modifica firmware
ciao a tutti ho realizzato questo circuito trovato sul sito http://picprojects.org.uk/projects/480/pro481/#Description ho notato la velocità con la quale viene eseguita e volevo rallentare i vari giochi ma aprendo il file asm mi sono trovato un sorgente che non capisco, pensavo di trovarmi davanti ad un sorgente tipo basic che in qualche maniera ci avrei provato ad modificare .se riuscite fare qualcosa voi . vi ringrazio
vi allego il sorgente
- Codice: Seleziona tutto
; 8 Channel PWM LED Chaser for PIC 16F628/A *
; Filename: pro481v207.asm *
; Date: 27/10/2010 *
; File Version: 2.0.7 *
; Author: Pete Griffiths *
; Company: http://picprojects.org.uk *
; Written and assmbled under MPLAB Version 8.20 *
; Before assembling code set correct PIC processor in MPLAB *
; from menu option Configure - Select Device *
; Now works with 16F84A, 16F627/628 16F627A/628A and 16F88 *
; The devices with 1K program memory (16F84A, 16F627/627A *
; will need some Sequences in pwmc_SeqData.inc file removing *
; to fit the code in their limited memory. *
; 27/10/2010 *
; PWM LED Chaser variant code for use with PCB480C only *
; Notes: *
; 1. PIC 16F628A datasheet can be downloaded from *
; http://ww1.microchip.com/downloads/en/DeviceDoc/40044b.pdf *
; 2. See also MPASM User Guide(UG) which can be downloaded from: *
; http://ww1.microchip.com/downloads/en/DeviceDoc/33014J.pdf *
; http://picprojects.org.uk/projects/ledchaser/ *
; 3. This code uses Pseudo-instructions listed in the MPASM User *
; guide, Part 4, Appendix A.5 *
; 4. For list of Radix types see MPASM UG Section 3.4, Table 3-3 *
ifdef __16F88
#include <p16f88.inc>
;Program Configuration Register 1
__CONFIG _CONFIG1, _CP_OFF & _CCP1_RB0 & _DEBUG_OFF & _WRT_PROTECT_OFF & _CPD_OFF & _LVP_OFF & _BODEN_ON & _MCLR_ON & _PWRTE_ON & _WDT_OFF & _INTRC_IO
;Program Configuration Register 2
__CONFIG _CONFIG2, _IESO_OFF & _FCMEN_OFF
#define T0IF TMR0IF
#define T0IE TMR0IE
endif
ifdef __16F628A
#include <p16f628A.inc> ; Standard include file
; defines processor specific variable definitions
; See MPASM UG Section 4.41
; '__CONFIG' directive is used to embed configuration data within .asm file.
; The lables following the directive are located in the respective .inc file.
; See respective data sheet for additional information on configuration word.
; and also see MPASM UG Section 4.12
__CONFIG _CP_OFF & _WDT_ON & _PWRTE_ON & _INTRC_OSC_NOCLKOUT & _LVP_OFF
endif
ifdef __16F628
#include <p16f628.inc>
endif
ifdef __16F84A
; **** 16F84A only has 1K of program memory - the default pwm_SeqData.inc file ****
; **** will not fit into the available memory, you must remove some of the ****
; **** the sequence data from the file before assembling the code ****
#include <p16f84a.inc>
__CONFIG _CP_OFF & _WDT_ON & _PWRTE_ON & _HS_OSC
; Code protect off
; Watch Dog timer off
; Power-up timer delay on
; change to _RC_OSC for resistor/capacitor
; change to _XT_OSC for crystal/resonator <3.5Mhz
; change to _HS_OSC for high speed crystal/resonator >3.5Mhz
endif
; Suppress specific warning messages
; see MPASM UG Section 4.29 for errorlevel directive
; see MPASM UG Section 8.4 for assembler message descriptions
errorlevel -302 ; suppress banksel warning messages during assembly
; define variables in General Purpose Register (GPR) memory
; See MPASM UG Section 4.8
; note: 16F84A GPR start at 0x0C but most other mid-range PICs start at 0x20
; We use 0x20 here for compatibilty with newer PICs
cblock 0x20
firstGPR:0 ; mark start of GPR memory used
state ; used by function state selector
copyPORTB ; working variable, holds copy of PORTB
vc0,vc1,vc2,vc3,vc4 ; vertical counter bits
hiReload ; vertical counter reload hi
loReload ; vertical counter reload lo
PWM ; PWM counter
holdTime ; sequence line hold time
repeatCount ; repeat seqeunce count
