Pagina 1 di 3
Super Car 8 LED
MessaggioInviato: 6 giu 2014, 19:39
da Cseven
Salve ,
di seguito vi posto il codice sorgente di un programma in C fatto dalla Microchip sui suoi esempi e ve lo riporto qui per chiedere, perché MPLAB X IDE v2.10 mi da il seguente errore:
(908) exit status = 1
make[2]: *** [build/default/production/super_car.p1] Error 1
super_car.c:34: warning: (374) missing basic type; int assumed
super_car.c:34: error: (314) ";" expected
super_car.c:56: error: (312) ";" expected
make[2]: Leaving directory `D:/ecc..
make[1]: Leaving directory `D:/ecc..
make[1]: *** [.build-conf] Error 2
make: *** [.build-impl] Error 2
BUILD FAILED (exit value 2, total time: 1s)
Codice: Seleziona tutto
/** C O N F I G U R A T I O N   B I T S ******************************/
#pragma config FOSC = INTIO67, FCMEN = OFF, IESO = OFF                       // CONFIG1H
#pragma config PWRT = OFF, BOREN = SBORDIS, BORV = 30                        // CONFIG2L
#pragma config WDTEN = OFF, WDTPS = 32768                                     // CONFIG2H
#pragma config MCLRE = OFF, LPT1OSC = OFF, PBADEN = ON, CCP2MX = PORTC       // CONFIG3H
#pragma config STVREN = ON, LVP = OFF, XINST = OFF                          // CONFIG4L
#pragma config CP0 = OFF, CP1 = OFF, CP2 = OFF, CP3 = OFF                   // CONFIG5L
#pragma config CPB = OFF, CPD = OFF                                         // CONFIG5H
#pragma config WRT0 = OFF, WRT1 = OFF, WRT2 = OFF, WRT3 = OFF               // CONFIG6L
#pragma config WRTB = OFF, WRTC = OFF, WRTD = OFF                           // CONFIG6H
#pragma config EBTR0 = OFF, EBTR1 = OFF, EBTR2 = OFF, EBTR3 = OFF           // CONFIG7L
#pragma config EBTRB = OFF                                                  // CONFIG7H
/** I N C L U D E S **************************************************/
#include "p18f46k20.h"
#include "delays.h"
/** V A R I A B L E S *************************************************/
#pragma udata // declare statically allocated uninitialized variables
unsigned char LED_Number;  // 8-bit variable
/** D E C L A R A T I O N S *******************************************/
// declare constant data in program memory starting at address 0x180
#pragma romdata Lesson3_Table = 0x180
const rom unsigned char LED_LookupTable[8] = {0x01, 0x02, 0x04, 0x08,
                                     0x10, 0x20, 0x40, 0x80};
#pragma code    // declare executable instructions
void main (void)
    LED_Number = 0;            // initialize
    TRISD = 0b00000000;        // PORTD bits 7:0 are all outputs (0)
    while (1)
      // use lookup table to output one LED on based on LED_Number value
        LATD = LED_LookupTable[LED_Number];
        LED_Number++;      // rotate display by 1
        if (LED_Number == 8)
            LED_Number = 0;    // go back to LED 0.
        Delay1KTCYx(50);       // Delay 50 x 1000 = 50,000 cycles; 200ms @ 1MHz
L'HEX file, una volta caricato nel PIC18F45K20 tramite Pickit3 , funziona regolarmente. Mentre se provo a farlo io e a compilarlo , mi da gli errori di prima....sapete aiutarmi?
Grazie mille.
Re: Super Car 8 LED
MessaggioInviato: 6 giu 2014, 19:56
da posta10100
Non uso MPLAB però prova a commentare questa riga:
Secondo me al posto di "declare ..." manca qualcosa.
Però posso sbagliarmi, MPLAB l'ho usato un paio di volte, non mi è piaciuto e l'ho mollato.
Re: Super Car 8 LED
MessaggioInviato: 6 giu 2014, 20:38
da Cseven
Puoi per piacere provare a compilare il programma e vedere se a te funziona?
Re: Super Car 8 LED
MessaggioInviato: 6 giu 2014, 20:58
da posta10100
Non ho il sw installato, dammi il tempo di scaricarlo e di ricordarmi come si usa :mrgreen:
Hai installato librerie particolari o hai fatto l'installazione di default?
Re: Super Car 8 LED
MessaggioInviato: 6 giu 2014, 21:01
da Cseven
Dicevo, se lo avresti fatto con il software che utilizzi tu.
Comunque Mplab, l'ho installato normalmente, tutto default, niente di aggiunto .
Crei il progetto, dopodiché aggiungi un file.c alla cartella Source files che trovi nel software. Questo se vuoi fare la prova con lui.
Non so dove sbattere la testa, e prima di andare avanti stavo cercando di capire come lo ha fatto questo .
Re: Super Car 8 LED
MessaggioInviato: 6 giu 2014, 21:07
da posta10100
Cseven ha scritto:Dicevo, se lo avresti fatto con il software che utilizzi tu.
