[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(8723ec5ee73bcd7e9bb5989607fc7f0e.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/8723ec5ee73bcd7e9bb5989607fc7f0e.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/8723ec5ee73bcd7e9bb5989607fc7f0e.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/8723ec5ee73bcd7e9bb5989607fc7f0e.png): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(9a9a01eed8a5a5ab2d7372dd0fa18af8.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/9a9a01eed8a5a5ab2d7372dd0fa18af8.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/9a9a01eed8a5a5ab2d7372dd0fa18af8.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/9a9a01eed8a5a5ab2d7372dd0fa18af8.png): No such file or directory
[phpBB Debug] PHP Warning: in file /generate_feed.php on line 295: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3768)
Latest posts from topic “quantità di moto e oscillazione” Latest posts from topic “quantità di moto e oscillazione” on “ElectroYou”. 2018-12-08T16:44:48Z https://www.electroyou.it/forum/viewtopic.php?f=14&t=76178 Re: quantità di moto e oscillazione https://www.electroyou.it/forum/viewtopic.php?f=14&t=76178#p799613 venexian 2018-12-23T09:26:56Z 2018-12-23T09:26:56Z
[quote="IlGuru"]Ora è tutto corretto?
Dovrebbe.
Grazie.
Re: quantità di moto e oscillazione https://www.electroyou.it/forum/viewtopic.php?f=14&t=76178#p799458 IlGuru 2018-12-21T15:51:58Z 2018-12-21T15:51:58Z
Re: quantità di moto e oscillazione https://www.electroyou.it/forum/viewtopic.php?f=14&t=76178#p799456 venexian 2018-12-21T15:35:31Z 2018-12-21T15:35:31Z
Mi è stato fatto notare un refuso nel messaggio [7].
La definizione di K è K=\frac{m}{M} come richiesto dall'esercizio, non K=\frac{M}{m} come erroneamente trascritto da me.
Infatti, il risultato è inferiore all'unità, come è giusto aspettarsi con la massa minore al denominatore e qualla maggiore al denominatore.
Chiedo a un moderatore di modificare [7] per maggiore chiarezza.
Re: quantità di moto e oscillazione https://www.electroyou.it/forum/viewtopic.php?f=14&t=76178#p799272 ziomangrovia 2018-12-20T06:52:59Z 2018-12-20T06:52:59Z
Tutto perfettamente chiaro e preciso, come sempre!
Se avessi un professore così all'università sarebbe impossibile non capire.
La mia difficoltà più grossa era nel trovare il rapporto tra le masse, ed in particolare i valori di Q e K , non credo ci sarei mai arrivato, è geniale l'idea.
Re: quantità di moto e oscillazione https://www.electroyou.it/forum/viewtopic.php?f=14&t=76178#p799065 venexian 2018-12-18T15:40:50Z 2018-12-18T15:40:50Z
Scusami zio... sono in ritardo, ma spero che che quello che segue ti possa comunque essere d'aiuto.
Riscrivendo l'esercizio in modo meno pittoresco, ma di più facile comprensione, suonerebbe più o meno così
Due punti materiali di masse diverse M e m, con M>m, sono sospesi allo stesso punto fisso con due connessioni inestensibili di massa trascurabile. Lasciati liberi di muoversi allo stesso istante, da posizione con sospensioni orizzontali, opposte e tese, si scontrano sulla verticale del punto di sospensione con urto perfettamente anelastico, proseguendo la corsa nella direzione posseduta dalla massa maggiore. Si calcoli il rapporto m/M necessario affinché i due punti materiali uniti raggiungano un'altezza massima corrispondente a un angolo si 35° della sospensione con la verticale.
Stabiliamo innanzitutto alcuni punti fermi:
1. Si conserva la quantità di moto
2. Non si conserva l'energia (1)
3. Le due masse si muovono con la stessa velocità (2) fino al loro punto di incontro.
Stabiliamo anche un verso per le velocità al momento dell'urto. Stabilire questo verso è fondamentale per il corretto calcolo della quantità di moto che, al contrario dell'energia, può assumere anche valori negativi. Prendiamo per positivo il verso della velocità della massa maggiore, così sarà positiva anche la velocità dopo l'urto.
Scriviamo qualche formula.
[unparseable or potentially dangerous latex formula]
questa è la formula che stabilisce la conservazione della quantità di moto nel caso di due masse che si urtano in modo perfettamente anelastico. La stessa formula, con la notazione dell'esercizio diventa
dove con v si intende il modulo della velocità (uguale e contraria) delle due masse al momento dell'urto, mentre con V si intende il modulo della velocità di uscita dall'urto. L'ultima formula può riscriversi come
e quindi come
Q=\frac{V}{v}=\frac{M-m}{M+m}
dove con Q si indica il rapporto tra le velocità, che scritto in questa forma assume un aspetto particolarmente elegante. Ricordiamoci ora che l'esercizio ci chiede un altro rapporto (K per semplicità)
K=\frac{m}{M}
Sfruttando l'ultima equazione in quella precedente possiamo scrivere (ancora più elegantemente di prima)
Q=\frac{1-K}{1+K}
e ricavare quindi K come
K=\frac{1-Q}{1+Q}
Vediamo allora di stabilire quanto valga questo rapporto di velocità. Dal moto del pendolo sappiamo che la velocità orizzontale nel punto minimo e stabilita dall'equazione (3)
v_o=\sqrt{2gh}
con ovvio significato dei termini. Nel nostro caso, indicando con l la lunghezza della sospensione, possiamo scrivere le due velocità come (4)
v=\sqrt{2gl}
Possiamo ora fare il rapporto tra le velocità e ottenere Q.