RandMask ; mask to AND random number with
seqIdxLo ; Lo byte address index pointer to start of selected sequence
seqIdxHi ; Hi byte address index pointer to start of selected sequence
seqTotal ; Total number of sequences in data
seqMatch ; working variable
seqCount ; working variable
forward ; working regsiter for mirroring data
reverse ; working regsiter for mirroring data
reloadTemp ; temporary holding variable for loReload
tick ; timer0 ticks
swTimer ; switch hold down timer
flags ; function flags register
mode ; mode flags register
indexLo ; Lo byte sequence line data address pointer
indexHi ; Hi byte sequence line data address pointer
save_W ; save W during interupt
save_Status ; save STATUS during interupt
save_PCLATH ; save PCLATH
saveModeTimerL ; holdoff timer for saving opmode to EEPROM high
saveModeTimerH ; holdoff timer for saving opmode to EEPROM low
eesave_W ; temp register used in EEPROM routings
LFSRH ; Random number shift regsiter high byte
LFSRL:0 ; Random number shift register low byte
lastGPR ; mark last GPR register used
; (required by GPR initialisation code)
endc
; EEPROM data
; ; program parameters
org 0x2100
de .0
de .1
de .0
; embed firmware release info
de " PRO481 PWM LED Chaser "
de " V2.0.7 "
de " 27/10/2010 "
de " picprojects.org.uk "
; Define bank select pseudo instructions to make code more readable
#define bank0 bcf STATUS,RP0 ; Sel Bank 0
#define bank1 bsf STATUS,RP0 ; Sel Bank 1
; See MPASM UG Secdtion 4.27 for definition of equ directive
switch equ 4 ; Port bit switch connected to
cSAVETIME EQU d'4' ; holdoff timer constant for saving EEPROM data
cTIMER EQU d'157'
cTICKS EQU d'50'
; 4Mhz oscillator clock, gives TMR0 clock = 1Mhz.
; Write to timer0 inhibits clock for 2 clock cycles
; TMR0 prescaler of 1:2 gives
; 1Mhz / ((256-157+2) x 2) = 5Khz = 0.2mS
; 50 x 0.2mS = 10mS
; So the sequence hold time will be 10mS x holdTime, giving a range of
; 1 = 10mS thru 254 = 2.54S
; remember that a holdtime value of 255 indicates the end of the sequence so DON'T USE IT
; define flag bits
fHoldTimeout EQU 0 ; flag set by ISR, cleared by Table Lookup function
fSwitch EQU 1 ; flag
fsetupRun EQU 2 ; 0=run mode / 1=setup mode
fTick EQU 3 ; timer tick flag
fSaveMode EQU 4 ; set indicates opmode needs writing to EEPROM, clear indicates no data to write
; 5
fMirrorData EQU 6 ; flag set, Table read reverses bits in data word [** This flag must be Bit 6 **]
fMirrorNext EQU 7 ; flag tells code current sequence should be mirrored next time
#define canMirror 1<<fMirrorData ; Don't change the position of this bit, sequence data expects it here
; define mode bits
modeSeq EQU 0
modeRan EQU 1
modeMan EQU 2
modeSleep EQU 3
; Program code starts here
; See MPASM UG Section 1.7.1, and Example 1-1
; Labels Mnemonics Operands Comments
; Directives
; Macros
RESET_VECTOR org 0x000 ; see MPASM UG Section 4.50
goto START ; START label is in pwmc_start.inc
INTERRUPT_V org 0x004 ; Interrupt handler code must follow this origin statement
#include pro481_inth.inc ; include Interrupt Handler code block
#include pro481_statef.inc ; include main state function code block (must reside in page 0)
#include pro481_start.inc ; include reset and initialisation code
#include pro481_functions.inc ; include all program functions
#include pro481_SeqMacro.inc ; include MACRO definitions for sequence data
; used for creating sequence data tables
; DO NOT CHANGE OR REMOVE this label
SeqBaseAddr ; label marks base address for start of sequence data.
; Include your sequence data file(s) here
#include pro481_SeqData.inc ; file containg sequence data
;#include pro481_xmastree.inc ; alternate data for use with xmas tree PCB
; Do not remove this instruction
_markLast retlw .255 ; Ensure last sequence is marked
end ; end of instructions, always needed
