[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(1bb40b8b961b8e98eb9ccbfa56e58ce5.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/1bb40b8b961b8e98eb9ccbfa56e58ce5.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/1bb40b8b961b8e98eb9ccbfa56e58ce5.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/1bb40b8b961b8e98eb9ccbfa56e58ce5.png): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 278: copy(5569d029951d31ebcd7943ad9652c122.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 298: unlink(/5569d029951d31ebcd7943ad9652c122.dvi): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 299: unlink(/5569d029951d31ebcd7943ad9652c122.ps): No such file or directory
[phpBB Debug] PHP Warning: in file /var/www/ey/web/forum/latexrender/class.latexrender.php on line 300: unlink(/5569d029951d31ebcd7943ad9652c122.png): No such file or directory
[phpBB Debug] PHP Warning: in file /generate_feed.php on line 295: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3768)
Latest posts from topic “Circuito RLC sinusoidale” Latest posts from topic “Circuito RLC sinusoidale” on “ElectroYou”. 2024-03-12T23:24:19Z https://www.electroyou.it/forum/viewtopic.php?f=2&t=90035 Re: Circuito RLC sinusoidale https://www.electroyou.it/forum/viewtopic.php?f=2&t=90035#p966074 Madara02 2024-03-18T23:33:34Z 2024-03-18T23:33:34Z
Buonasera,
scrivo solo per comunicare che sono riuscito a risolvere il problema del messaggio precedente.
Vorrei ringraziare sinceramente coloro che hanno prestato attenzione a questo argomento e coloro che hanno risposto, in particolare RenzoDF :D.
Grazie e buona giornata.
Re: Circuito RLC sinusoidale https://www.electroyou.it/forum/viewtopic.php?f=2&t=90035#p965897 Madara02 2024-03-16T16:55:32Z 2024-03-16T16:55:32Z
[quote="RenzoDF"]Io ti parlo ovviamente delle mie metodologie risolutive; le tue non le conosco e non vorrei nemmeno conoscerle, visto le complicazioni che comportano.
Ti capisco benissimo, io stesso vorrei non conoscerle. Sono delle tabelle/procedure indicate come metodo universale/automatico/sistematico per la risoluzione di ogni circuito, ma sto scoprendo che non è così :lol:
queste cose che mi stai dicendo, io non saprei (attualmente) come applicarle.
Colgo l'occasione per chiedere a chiunque legga (nel caso aprirò un altro topic), se disponete di appunti o se potreste indicarmi dei siti, canali youtube o libri di testo in cui vengono spiegate le varie metodologie.
Sperando di trovare qualcosa più simile possibile alle modalità che applico.
[quote="RenzoDF"]Postali pure, se non potrò risponderò io lo farà di certo qualcun altro.
Nella speranza di capire di più
ecco l'altra versione:
Ho scelto e3=0
ottengo
e1=Vcs
[unparseable or potentially dangerous latex formula]
MC=[1,0,0;
-G4+g,G4-g+G3,-G3;
-G2+g,-G3-g,G2+G2]
TN=[Vcs; -Ils; Igs]
Grazie a chiunque risponderà
Re: Circuito RLC sinusoidale https://www.electroyou.it/forum/viewtopic.php?f=2&t=90035#p965841 RenzoDF 2024-03-15T11:16:47Z 2024-03-15T11:16:47Z
[quote="Madara02"]... in pratica non ho capito il motivo per cui si scrive la relazione al nodo 0. ...
Il nodo 0 è un nodo come tutti gli altri, non è che per averlo scelto come riferimento per i potenziali sia escluso dalla possibilità di scrittura di una KCL ma, mentre per le soluzioni fasoriali il condensatore è "visto" come un'ammettenza YC, nella soluzione via circuito resistivo associato, viene "visto" come un generatore ideale di tensione Vcs, ne segue che, ripetendo quanto già più volte sottolineato, sui nodi 1 e 3 relativi ai morsetti del condensatore, non è possibile scrivere delle KCL se non introducendo una nuova variabile, la corrente in Vcs, alle tre incognite e1,e2 ed e3. Ne segue che per "vincere facile", è conveniente scrivere le KCL ai rimanenti nodi 2 e 0.
[quote="Madara02"]... Inoltre non capisco che fine faccia e1-e3=Vcs, ma è collegata sicuramente all'equazione del nodo 0. ...
Quell'equazione sparisce solo nelle matrici fasoriali MZ, non nella matrice MC della dinamica del sistema, per quanto già sopra spiegato, come puoi vedere dal codice.