Sostituendo quest'ultima in quella che definisce K si ottiene
La soluzione fornita con l'esercizio è corretta.
(1) Precisiamo che l'energia si conserva sempre. Scrivendo che l'energia non si conserva, si intende dire che non si conserva nell'ambito della cinematica che stiamo adottando. Parte dell'energia si trasforma in energie che esulano dall'ambito preso in considerazione (essenzialmente energia termica) pertanto ci si permette di affermare tale 'non conservazione'.
(2) Si precisa in modulo, perché le velocità vettoriali sono una speculare rispetto all'altra con piano di mezzeria definito da una retta giacente verticale passante per il punto di sospensione, e da un'altra retta perpendicolare che unisce i due punti materiali al momento iniziale della loro corsa.
(3) Equazione che si ottiene dalla conservazione dell'energia nella trasformazione da energia potenziale (gravitazionale) a energia cinetica.
(4) In quanto sempre per la conservazione dell'energia si applica lo stesso principio in (3) e l'altezza raggiunta dopo l'urto è ottenuta dalla semplice equazione trigonometrica [unparseable or potentially dangerous latex formula]
Re: quantità di moto e oscillazione https://www.electroyou.it/forum/viewtopic.php?f=14&t=76178#p798854 IlGuru 2018-12-17T14:33:34Z 2018-12-17T14:33:34Z
Più che altro ti ritrovi di mezzo quella v che andrebbe ricavata dall'energia cinetica di uno dei due quadrumani.
Non sono sicuro del procedimento, ma non si poteva partire dal confronto delle energie potenziali del sistema prima e dopo l'urto?
Io ci ho provato in questo modo ma il risultato non mi torna con quello riportato dall' OP.
Re: quantità di moto e oscillazione https://www.electroyou.it/forum/viewtopic.php?f=14&t=76178#p797966 ziomangrovia 2018-12-09T11:01:39Z 2018-12-09T11:01:39Z
In effetti mi chiedo come mai non abbiano messo Jane ! :mrgreen:
Ottimo spunto!
Allora alla luce delle vostre riflessioni posso affermare che:
m= massa di Tarzan
M= massa del Gorilla
v= velocità di Tarzan
-v= velocità del Gorilla
v_{cm}= velocità del centro di massa relativa ai due corpi
l=lunghezza liana
quindi [unparseable or potentially dangerous latex formula]
Facendo considerazioni energetiche: [unparseable or potentially dangerous latex formula]
da cui v_{cm}=\sqrt{2gh}
per cui posso uguagliare [unparseable or potentially dangerous latex formula]
Poi mi fermo. Devo sviluppare l'espressione e raccogliere i fattori massa?
Re: quantità di moto e oscillazione https://www.electroyou.it/forum/viewtopic.php?f=14&t=76178#p797948 claudiocedrone 2018-12-09T02:10:06Z 2018-12-09T02:10:06Z
[quote="testodellesercizio"]" ...le liane sono allineate con l'orizzontale quando i due iniziano...
[quote="ziomangrovia"] ...non c'e' scritto la partenza dell'oscillazione...
non farti distrarre da Tarzan gorilla e liane (potrei capire da Jane... ) sono semplicemente due pendoli, fatti i disegnini, due pendoli di identica lunghezza appesi al medesimo punto che partono orizzontali uno da destra e uno da sinistra, scendono uno verso l'altro, si incontrano in basso quando raggiungono la verticale unendosi l'uno con l'altro, hanno però massa differente percui il moto della massa congiunta prosegue nella direzione in cui stava andando quello di massa maggiore per fermarsi (poi ovviamente invertirebbe la direzione per continuare la pendolazione ma ciò non interessa minimamente ai fini dell'esercizio come altrettanto ininfluente è se quello di massa maggiore proviene da destra o viceversa) quando raggiunge un angolo di 35° con la verticale...
[quote="ziomangrovia"] ...quando si scontrano di sicuro le loro velocità sono le stesse...
...beh... mi sa che se provavi ad affermare il contrario arrivava lo spirito di Galilei a dirtene quattro :mrgreen:
Re: quantità di moto e oscillazione https://www.electroyou.it/forum/viewtopic.php?f=14&t=76178#p797915 ziomangrovia 2018-12-08T19:00:04Z 2018-12-08T19:00:04Z
[quote="IsidoroKZ"]La partenza dell'oscillazione e` specificata essera dalla stessa altezza, supponi che partano insieme e si scontrino nel punto piu` basso.
quando si scontrano di sicuro le loro velocità sono le stesse e valgono v=\sqrt{2gh}
Re: quantità di moto e oscillazione https://www.electroyou.it/forum/viewtopic.php?f=14&t=76178#p797897 IsidoroKZ 2018-12-08T16:44:48Z 2018-12-08T16:44:48Z
