Libreria rotary con problemi su arduino mega
MessaggioInviato: 12 feb 2023, 22:36
da aduri
Buongiorno a tutti,
devo usare questa libreria per encoder che uso con successo su arduino 1 con questo sw (l'originale e' qui: www.ad7c.com) per gestire un menu di comando per un dds, lo vorrei usare con arduino mega ma non va.
Ho subito pensato ai pins 2 e 3 di interrupt HW e guardando il datasheet del mega ho provato i pins 18 e 19, poi A11 e A12 che corrisponto ai PCINT19 e PCINT20 (definiti in libreria) ma continua a non andare.
Avete qualche idea?
Allego codice:
Codice: Seleziona tutto
Main code by Richard Visokey AD7C - www.ad7c.com
Revision 2.0 - November 6th, 2013
used and midified by IZ1QXJ Antonio
// Include the library code
#include <LiquidCrystal_I2C.h>
#include <rotary.h>
#include <EEPROM.h>
//Setup some items
#define pulseHigh(pin) {digitalWrite(pin, HIGH); digitalWrite(pin, LOW); }
LiquidCrystal_I2C lcd(0x3f, 16, 2);//0x3f o 0x27
int_fast32_t rx=7150000; // Base (starting) frequency of VFO.  This only loads once.  To force load again see ForceFreq variable below.
int_fast32_t rx2=1; // variable to hold the updated frequency
int_fast32_t increment = 10; // starting VFO update increment in Hz.!!!!!!!!!
int_fast32_t iffreq = 4192000; // Intermedite Frequency - Amount to subtract (-) from base frequency. ********************************************
int buttonstate = 0;
int buttonstate2 = 0;
int GoIF = 1;
String hertz = "10 Hz";
int  hertzPosition = 5;
byte ones,tens,hundreds,thousands,tenthousands,hundredthousands,millions ;  //Placeholders
String freq; // string to hold the frequency
int_fast32_t timepassed = millis(); // int to hold the arduino miilis since startup
int memstatus = 1;  // value to notify if memory is current or old. 0=old, 1=current.
int f0=4;int f1=5; int f2=6; int f4=7; // BCD 100Hz
int ForceFreq = 1;  // Change this to 0 after you upload and run a working sketch to activate the EEPROM memory.  YOU MUST PUT THIS BACK TO 0 AND UPLOAD THE SKETCH AGAIN AFTER STARTING FREQUENCY IS SET!
// Rotary(Encoder Pin 1, Encoder Pin 2, Button Pin)
Rotary r = Rotary(2, 3, A0);
void setup() {
  pinMode(A0,INPUT); // Connect to a button that goes to GND on push
// pinMode(A5,INPUT); // IF sense **********************************************
  digitalWrite(A0,HIGH);
  //digitalWrite(A5,HIGH);
  lcd.begin();
   lcd.backlight(); //accende la retroilluminazione
  PCICR |= (1 << PCIE2);
  PCMSK2 |= (1 << PCINT18) | (1 << PCINT19);
  sei();
  Serial.begin(9600);
lcd.setCursor(hertzPosition,1);
  lcd.print(hertz);
  // Load the stored frequency
  if (ForceFreq == 0) {
    freq = String(EEPROM.read(0))+String(EEPROM.read(1))+String(EEPROM.read(2))+String(EEPROM.read(3))+String(EEPROM.read(4))+String(EEPROM.read(5))+String(EEPROM.read(6));
    rx = freq.toInt();
void loop() {
  // Update the display and frequency if the new Freq NEQ the old Freq
  if (rx != rx2){
        showFreq();
//        sendFrequency(rx);
  Serial.println(rx);
delay(500);
        rx2 = rx;
  // Rotate through the rate of tuning as you hold down the button
  buttonstate = digitalRead(A0);
  if(buttonstate == LOW) {
        setincrement();
    // Write the frequency to memory if not stored and 2 seconds have passed since the last frequency change.
