[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(546641e1ea0c6ee5b9ad733f8e7dd80f.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/546641e1ea0c6ee5b9ad733f8e7dd80f.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/546641e1ea0c6ee5b9ad733f8e7dd80f.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/546641e1ea0c6ee5b9ad733f8e7dd80f.png): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(9e4e9077029537d9603327ebb2f35e2b.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/9e4e9077029537d9603327ebb2f35e2b.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/9e4e9077029537d9603327ebb2f35e2b.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/9e4e9077029537d9603327ebb2f35e2b.png): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(d3f1bd9c7b684a6ae332ce2fbcc0fb8b.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/d3f1bd9c7b684a6ae332ce2fbcc0fb8b.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/d3f1bd9c7b684a6ae332ce2fbcc0fb8b.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/d3f1bd9c7b684a6ae332ce2fbcc0fb8b.png): No such file or directory
[phpBB Debug] PHP Warning: in file /generate_feed.php on line 295: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3768)
Latest posts from topic “Sviluppo in serie” Latest posts from topic “Sviluppo in serie” on “ElectroYou”. 2019-03-30T13:45:04Z https://www.electroyou.it/forum/viewtopic.php?f=7&t=77289 Re: Sviluppo in serie https://www.electroyou.it/forum/viewtopic.php?f=7&t=77289#p809992 PietroBaima 2019-03-31T16:41:02Z 2019-03-31T16:41:02Z
AHHH... adesso ho capito cosa volevi intendere.
Però permettimi di dirti di spiegarti meglio la prossima volta.
Lo sviluppo di una funzione, in serie di Taylor, arrestato al primo termine è:
[unparseable or potentially dangerous latex formula]
forziamo l'uguaglianza, accettando l'errore e riscriviamo il tutto come:
Confrontando questa con l'equazione del campo sul tuo libro:
posso pensare (sbagliando, ma lasciamo perdere) che z+\text{d}z sia x e z sia x_0
per cui posso riscrivere
da cui la (brutta) approssimazione ricavata.
Ricorda che queste cose si possono fare ragionevolmente solo quando il Del si comporta come un vettore.
Re: Sviluppo in serie https://www.electroyou.it/forum/viewtopic.php?f=7&t=77289#p809986 quapakko 2019-03-31T16:03:42Z 2019-03-31T16:03:42Z
Mazzoldi Nigro Voci, Fisica II, ELETTROMAGNETISMO-ONDE, seconda edizione,pag 53.
Re: Sviluppo in serie https://www.electroyou.it/forum/viewtopic.php?f=7&t=77289#p809981 rugweri 2019-03-31T15:31:33Z 2019-03-31T15:31:33Z
Ribadisco quanto già scritto (e ripetuto anche da Foto UtentePietroBaima):
[quote="rugweri"]quando fai riferimento a un libro, è sempre bene citarlo esplicitamente
E aggiungo: prima di dire "non c'entra niente", per favore leggi quello che ti viene proposto. Nessuno qui ha voglia di perdere tempo a scrivere cavolate nè ancor meno ha voglia di far perdere tempo a te, quindi se ti ho scritto di riflettere sulla definizione di derivata direzionale un motivo ci sarà pure :roll:
Re: Sviluppo in serie https://www.electroyou.it/forum/viewtopic.php?f=7&t=77289#p809972 PietroBaima 2019-03-31T14:40:07Z 2019-03-31T14:40:07Z
Mah...
Puoi riportare titolo, autore ed editore del libro, come ti è stato già richiesto?
Re: Sviluppo in serie https://www.electroyou.it/forum/viewtopic.php?f=7&t=77289#p809965 quapakko 2019-03-31T13:42:18Z 2019-03-31T13:42:18Z
Non credo riguardi la derivata direzionale. Si parla esplicitamente di sviluppo in serie!
Re: Sviluppo in serie https://www.electroyou.it/forum/viewtopic.php?f=7&t=77289#p809961 rugweri 2019-03-31T12:56:19Z 2019-03-31T12:56:19Z
Fammi capire, per ottenere la seconda formula praticamente hai diviso i termini della prima per dz? ?%
La spiegazione dell'uguaglianza cui ti riferisci, comunque, risiede nella definizione stessa della derivata direzionale, sulla quale ti invito a ragionare al fine di giungere tu stesso alla risposta al tuo quesito :ok:
Ah, un piccolo appunto: quando fai riferimento a un libro, è sempre bene citarlo esplicitamente, includendo titolo, autore e se necessario edizione ;-)
Re: Sviluppo in serie https://www.electroyou.it/forum/viewtopic.php?f=7&t=77289#p809960 quapakko 2019-03-31T12:37:26Z 2019-03-31T12:37:26Z
Potrei dire che [unparseable or potentially dangerous latex formula]? Anche se per definizione dovrebbe esserci il limite del rapporto incrementale per l'incremento che tende a 0?
Sviluppo in serie https://www.electroyou.it/forum/viewtopic.php?f=7&t=77289#p809881 quapakko 2019-03-30T13:45:04Z 2019-03-30T13:45:04Z
Consideriamo una funzione [unparseable or potentially dangerous latex formula]. Non riesco a capire perchè [unparseable or potentially dangerous latex formula]. Il libro mi riporta che la differenza in questione viene sviluppata in serie arrestandosi al primo termine senza però specificare intorno a quale punto.
