vintage tube advertisement
Moderatori: Foto Utentecarloc, Foto Utenteg.schgor, Foto UtenteDirtyDeeds, Foto UtenteIsidoroKZ, Foto UtenteBrunoValente
[1] vintage tube advertisement
Messaggioda Foto UtenteMarcoD » 29 apr 2020, 18:29
Per gli amanti dei tubi a vuoto:
The Umac 606 is an infernal anode, helical beamed phantasatron having a dissipation rating. The unique vacuum in the phantasatron is of the double-sucked type, permitting a clear view of the non-emitting triple-processed prophylac plate. Because of its unique self-flushing construction, this tube will remain usable throughout its useful life.
The grid is constructed of a rare metal senilium chosen for its total lack of emission.1 Primary, secondary, and tertiary electrons are fully suppressed by a left-hand inclination toward the ecliptic extending from the nadir to the zenith. This also compensates for aberrations in azimuthal displacements common in tubes of previous design, wherein the focal point was improperly focused due to chromatic sphericalization.
The urinated tungsten filament is unique. This process is secret.2 The uranium used for the urination is of the triple distilled, single isotope variety with all neutrons removed. This material is obtained directly from the Hanford works.
Per i dati completi leggi:
http://www.wa7prc.com/humor/umac606.htm
thanks IsidoroKz
Foto UtenteMarcoD
7.094 4 8 13
[2] Re: vintage tube advertisement
Messaggioda Foto Utenteclaudiocedrone » 29 apr 2020, 18:45
Simpatico il catodo in tungsteno urinato :mrgreen: una delle tante valvole radioattive da cui tenersi alla larga...
15,6k 4 6 9
[3] Re: vintage tube advertisement
Messaggioda Foto Utentespeedyant » 29 apr 2020, 18:59
Devo fare attenzione alla mia "collezione" di valvole. Promemoria, ricordarsi del contatore Geiger...
3.739 3 6 8
[4] Re: vintage tube advertisement
Messaggioda Foto Utenteedgar » 29 apr 2020, 20:27
COOLING -- In operation, the 606 requires a minimum air flow of 5,000 cubic feet per second through, around, and above the base
Il primo convertitore piedi cubi -> metri cubi mi dice 141,58 metri cubi. Al secondo ?? :shock: :shock:
This air flow must be passed through the base in both directions in such a manner that none of the seals can exceed a temperature of -20° Kelvin
:shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock:
Refer to page 42, paragraph 6, "Notes from the 12U Conference" translated from Russian by A. Popoff.
Qualche lieve errore di traduzione magari ? :mrgreen: :mrgreen:
Foto Utenteedgar
6.302 3 5 8
[5] Re: vintage tube advertisement
Messaggioda Foto Utentespeedyant » 29 apr 2020, 20:31
Proprio lievi problemi traduzione, direi insignificanti!
3.739 3 6 8
[6] Re: vintage tube advertisement
Messaggioda Foto UtenteMarcoD » 1 mag 2020, 14:53
Vi sarete sicuramente accorti that it is an old elecronic hoax :-) :-)
Foto UtenteMarcoD
7.094 4 8 13
[7] Re: vintage tube advertisement
Messaggioda Foto Utenteedgar » 1 mag 2020, 16:06
A dire il vero ho giusto letto le due bestialità, ho attribuito alla traduzione l'errore e mi sono dedicato ad altro.
Fake news dal passato ? :mrgreen: :mrgreen: :mrgreen:
Foto Utenteedgar
6.302 3 5 8
[8] Re: vintage tube advertisement
Messaggioda Foto Utenteivano » 1 mag 2020, 16:59
e a che cosa sarebbe servito detto tubo?
forse era l'enfasi del nucleare che portava a produrre simili congegni o forse era una fake news di 70 anni fa'
Foto Utenteivano
881 1 3 4
[9] Re: vintage tube advertisement
Messaggioda Foto Utenteivano » 1 mag 2020, 17:09
ho cercato su internet e ho visto che dettimtubi esistevano davvero. erano usati nei radar militari.
da qui si capisce che i dati che ai nostri occhi non sembrano aver senso, in realta' molto probabilmente erano raggiunti. ricordiamoci che erano i tempi della grande corsa agli armamenti tecnologici e nucleari
Foto Utenteivano
881 1 3 4
[10] Re: vintage tube advertisement
Messaggioda Foto UtenteMarcoD » 1 mag 2020, 18:04
Certo che tubi con nomi simili erano usati per i radar...ma;
osservate attentamente l'immagine nell'articolo:
La placca è uno sturalavandini !!!
la connessinoe di griglia è un rubinetto
il filamento è poco chiaro, mi pare sia una candela.
Il marchio Umac non esiste, ma ricorda la Eimac
:D :D :D :D
Foto UtenteMarcoD
7.094 4 8 13
Visitano il forum: Nessuno e 67 ospiti