    if(memstatus == 0){
      if(timepassed+2000 < millis()){
        storeMEM();
// Interrupt routine to catch the rotary encoder
ISR(PCINT2_vect) {
  unsigned char result = r.process();
  if (result) {
    if (result == DIR_CW){rx=rx+increment;}
    else {rx=rx-increment;};
      if (rx >=30000000){rx=rx2;}; // UPPER VFO LIMIT
      if (rx <=1000000){rx=rx2;}; // LOWER VFO LIMIT
void setincrement(){
  if(increment == 10){increment = 50; hertz = "50 Hz"; hertzPosition=5;}
  else if (increment == 50){increment = 100;  hertz = "100 Hz"; hertzPosition=4;}
  else if (increment == 100){increment = 500; hertz="500 Hz"; hertzPosition=4;}
  else if (increment == 500){increment = 1000; hertz="1 kHz"; hertzPosition=6;}
  else if (increment == 1000){increment = 2500; hertz="2.5 kHz"; hertzPosition=4;}
  else if (increment == 2500){increment = 5000; hertz="5 kHz"; hertzPosition=6;}
  else if (increment == 5000){increment = 10000; hertz="10 kHz"; hertzPosition=5;}
  else if (increment == 10000){increment = 100000; hertz="100 kHz"; hertzPosition=4;}
  else if (increment == 100000){increment = 1000000; hertz="1 MHz"; hertzPosition=6;}
  else{increment = 10; hertz = "10 Hz"; hertzPosition=5;};
   lcd.setCursor(0,1);
   lcd.print("                ");
   lcd.print(hertz);
   delay(250); // Adjust this delay to speed up/slow down the button menu scroll speed.
void showFreq(){
    millions = int(rx/1000000);
    hundredthousands = ((rx/100000)%10);
    tenthousands = ((rx/10000)%10);
    thousands = ((rx/1000)%10);
    hundreds = ((rx/100)%10);
    tens = ((rx/10)%10);
    ones = ((rx/1)%10);
    lcd.setCursor(0,0);
    lcd.print("                ");
   if (millions > 9){lcd.setCursor(1,0);}
   else{lcd.setCursor(2,0);}
    lcd.print(millions);
    lcd.print(".");
    lcd.print(hundredthousands);
    lcd.print(tenthousands);
    lcd.print(thousands);
    lcd.print(".");
    lcd.print(hundreds);
    lcd.print(tens);
    lcd.print(ones);
    lcd.print(" MHz  ");
    memstatus = 0; // Trigger memory write
void storeMEM(){
  //Write each frequency section to a EPROM slot.  Yes, it's cheating but it works!
   EEPROM.write(0,millions);
   EEPROM.write(1,hundredthousands);
   EEPROM.write(2,tenthousands);
   EEPROM.write(3,thousands);
   EEPROM.write(4,hundreds);
   EEPROM.write(5,tens);
   EEPROM.write(6,ones);
   memstatus = 1;  // Let program know memory has been written
la libreria e' qui:
https://github.com/brianlow/Rotary
ciao
Antonio
Re: Libreria rotary con problemi su arduino mega
MessaggioInviato: 16 feb 2023, 12:39
da aduri
Buongiorno a tutti,
ho fatto un passo avanti scoprendo che con gli esempi della libreria l'encoder con l'arduino mega lavora esattamente come l'arduino 1, il problema e' sul settaggio dei registri degli interrupt e pins relativi in uso.
  sei();
devo studiarmi le differenze del mega vs UNO.
Se qualcuno ci e' gia' passato e vuole darmi due dritte e' ben accetto.
saluti
Antonio
MessaggioInviato: 15 mar 2023, 12:50
da wimatech
perché non usi 2 e 3 anche sul mega?
Anche il mega ha gli interrupt su quei pin
Giusto per farti un idea prima di andare a toccare i registri hai provato uno sketch di test semplicemente dichiarando l'encoder come da esempi e stampando a monitor e eventualmente poi agire in profondità sui registri?
* Example using the Rotary library, dumping integers to the serial
* port. The integers increment or decrement depending on the direction
* of rotation.
* This example uses interrupts rather than polling.
#include <Rotary.h>
// Rotary encoder is wired with the common to ground and the two
// outputs to pins 2 and 3.
Rotary rotary = Rotary(2, 3);
// Counter that will be incremented or decremented by rotation.
int counter = 0;
void setup() {
  Serial.begin(57600);
  attachInterrupt(0, rotate, CHANGE);
  attachInterrupt(1, rotate, CHANGE);
void loop() {
// rotate is called anytime the rotary inputs change state.
void rotate() {
  unsigned char result = rotary.process();
  if (result == DIR_CW) {
    counter++;
    Serial.println(counter);
  } else if (result == DIR_CCW) {
    counter--;