[quote="Madara02"]... Da ciò che ho capito, è legata alla presenza del generatore controllato...
No, non ha nessun legame con il generatore controllato.
[quote="Madara02"]... Ma non ti nego che la gran parte delle cose che hai scritto è per me estraneo, ho solo tabelle con procedure meccaniche....
Io ti parlo ovviamente delle mie metodologie risolutive; le tue non le conosco e non vorrei nemmeno conoscerle, visto le complicazioni che comportano. :-)
[quote="Madara02"]... Se non ho capito male il metodo dei potenziali nodali (o correnti di maglia) sono una rappresentazione di V=R I, ...
No, i potenziali nodali sostanzialmente sfruttano solo il principio di Kirchhoff alle correnti; ma è chiaro che Ohm si "nasconde" ovunque. :D
[quote="Madara02"]... Ho dei dubbi perché, ho riprovato ad eseguire dei calcoli mettendo come nodo a potenziale nullo il terzo( quello collegato al polo negativo del condensatore/Vcs per intenderci), non ho risolto comunque l'esercizio.
Al solito, ti chiedo se posso inviare i calcoli
Postali pure, se non potrò risponderò io lo farà di certo qualcun altro. ;-)
Re: Circuito RLC sinusoidale https://www.electroyou.it/forum/viewtopic.php?f=2&t=90035#p965807 Madara02 2024-03-14T19:50:44Z 2024-03-14T19:50:44Z
Mi sono preso un bel po' di tempo per rispondere, ho provato a ragionare con alcuni colleghi sulle informazioni che mi hai fornito.
Ovviamente non pretendo risposte, ma chiederò ugualmente delle cose.
Ci sono delle cose che mi sono poco chiare e poi volevo proporti un altro caso.
[quote="RenzoDF"]il problema è che, non essendo nota la corrente nel ramo del GIT, non potremo usare le KCL a quei due nodi se non aggiungendola come ulteriore incognita.
Ne segue che in questo caso potremo scrivere le KCL solo al nodo 2 e al nodo 0, ma potremo però usare la tensione del GIT per la relazione mancante al sistema con le tre incognite, ovvero e1-e3=Vcs.
Ciò che hai scritto dovrebbe essere la teoria/logica dietro quella procedura che applicavo meccanicamente.
Da ciò che ho capito, è legata alla presenza del generatore controllato. Ma non ti nego che la gran parte delle cose che hai scritto è per me estraneo, ho solo tabelle con procedure meccaniche.
Se non ho capito male il metodo dei potenziali nodali (o correnti di maglia) sono una rappresentazione di V=R I, in effetti non ho tutto chiaro riguardo la "gestione dei generatori" e come viene gestita su livello teorico.
[quote="RenzoDF"]Ora, con riferimento a t>0, senza "togliere" nulla e senza usare assurde procedure e tabelle, basterà osservare che il generatore di corrente controllato andrà a modificare le KCL ai nodi 2 e 0 (unici utilizzabili per la loro scrittura nel caso del CRA), e il suo contributo sarà presente sia nel calcolo fasoriale che porta alla componente a regime, sia nel calcolo via CRA per la componente transitoria.
Sei d'accordo?
Le domande e dubbi rimangono gli stessi, ma effettivamente (anche seguendo la tabella che ho allegato sopra) combacia tutto, quindi sì, sono d'accordo.
Al solito, ti chiedo se posso inviare i calcoli (in caso contrario non avrei alcun rancore, tutt'altro), più uno "sfizio" per comprendere meglio.
[quote="RenzoDF"]Per le diverse matrici, ti consiglio di dare un occhio al codice Matlab già postato, che oggi ho leggermente ritoccato.
NB Ad ogni modo, per concludere, ti consiglio anche di rivedere la più semplice via risolutiva che ti ho indicato in quanto, in questo caso particolare, determinate le soluzioni fasoriali e la resistenza vista dall'induttore (2 ohm), il problema era risolto
Ho controllato il codice, stavo studiando il caso-fasoriale per t>0 e ti ringrazio per l'attenzione.
