ireon ha scritto:Ma le limitazioni della versione lite quali sarebbero?
Limits
The following limits apply to the Student Version of the products:
PSpice A/D
Circuit simulation is limited to circuits with up to:
64 nodes
10 transistors
65 digital primitive devices
10 transmission lines in total (ideal or non-ideal)
4 pairwise coupled transmission lines.
Additional limits:
The sample library includes 39 analog and 134 digital parts.
Device characterization in the PSpice Model Editor is limited to diodes.
Stimulus generation in the PSpice Stimulus Editor is limited to sine waves (analog) and clocks (digital).
Circuit optimization with the PSpice Optimizer is limited to one goal, one parameter, and one constraint.
You can not create CSDF format data files.
You can only display simulation data from simulations performed with the Student Version of the simulator.
Schematics
You can place a maximum of 50 parts on a schematic design.
You can only draw on size A sheets.
Capture
The PSpice libraries are the only ones included. The standard Capture libraries are not included.
Import facilities, netlisters, and accessories that are not relevant to PSpice are not included.
You can not save a design that contains more than 60 parts. (You can view or create larger designs, but you can not save them.)
You can not save a library that contains more than 15 parts.
Minimum hardware requirements
Intel Pentium 90MHz or equivalent processor
Windows 95, Windows 98 or Windows NT
16MB RAM (32MB recommended)
90MB of free hard disk space
CD-ROM drive
Mouse or similar pointing device
Distributing the Student Version of PSpice
The Student Version of PSpice can be distributed freely -- we encourage it -- providing all copyrights are observed and the software is not redistributed under another name.
Contacting customer support
To obtain assistance with the Student Version of PSpice, you can send questions to our customer support email address: mailto:tech.support@pspice.com