OK, butto tutto e uso Piklab! :mrgreen:
Re: Super Car 8 LED
MessaggioInviato: 6 giu 2014, 21:13
da Cseven
Ti ringrazio :)
Anche io volevo usare Piklab, ma avevo paura, per modo di dire, nel poterlo usare con il pickit3 . Ma da quello che ho capito finora non c'è grande differenza tra pickit3 e il 2 .
Aspetto una tua risposta. Vediamo se da te parte. Se riesci a compilarlo, butto tutto e passo anche io a Piklab :)
Re: Super Car 8 LED
MessaggioInviato: 6 giu 2014, 21:26
da posta10100
Devo riadattare un po il codice, appena stacco il saldatore lo sistemo e te lo passo.
A dopo!
Re: Super Car 8 LED
MessaggioInviato: 6 giu 2014, 21:32
da Cseven
Grazie mille :) finalmente potrò capirci qualcosa :)
Re: Super Car 8 LED
MessaggioInviato: 6 giu 2014, 22:49
da posta10100
Ecco il codice riadattato.
Per poterlo compilare, oltre a Piklab devi avere anche sdcc.
    #include "pic18f46k20.h"
    //#pragma config FOSC = INTIO67, FCMEN = OFF, IESO = OFF                       // CONFIG1H
    __code char __at __CONFIG1H CONFIG1H = _OSC_INTIO67_1H & _FCMEN_OFF_1H & _IESO_OFF_1H;
    //#pragma config PWRT = OFF, BOREN = SBORDIS, BORV = 30                        // CONFIG2L
    __code char __at __CONFIG2L CONFIG2L = _PWRT_OFF_2L & _BOREN_SBORDIS_2L & _BORV_46_2L;
    //#pragma config WDTEN = OFF, WDTPS = 32768                                     // CONFIG2H
   __code char __at __CONFIG2H CONFIG2H = _WDT_OFF_2H & _WDTPS_32768_2H;
    //#pragma config MCLRE = OFF, LPT1OSC = OFF, PBADEN = ON, CCP2MX = PORTC       // CONFIG3H
   __code char __at __CONFIG3H CONFIG3H = _MCLRE_OFF_3H & _LPT1OSC_OFF_3H & _PBADEN_ON_3H & _CCP2MX_PORTC_3H;
    //#pragma config STVREN = ON, LVP = OFF, XINST = OFF                          // CONFIG4L
   __code char __at __CONFIG4L CONFIG4L = _STVREN_ON_4L & _LVP_OFF_4L & _XINST_OFF_4L;
    //#pragma config CP0 = OFF, CP1 = OFF, CP2 = OFF, CP3 = OFF                   // CONFIG5L
   __code char __at __CONFIG5L CONFIG5L = _CP0_OFF_5L & _CP1_OFF_5L & _CP2_OFF_5L & _CP3_OFF_5L;
    //#pragma config CPB = OFF, CPD = OFF                                         // CONFIG5H
   __code char __at __CONFIG5H CONFIG5H = _CPB_OFF_5H & _CPD_OFF_5H;
    //#pragma config WRT0 = OFF, WRT1 = OFF, WRT2 = OFF, WRT3 = OFF               // CONFIG6L
   __code char __at __CONFIG6L CONFIG6L = _WRT0_OFF_6L & _WRT1_OFF_6L & _WRT2_OFF_6L & _WRT3_OFF_6L;
    //#pragma config WRTB = OFF, WRTC = OFF, WRTD = OFF                           // CONFIG6H
   __code char __at __CONFIG6H CONFIG6H = _WRTB_OFF_6H & _WRTC_OFF_6H & _WRTD_OFF_6H;
    //#pragma config EBTR0 = OFF, EBTR1 = OFF, EBTR2 = OFF, EBTR3 = OFF           // CONFIG7L
   __code char __at __CONFIG7L CONFIG7L = _EBTR0_OFF_7L & _EBTR1_OFF_7L & _EBTR2_OFF_7L & _EBTR3_OFF_7L;
    //#pragma config EBTRB = OFF                                                  // CONFIG7H
   __code char __at __CONFIG7H CONFIG7H = _EBTRB_OFF_7H;
    const unsigned char LED_LookupTable[8] = {0x01, 0x02, 0x04, 0x08,
    //#pragma code    // declare executable instructions
   unsigned char d1, d2;
   void delay() {
     __asm
      ; Delay = 0.2 seconds
      ; Clock frequency = 1 MHz
      ; Actual delay = 0.2 seconds = 50000 cycles
      ; Error = 0 %
   Delay:
         ;49993 cycles
      movlw   0x0E
      movwf   _d1
      movlw   0x28
      movwf   _d2
   Delay_0:
      decfsz   _d1, f
      goto   $+2
      decfsz   _d2, f
      goto   Delay_0
         ;3 cycles
      goto   $+1
      nop
         ;4 cycles (including call)
     __endasm;
    void main (void)
        while (1)
            //Delay1KTCYx(50);       // Delay 50 x 1000 = 50,000 cycles; 200ms @ 1MHz
            delay();
La routine di delay è stata ottenuta riadattando il codice generato con questo calcolatore.
Se hai difficoltà a configurare SDCC dimmelo che ti do una mano.
Su che OS lavori?
