Scheda FreArduino come si installa
Buongiorno a tutti,:
la scheda in oggetto viene vista come COM3, ho provato a caricare un codice come arduino 1 ma da errore:
grazie per l'aiuto
Antonio
- Codice: Seleziona tutto
Arduino:1.8.16 (Windows 10), Scheda:"Arduino Uno"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Tony Stark\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Tony Stark\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Tony Stark\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=2341_0001 -ide-version=10816 -build-path C:\Users\TONYST~1\AppData\Local\Temp\arduino_build_665287 -warnings=none -build-cache C:\Users\TONYST~1\AppData\Local\Temp\arduino_cache_289814 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Users\Tony Stark\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\Tony Stark\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.arduinoOTA.path=C:\Users\Tony Stark\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\Tony Stark\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avrdude.path=C:\Users\Tony Stark\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\Tony Stark\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -verbose C:\Users\Tony Stark\Downloads\ProvaValvoleTest2\ProvaValvoleTest2.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Tony Stark\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Tony Stark\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Tony Stark\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=2341_0001 -ide-version=10816 -build-path C:\Users\TONYST~1\AppData\Local\Temp\arduino_build_665287 -warnings=none -build-cache C:\Users\TONYST~1\AppData\Local\Temp\arduino_cache_289814 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Users\Tony Stark\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\Tony Stark\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.arduinoOTA.path=C:\Users\Tony Stark\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\Tony Stark\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avrdude.path=C:\Users\Tony Stark\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\Tony Stark\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -verbose C:\Users\Tony Stark\Downloads\ProvaValvoleTest2\ProvaValvoleTest2.ino
Using board 'uno' from platform in folder: C:\Users\Tony Stark\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Using core 'arduino' from platform in folder: C:\Users\Tony Stark\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Detecting libraries used...
"C:\\Users\\Tony Stark\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Tony Stark\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\Tony Stark\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "C:\\Users\\TONYST~1\\AppData\\Local\\Temp\\arduino_build_665287\\sketch\\ProvaValvoleTest2.ino.cpp" -o nul
Generating function prototypes...
"C:\\Users\\Tony Stark\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Tony Stark\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\Tony Stark\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "C:\\Users\\TONYST~1\\AppData\\Local\\Temp\\arduino_build_665287\\sketch\\ProvaValvoleTest2.ino.cpp" -o "C:\\Users\\TONYST~1\\AppData\\Local\\Temp\\arduino_build_665287\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\TONYST~1\\AppData\\Local\\Temp\\arduino_build_665287\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Sto compilando lo sketch...
"C:\\Users\\Tony Stark\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Tony Stark\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\Tony Stark\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "C:\\Users\\TONYST~1\\AppData\\Local\\Temp\\arduino_build_665287\\sketch\\ProvaValvoleTest2.ino.cpp" -o "C:\\Users\\TONYST~1\\AppData\\Local\\Temp\\arduino_build_665287\\sketch\\ProvaValvoleTest2.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core: C:\Users\TONYST~1\AppData\Local\Temp\arduino_cache_289814\core\core_arduino_avr_uno_dcb37be7cfaaf5cd3d717b3105cb9a36.a
Linking everything together...
"C:\\Users\\Tony Stark\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\\Users\\TONYST~1\\AppData\\Local\\Temp\\arduino_build_665287/ProvaValvoleTest2.ino.elf" "C:\\Users\\TONYST~1\\AppData\\Local\\Temp\\arduino_build_665287\\sketch\\ProvaValvoleTest2.ino.cpp.o" "C:\\Users\\TONYST~1\\AppData\\Local\\Temp\\arduino_build_665287/..\\arduino_cache_289814\\core\\core_arduino_avr_uno_dcb37be7cfaaf5cd3d717b3105cb9a36.a" "-LC:\\Users\\TONYST~1\\AppData\\Local\\Temp\\arduino_build_665287" -lm
"C:\\Users\\Tony Stark\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\TONYST~1\\AppData\\Local\\Temp\\arduino_build_665287/ProvaValvoleTest2.ino.elf" "C:\\Users\\TONYST~1\\AppData\\Local\\Temp\\arduino_build_665287/ProvaValvoleTest2.ino.eep"
"C:\\Users\\Tony Stark\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\TONYST~1\\AppData\\Local\\Temp\\arduino_build_665287/ProvaValvoleTest2.ino.elf" "C:\\Users\\TONYST~1\\AppData\\Local\\Temp\\arduino_build_665287/ProvaValvoleTest2.ino.hex"
"C:\\Users\\Tony Stark\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-size" -A "C:\\Users\\TONYST~1\\AppData\\Local\\Temp\\arduino_build_665287/ProvaValvoleTest2.ino.elf"
Lo sketch usa 10644 byte (32%) dello spazio disponibile per i programmi. Il massimo è 32256 byte.
Le variabili globali usano 330 byte (16%) di memoria dinamica, lasciando altri 1718 byte liberi per le variabili locali. Il massimo è 2048 byte.
C:\Users\Tony Stark\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\Tony Stark\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\TONYST~1\AppData\Local\Temp\arduino_build_665287/ProvaValvoleTest2.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\Tony Stark\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM3
Using Programmer : arduino
Overriding Baud Rate : 115200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 3
Firmware Version: 4.4
Vtarget : 0.3 V
Varef : 0.3 V
Oscillator : 28.800 kHz
SCK period : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\TONYST~1\AppData\Local\Temp\arduino_build_665287/ProvaValvoleTest2.ino.hex"
avrdude: writing flash (10644 bytes):
Writing | ################################################## | 100% 1.40s
avrdude: 10644 bytes of flash written
avrdude: verifying flash memory against C:\Users\TONYST~1\AppData\Local\Temp\arduino_build_665287/ProvaValvoleTest2.ino.hex:
avrdude: load data flash data from input file C:\Users\TONYST~1\AppData\Local\Temp\arduino_build_665287/ProvaValvoleTest2.ino.hex:
avrdude: input file C:\Users\TONYST~1\AppData\Local\Temp\arduino_build_665287/ProvaValvoleTest2.ino.hex contains 10644 bytes
avrdude: reading on-chip flash data:
Reading | ################################################Errore durante il caricamento dello sketch
## | 100% 1.39s
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x0000
0x62 != 0x0c
avrdude: verification error; content mismatch
avrdude done. Thank you.
grazie per l'aiuto
Antonio
