Salve
Digisamuel98,
la normativa e la legislazione sui campi elettrici statici (ed in genere a bassa frequenza) riflette il fatto che non ci sono dubbi sull'assenza di effetti sulla salute.
La prassi e quei pochi riferimenti legislativi e normativi sono quindi orientati a minimizzare gli eventuali effetti sensoriali, innocui e reversibili, quali micro-scariche per elettricità statica e percezione/formicolio sui cappelli.
Qui una spiegazione sintetica e dei link di riferimento:
https://www.emf-portal.org/en/cms/page/home/effects/static-fieldsStatic electric fields
If static electric fields are strong enough, the electrical charge of the skin surface is perceptible due to micro-discharges and the movement of hairs, which repel each other and then straighten up. The human sensing threshold is stated in a range from 10 to 45 kV/m (ICNIRP). The only relevant direct health effect of static electric fields known is the possible stress caused by prolonged exposure to microshocks. However, so far no harmful effects could be detected in human and animal laboratory studies (ICNIRP). No direct effects occur inside the body because static electric fields discharge at the surface due to the high conductivity of the body and cannot penetrate the body.
