problema IF mplab x pic16
MessaggioInviato: 2 feb 2020, 15:03
da lorenzo01
buongiorno, ho un problema riguardo ad un codice di prova che ho scritto per un pic16f1773 su mplab x con compilatore XC8, sostanzialmente il programma non funziona, anche se compila senza dare errori e il codice viene correttamente scaricato sul mcu dal pickit 3.
precedentemente ho provato a far blinkare un led e tutto funzionava quindi escluderei che sia un problema hardware o dei registri di configurazione posto qui il codice completo:
Codice: Seleziona tutto
#pragma config FOSC = HS        // Oscillator Selection Bits (HS Oscillator, High-speed crystal/resonator connected between OSC1 and OSC2 pins)
#pragma config WDTE = OFF        // Watchdog Timer Enable (WDT enabled)
#pragma config PWRTE = OFF      // Power-up Timer Enable (PWRT disabled)
#pragma config MCLRE = ON       // MCLR Pin Function Select (MCLR/VPP pin function is MCLR)
#pragma config CP = OFF         // Flash Program Memory Code Protection (Program memory code protection is disabled)
#pragma config BOREN = ON       // Brown-out Reset Enable (Brown-out Reset enabled)
#pragma config CLKOUTEN = ON    // Clock Out Enable (CLKOUT function is enabled on the CLKOUT pin)
#pragma config IESO = ON        // Internal/External Switchover Mode (Internal/External Switchover Mode is enabled)
#pragma config FCMEN = ON       // Fail-Safe Clock Monitor Enable (Fail-Safe Clock Monitor is enabled)
#pragma config WRT = OFF        // Flash Memory Self-Write Protection (Write protection off)
#pragma config PPS1WAY = ON     // Peripheral Pin Select one-way control (The PPSLOCK bit cannot be cleared once it is set by software)
#pragma config ZCD = OFF        // Zero-cross detect disable (Zero-cross detect circuit is disabled at POR)
#pragma config PLLEN = OFF       // Phase Lock Loop enable (4x PLL is always enabled)
#pragma config STVREN = ON      // Stack Overflow/Underflow Reset Enable (Stack Overflow or Underflow will cause a Reset)
#pragma config BORV = LO        // Brown-out Reset Voltage Selection (Brown-out Reset Voltage (Vbor), low trip point selected.)
#pragma config LPBOR = OFF      // Low-Power Brown Out Reset (Low-Power BOR is disabled)
#pragma config LVP = ON         // Low-Voltage Programming Enable (Low-voltage programming enabled)
#include <xc.h>
#define _XTAL_FREQ 20000000
#define led PORTCbits.RC4
#define encoder PORTAbits.RA1
void main() {
TRISC = 0b00000000;
TRISA = 0b11111111;
led = 0;
while(1) {
  if(encoder)
     led=1;
il problema sta nella variabile dell if che corrisponde ad un ingresso digitale RA1 collegato ad un encoder ottico non da errori ma non funziona
mentre inserendo 2 dentro le parentesi dell if il led si accende e viceversa inserendo uno 0, quindi mi viene da dire che sbaglio qualcosa nella variabile "encoder"
Re: problema IF mplab x pic16
MessaggioInviato: 2 feb 2020, 15:11
da Paolino
Ciao Foto Utentelorenzo01.
Leggendo il datasheet, è indicato che la porta PORTA è inizialmente imposata come ANALOG, quindi devi dire al micro che la vuoi usare come DIGITAL.
Per far ciò, prima del while(1) devi porre a zero il registro ANSELA:
void main() {
ANSLEA = 0x00;
TRISC = 0b00000000;
TRISA = 0b11111111;
led = 0;
while(1) {
  if(encoder)
     led=1;
Prova e poi facci sapere.
CIao.
Paolo.
MessaggioInviato: 6 feb 2020, 21:16
da lorenzo01
ok configurando correttamente tutti i registri del porto funziona correttamente grazie per la dritta
