Libro storia oscilloscopi Tektronix
[11] Re: Libro storia oscilloscopi Tektronix
Messaggioda Foto UtenteDarwinNE » 30 apr 2023, 10:05
Ma che meraviglia!!!
Gianni Becattini me lo ricordo per via della General Processor!
Foto UtenteDarwinNE
31,0k 7 11 13
[12] Re: Libro storia oscilloscopi Tektronix
Messaggioda Foto Utenteelfo » 30 apr 2023, 12:26
Il periodo intorno alla meta' degli anni '80 fu un momento critico per la Tek, causa la transizione al digitale per gli oscilloscopi.
Qui sotto alcune info su prodotti che ho toccato (o avrei voluto) toccare con mano.
Qui le specs e in fondo alcuni miei commenti e ricordi (non so quanto accurati)
______________________________________
*** Tek 2430 (meta' anni '80)
https://w140.com/tekwiki/wiki/2430
Channels 2
Sampling Rate 100 MS/s
Bandwidth 150 MHz
Single Shot bandwidth 40 MHz
Resolution 8 bits
Memory 1024 samples
*** LeCroy 9400 (meta' anni '80) diretto concorrente del Tek 2430
https://xdevs.com/doc/LeCroy/LECROY%209 ... Manual.pdf
http://www.test-italy.com/Specifiche%20 ... 209400.pdf
Vertical Analog Section
@ 50 ohm DC - 125 MHz at 10 mV/div, up to 150 MHz at 1 V/div
@ 1 M ohm AC <10 Hz - 100 MHz typical Bandwidth (-3
dB)
@ 1 M ohm DC DC - 100 MHz typical
Input Impedance 1 M ohm // 50 pF and 50 ohm
Channels Two; standard BNC connector inputs
Sensitivity 5 mV/div to 1 V/div at 50 ohm and 5 mV/div to 5 V/div at 1 M ohm
Vertical Digital Section
ADC One per channel, 8-bit flash
Conversion Rate
Up to 100 megasamples/sec for transient signals, up to 5
gigasamples/sec for repetitive signals, simultaneously on both
channels
Acquisition Memories
Channel 1 and 2
two, 32K 8-bit word memories (64K total) which can be segmented
into 8, 15, 31, 62, 125, or 250 blocks.
Reference Memories
C and D
Two, 32K 16-bit word memories (64K total) which can store two
acquired and/or processed waveforms
Glitch Detection Permanent glitch detection for events down to 0.4% of the timebase setting, 10 nsec minimum
*** Intertechnique IN7000 / Tek 7250 (meta anni '80 - inizio anni '90)
https://w140.com/tekwiki/wiki/7250
https://w140.com/tekwiki/images/0/0b/070-6401-01.pdf
It was made by Intertechnique in France where it was sold as the IN7000, and rebranded by Tektronix
Bandwidth 6 GHz (measured as -3 dB @ 7 GHz, -6 dB @ 9.6 GHz, and -8.5 dB @ 14 GHz in Haas, Warman, van Ewijk, Rev. Sci. Instrum. 60 (3), March 1989)
Rise time 50 ps
Resolution Vertical, 11 bits. The digitizer captures 512 samples in one shot.
Sweep 1 μs/Div to 50 ps/Div (1-2-5), equivalent to max. ~1 terasample per second
Sensitivity fixed 500 mV/Div (no vertical amplifiers in the signal path)
Weight 60 kg
Shipping 110 kg
Height 22.2 cm
Width 48.3 cm
Depth 91.5 cm
Commenti e ricordi
*** TEK 2430 Il Tek 2430 era la "versione digitale" del classico oscilloscopio portatile Tek ma era "molto oscilloscopio" e poco "digitale"
La digitalizzazione era fatta con tecnologia "analogica" a CCD (vedi link qui sotto) con conseguente profondita' di memoria di acquisizione di solo 1 K.
https://www.manualslib.com/manual/15830 ... l?page=261
Il display era un classico CRT Tek.
Poco dopo l'acquisto ci accorgemmo che scaricando i dati del CH2 tramite GPIB si otteneva "garbage" (spazzatura) - i dati del CH1 erano corretti.
Penammo non poco a far riconoscere il problema alla Tek ma finalmente venne un uomo Tek con le eprom "giuste".
Ci furono due "momenti di guasto":
1) un certo giorno, nel self test iniziale, comparve un codice di errore.
Il Tek 2430 aveva una guida alla diagnostica sullo schermo dell'oscilloscopio.
Utilizzandola insieme al manuale di service (completo di schemi elettrici!) individuammo il componente rotto. Se non ricordo male era uno switch analogico.
Andammo dal fornitore di componenti elettronici "dietro l'angolo" (si all'epoca c'erano ancora) e, comprato il componente, riparammo lo strumento.
2) in un momento successivo al precedente, in occasione di un problema piu' sottile, contattammo l'assistenza a Milano.
Ci fecero capire che se avessimo spedito lo strumento per una "calibrazione" avrebbero sostituito "free of charge" la motherboard con la versione 2430A.
Costo? 12 ML (ricordo di elfo)
*** LeCroy 9400 Il LeCroy era un "vero digitale moderno" ed effettuava la digitalizzazione con ADC flash e profondita' di memoria di 32 K.
Il display era un monitor televisivo.
La "scatola" era un contenitore Schroff customizzato (riconoscibilissimo dal tipo di maniglione utilizzato)
Gli alimentatori (piazzati in batteria sul retro dello strumento) erano prodotti modulari commerciali.
Costo? 24 ML (ricordo di elfo - il doppio del Tek)
*** Tek 7250 Il Tek 7250 era in realta' prodotto dalla francese Intertechnique.
Era un 6 GHz real time (non sampling) ma sostanzialmente "inusabile" stante - tra le altre cose - la profondita' di quasi un metro della "scatola" e il peso di 60 kg che richiedeva due persone per trasportarlo.
Ricordo quando - poco dopo l'acquisto, arrivato con pannello frontale con marchio Intertechnique - arrivarono da Milano due guys incravattati per sostituire il pannello originale con un altro identico salvo il marchio e modello Tektronix 7250.
Costo in Italia? 200 ML (ricordo di elfo)
Foto Utenteelfo
6.819 4 5 7
Visitano il forum: Nessuno e 165 ospiti
