 IsidoroKZ 2017-08-26T19:31:39Z 2017-08-26T19:31:39Z
Adesso mi pare a posto.
Re: Circuito dinamico del secondo ordine - evoluz.libera https://www.electroyou.it/forum/viewtopic.php?f=2&t=70506#p726066 Carlo1 2017-08-26T18:11:07Z 2017-08-26T18:11:07Z
Ho mancato la derivata di un fattore.
Aggiustando, ottengo:
Sono andato di fretta, penso che sia giusto. Non so.
Re: Circuito dinamico del secondo ordine - evoluz.libera https://www.electroyou.it/forum/viewtopic.php?f=2&t=70506#p726063 Carlo1 2017-08-26T18:02:20Z 2017-08-26T18:02:20Z
Grazie per le dritte.
Aspetto la sua risposta.
Rifaccio e riposto poiché forse ho capito l'errore.
Re: Circuito dinamico del secondo ordine - evoluz.libera https://www.electroyou.it/forum/viewtopic.php?f=2&t=70506#p726050 IsidoroKZ 2017-08-26T17:27:29Z 2017-08-26T17:27:29Z
Il coefficiente (L/RU+RS/RU+1) non va bene. Stai sommando un tempo a due valori adimensionati.
Scrivi molto bene le derivate con la d in tondo, non in corsivo! Lo fanno in pochi! Potresti migliorare la leggibilità usando anche i pedici, R_s, V_{R_S}.
Se usi meno nomi per le variabili, per esempio i1 che è uguale ad iL... fai meno passaggi e meno errori.
Ora sono sul tablet, appena riesco a mettere le mani su una tastiera vera, provo a raccontare come scrivo io queste equazioni.
Circuito dinamico del secondo ordine - evoluz.libera https://www.electroyou.it/forum/viewtopic.php?f=2&t=70506#p726044 Carlo1 2017-08-26T16:50:37Z 2017-08-26T16:50:37Z
Buongiorno ragazzi, volevo postarvi questo esercizio dove determino l'equazione differenziale lineare omogenea del circuito.
Volevo sapere se fosse stata determinata bene.
1)Scrivo LKT alle due maglie fondamentali e LKC al nodo estremo superiore:
Maglia 1: [unparseable or potentially dangerous latex formula]
Maglia 2:[unparseable or potentially dangerous latex formula]
Nodo: [unparseable or potentially dangerous latex formula] --> [unparseable or potentially dangerous latex formula]
2)Voglio scrivere l'equazione in funzione dell'incognita grandezza di stato vc(t) del condensatore, quindi a partire dalla lkt scritta alla maglia 1 e sostituendo le relazioni caratteristiche dei bipoli in quest'ultima, ottengo:
Sapendo che: [unparseable or potentially dangerous latex formula] , [unparseable or potentially dangerous latex formula] e sfruttando che [unparseable or potentially dangerous latex formula]
ottengo:
Vi trovate ? Grazie in anticipo.
