[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(bd00f3e009633d42f858a47fc81d2a3e.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/bd00f3e009633d42f858a47fc81d2a3e.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/bd00f3e009633d42f858a47fc81d2a3e.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/bd00f3e009633d42f858a47fc81d2a3e.png): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(f9f1d41a60d610f5859c45a3c0d5d49b.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/f9f1d41a60d610f5859c45a3c0d5d49b.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/f9f1d41a60d610f5859c45a3c0d5d49b.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/f9f1d41a60d610f5859c45a3c0d5d49b.png): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(66c4dc9d86ef569251ef387b1bf5eae6.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/66c4dc9d86ef569251ef387b1bf5eae6.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/66c4dc9d86ef569251ef387b1bf5eae6.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/66c4dc9d86ef569251ef387b1bf5eae6.png): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(a21bc0d78bb6be56a62e8dcac4884b60.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/a21bc0d78bb6be56a62e8dcac4884b60.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/a21bc0d78bb6be56a62e8dcac4884b60.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/a21bc0d78bb6be56a62e8dcac4884b60.png): No such file or directory
[phpBB Debug] PHP Warning: in file /generate_feed.php on line 295: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3768)
Latest posts from topic “Analisi circuito con opamp e MOSFET” Latest posts from topic “Analisi circuito con opamp e MOSFET” on “ElectroYou”. 2020-01-02T15:41:16Z https://www.electroyou.it/forum/viewtopic.php?f=1&t=79583 Re: Analisi circuito con opamp e MOSFET https://www.electroyou.it/forum/viewtopic.php?f=1&t=79583#p833654 MarkyMark 2020-01-02T20:41:12Z 2020-01-02T20:41:12Z
Perché dici che il condensatore si scarica per t > 6 s? Visto che il MOS si spegne il condensatore si carica di nuovo a 10 V.
Re: Analisi circuito con opamp e MOSFET https://www.electroyou.it/forum/viewtopic.php?f=1&t=79583#p833644 Saraa 2020-01-02T19:21:59Z 2020-01-02T19:21:59Z
Si scusami hai ragione.
Per l'intervallo t>6, considerando le equazioni di prima del metodo asintotico:
il condensatore si sarà scaricato. [unparseable or potentially dangerous latex formula]
la [unparseable or potentially dangerous latex formula] mentre..
La [unparseable or potentially dangerous latex formula] ?
So che il MOS si interdice istantaneamente ma scorre ancora la corrente di drain nel parallelo tra le due resistenze ?
Re: Analisi circuito con opamp e MOSFET https://www.electroyou.it/forum/viewtopic.php?f=1&t=79583#p833642 MarkyMark 2020-01-02T18:29:22Z 2020-01-02T18:29:22Z
Per esempio usando il metodo dei nodi, maglie, Thévenin, Norton, Millman...
Re: Analisi circuito con opamp e MOSFET https://www.electroyou.it/forum/viewtopic.php?f=1&t=79583#p833641 Saraa 2020-01-02T18:23:53Z 2020-01-02T18:23:53Z
Come so che la corrente che scorre in R_D e in R_L sia 0,5mA ?
Re: Analisi circuito con opamp e MOSFET https://www.electroyou.it/forum/viewtopic.php?f=1&t=79583#p833638 MarkyMark 2020-01-02T18:13:19Z 2020-01-02T18:13:19Z
[quote="Saraa"]perché [unparseable or potentially dangerous latex formula]
Basta risolvere il circuito a  0+  1+. Ridisegno
[quote="Saraa"]come trovo che [unparseable or potentially dangerous latex formula]?
Si risolve il circuito supponendo che non ci siano altre variazioni della tensione di ingresso (il condensatore "non sa" che la tensione di ingresso cambierà a t = 6 s) e con condensatore aperto. Ridisegno
[quote="Saraa"]quando risolvo l'intervallo 1<t<6 s il condensatore essendo carico lo considero come un generatore di 10V?
Il condensatore si può considerare come un generatore di 10 V solo per un istante in 1+ : è come se avessi fatto una foto al circuito in 1+ in modo da poter calcolare il valore iniziale di tutte le grandezze.
Re: Analisi circuito con opamp e MOSFET https://www.electroyou.it/forum/viewtopic.php?f=1&t=79583#p833636 Saraa 2020-01-02T17:49:36Z 2020-01-02T17:49:36Z
Re: Analisi circuito con opamp e MOSFET https://www.electroyou.it/forum/viewtopic.php?f=1&t=79583#p833635 Saraa 2020-01-02T17:46:42Z 2020-01-02T17:46:42Z
Perchè [unparseable or potentially dangerous latex formula]
Re: Analisi circuito con opamp e MOSFET https://www.electroyou.it/forum/viewtopic.php?f=1&t=79583#p833634 MarkyMark 2020-01-02T17:36:06Z 2020-01-02T17:36:06Z
[quote="Saraa"]per [unparseable or potentially dangerous latex formula] sarebbe la tensione di uscita qualora l'intervallo 1<t<6 terminasse ? ovvero zero.
Mentre [unparseable or potentially dangerous latex formula] ma come calcolo la corrente che scorre nella R_L? So che in R_1 scorre la corrente di Drain (Il Mosfet ho dimostrato essere in Pinch Off), che poi si divide nei rami di R_D e di R_L.
[quote="Saraa"][unparseable or potentially dangerous latex formula] non è comunque 0?
Per t>6s non saprei come definirla la tensione di uscita...
So che[unparseable or potentially dangerous latex formula].
Comunque dipende sempre dal comportamento del condensatore?
Rispondo a questi due post. Mi sembra di capire che tu abbia qualche difficoltà con il calcolo del valore iniziale delle grandezze del circuito. Si risolve il circuito per t = 1^- \ \mathrm{s}
Si suppone che il circuito sia a regime (corrente nel condensatore pari a zero). Allora si possono calcolare [unparseable or potentially dangerous latex formula]
Si passa a risolvere il circuito un attimo dopo la variazione della tensione di ingresso (t = 1^+ \ \mathrm{s}); I vale 1 mA.
Durante questo passaggio si sa che la tensione ai capi del condensatore non può avere salti mentre le altre grandezze possono anche essere discontinue. Risolvendo il circuito si ha
Si calcolano i valori finali delle grandezze (cioè quei valori che si avrebbero se la tensione di ingresso rimanesse fissa a 2 V). Si può disegnare un circuito equivalente anche per fare questo calcolo. Infatti si sa che il condensatore equivale a un circuito aperto in continua:
Si ha che
La costante di tempo ormai abbiamo capito quanto vale :D
Si possono comporre le espressioni delle due tensioni
valide per
1 \ \mathrm{s} < t < 6 \ \mathrm{s}
Il procedimento è lo stesso per risolvere l'altro transitorio.
Re: Analisi circuito con opamp e MOSFET https://www.electroyou.it/forum/viewtopic.php?f=1&t=79583#p833628 Saraa 2020-01-02T15:51:52Z 2020-01-02T15:51:52Z
Nello svolgimento proposto l'andamento risulta essere questo :?:
Re: Analisi circuito con opamp e MOSFET https://www.electroyou.it/forum/viewtopic.php?f=1&t=79583#p833626 MarcoD 2020-01-02T15:41:16Z 2020-01-02T15:41:16Z
Mi sono stancato di leggere post inconcludenti.
Questo è l'andamento delle tensioni.
Potrebbe anche essere giusto, ma non fidatevi
L'andamento dei transitori è disegnato male, dovrebbero avere la stessa durata.
Chissà se un''anima buona può ridisegnarlo in fidocadj ?