Per quanto riguarda il "metodo più veloce", sto cercando di approfondirlo meglio, anche perché mi servirà nel mio futuro accademico (almeno per ora) :D
Re: Circuito RLC sinusoidale https://www.electroyou.it/forum/viewtopic.php?f=2&t=90035#p965763 RenzoDF 2024-03-14T11:57:14Z 2024-03-14T11:57:14Z
Sei d'accordo? :-)
NB Ad ogni modo, per concludere, ti consiglio anche di rivedere la più semplice via risolutiva che ti ho indicato in quanto, in questo caso particolare, determinate le soluzioni fasoriali e la resistenza vista dall'induttore (2 ohm), il problema era risolto, ovvero da
discendeva direttamente che
e da
via condizione iniziale [unparseable or potentially dangerous latex formula] e quindi \qquad \tau=L/R=1/10 \,\text{ s}
... usando Ahmes, ottenibile in pochissimi minuti :!: :mrgreen:
Re: Circuito RLC sinusoidale https://www.electroyou.it/forum/viewtopic.php?f=2&t=90035#p965748 Madara02 2024-03-13T20:39:01Z 2024-03-13T20:39:01Z
Cerco di unire le informazioni ma penso di esserci
Re: Circuito RLC sinusoidale https://www.electroyou.it/forum/viewtopic.php?f=2&t=90035#p965737 RenzoDF 2024-03-13T17:54:54Z 2024-03-13T17:54:54Z
[quote="Madara02"]... Sì comunque, me ne sono accorto.
Ho inviato il codice perché me l'avevi chiesto tu. ...
Te lo avevo chiesto perché avevo inteso che portasse al risultato corretto e non errato. :-)
[quote="Madara02"]... é la procedura per la gestione del generatore di corrente controllato nel metodo dei potenziali nodali nella matrice, proviene dagli appunti del professore. ...
Incredibile, trovo assurdo quelle procedure a regolette e tabelle che non fanno altro che complicare il discorso.
Detto in sintesi, nel metodo dei potenziali nodali, si vanno ad usare le KCL ma, in presenza di generatori di tensione (come nel caso in oggetto Vcs nel CRA) il generatore va ad imporre la differenza di potenziale fra due punti della rete, in questo caso fra il nodo 1 e il nodo 3 (con le tue scelte di denominazione); il problema è che, non essendo nota la corrente nel ramo del GIT, non potremo usare le KCL a quei due nodi se non aggiungendola come ulteriore incognita.
Scritte queste tre equazioni nelle incognite e1,e2 ed e3, potrai o risolvere il sistema in modo manuale (o via software) oppure scrivere la "matrice delle conduttanze" (anche se non si potrebbe più chiamare in questo modo) e andare ad usarla per risolvere in Matlab come sei abituato a fare.
Fino a qui, mi segui? :-)
Re: Circuito RLC sinusoidale https://www.electroyou.it/forum/viewtopic.php?f=2&t=90035#p965720 Madara02 2024-03-13T11:47:41Z 2024-03-13T11:47:41Z
Eh, purtroppo non so cosa dirti :?
Siamo un bel po' di colleghi in questa situazione "confusa".
Almeno ho scoperto questo forum in cui ho fatto chiarezza su molti argomenti :-)
Re: Circuito RLC sinusoidale https://www.electroyou.it/forum/viewtopic.php?f=2&t=90035#p965708 RenzoDF 2024-03-13T09:33:12Z 2024-03-13T09:33:12Z
Certo ragazzi che ve ne fanno fare di confusione questi "professori". :mrgreen:
Re: Circuito RLC sinusoidale https://www.electroyou.it/forum/viewtopic.php?f=2&t=90035#p965697 Madara02 2024-03-12T23:24:19Z 2024-03-12T23:24:19Z
[quote="RenzoDF"]Ora non ho tempo per commentare tutto, ma solo quello per provare se il codice da te allegato porta ai risultati corretti ... e devo dire che la prova è stata negativa, in quanto porta a risultati scorretti per iL(t) e vC(t); dovresti essertene accorto, no ?
Nessun problema, capisco che non è il momento migliore :-)
E' uguale al codice della mia richiesta iniziale, cambia solo la matrice per t<0 e quel dettaglio nella matrice di t>0.
[quote="RenzoDF"]BTW Non capisco quell'immagine relativa ai generatori controllati? ... a cosa servirebbe ? ... da dove arriva?
Spiegando in breve: é la procedura per la gestione del generatore di corrente controllato nel metodo dei potenziali nodali nella matrice, proviene dagli appunti del professore. Sono state raccolte tutte queste procedure e inserite in un unico pdf per un fattore di comodità.
[quote="RenzoDF"]cosa stai studiando, in che ateneo, con che testo di riferimento?
studio elettrotecnica facoltà di ingegneria informatica, Catania, nessun testo di riferimento, solo slides del professore
