circuito Bedini - fai da te
[1] circuito Bedini - fai da te
Messaggioda Foto UtenteBalduz » 11 gen 2011, 20:34
Salve a tutti e grazie per l'attenzione.
Premetto due cose:
1 Non conosco praticamente niente di elettronica.
2 Anni fa a scuola mi hanno insegnato i principi della termodinamica quindi non sto cercando di realizzare il moto perpetuo o fantasie simili.
L'altra sera mi sono imbattuto in questi video:
-- get 4 wires mark them or 4 colors
-- get 2 diodes ecg125 or eq
-- get a transistor npn 2n3055
-- a neon bulb
-- a computer fan
-- potentiometer
1-- remove label and clips from the rotor
2-- remove rotor and stator
3-- some stators are tough, cut wires off and carefully twist, the fan housings are flimsy, go easy
4-- remove circuit board
5-- most fan are single wire series wound, some are bifiler, dual phase-split the common pole wires so you now have 4 wires just what you need for bedini circuit carefully add fourth place for your extra wire get creative
6-- sometimes i removed all components off old board, put it back on to solder the 4th wire to it thru the removed component holes near it, get a magnifier to see better if you have too check for short on old traces
7-- pause, look carefully 2 wires
8-- separate them
9-- inside start of wrap
10-- put 1 back on post
11-- prepare 4th post
12-- take diode its the 4th pin
13-- start to hand drill 4th spot
14-- hold and heat pin
15-- push lighty not too much heat
16-- now its the 4th post
17-- cut off level with the rest
18-- mark start and of coils
19-- wrap 4th wire solder
20-- mark 2 wires were at the inside (start of wrap) as minus somewhere on the stator and the 2 wires at the outside (end of wrap) as plus check for continuity 20 to 60 ohm
21-- handy tool for starting holes
22-- check continuity
23-- solder 4 wires as you had marked them plus and minus, if you cold not determine which was start of wrap and end of wrap just switch wires when you wire the bedini circuit if you cet no start condition
24-- push stator and rotor back on
25-- put clip back and lube and label
26-- relax hard parts over
27-- get diode see and (cathode)
28-- get transistor check e-b-c
29-- get vol. wiper in center
30-- mount vol.
31-- mount diode to transistor
32-- get other diode put on case
33-- install neon
34-- install transistor
35-- make sure you observed all polarities of transistor and diodes solder base pin of transistor to center wiper of vol control solder positive of one set of coil wires to either side of vol control, negative to emitter on transistor
36-- solder negative side of second set of coils to collector of transistor, the positive side of second coil is your input battery plus, the emitter is the input battery negative
37-- now here's the surprising part of bedini's circuit, charge batteries negative lead hooks to the pluse side of the source battery, and the positive to the 2nd diode i use green for this ground as to not get confused with the source battery grounds black
38-- spin it up
39-- adjust look for neon glow
Vorrei poter realizzare questo tipo di circuito ma avrei alcune domande a riguardo:
Non ho ben chiaro come preparare il motorino della ventola (primo video intervallo da 2:00 minuti a 6:30, nella mia lista da punto numero 5 a 23), qualcuno potrebbe spiegarmelo?
Al posto del bulbo neon si potrebbe mettere un led?
Al circuito bisogna collegare anche delle batterie ricaricabili? Se si, si potrebbero sostituire le pile ricaricabili con dei condensatori?
Grazie ancora per l'attenzione.
Ale
Foto UtenteBalduz
[2] Re: circuito Bedini - fai da te
Messaggioda Foto UtenteIsidoroKZ » 11 gen 2011, 23:56
Risparmia soldi e tempo, tanto non va :-)
[3] Re: circuito Bedini - fai da te
Messaggioda Foto UtenteBalduz » 12 gen 2011, 21:50
l'hai già provato? e di preciso cosa non va? (se puoi indicare in che parte del circuito c'è l'errore saresti d'aiuto)
grazie
Foto UtenteBalduz
[4] Re: circuito Bedini - fai da te
Messaggioda Foto UtenteTardoFreak » 12 gen 2011, 22:52
Here we go! :mrgreen:
73,9k 8 12 13
[5] Re: circuito Bedini - fai da te
Messaggioda Foto UtenteIsidoroKZ » 12 gen 2011, 23:35
Balduz ha scritto:l'hai già provato? e di preciso cosa non va?
Non va il fatto che si cerchi di imbrogliare la termodinamica, che dici di aver studiato :-)
[6] Re: circuito Bedini - fai da te
Messaggioda Foto UtenteRenzoDF » 12 gen 2011, 23:43
Si, noi li abbiamo provati TUTTI :D
... cosa non va? ... il colore dello smalto :mrgreen:
[7] Re: circuito Bedini - fai da te
Messaggioda Foto UtenteDirtyDeeds » 13 gen 2011, 2:00
Bedini-Imhotep :!: E' quell'Imhotep che mi mette soggezione: e se uno analizza il circuito e poi si scoperchia una tomba faraonica? :mrgreen:
55,9k 7 11 13
[8] Re: circuito Bedini - fai da te
Messaggioda Foto UtenteLayer » 13 gen 2011, 15:16
RenzoDF ha scritto: ... cosa non va? ... il colore dello smalto :mrgreen:
Intendi quello del filo di rame smaltato? :D :lol: (Balduz, non prendertela... la buttiamo sullo scherzoso!)
Foto UtenteLayer
205 3 8
[9] Re: circuito Bedini - fai da te
Messaggioda Foto UtenteRenzoDF » 13 gen 2011, 15:43
Layer ha scritto: Intendi quello del filo di rame smaltato?
No no, intendo quello delle unghie "ragazza"! :mrgreen: ... che è pure "steso" male!
... io so far di meglio :D
[10] Re: circuito Bedini - fai da te
Messaggioda Foto UtenteTONYSTARK » 13 gen 2011, 15:52
Tu parli delle unghie di lei!?! ma li hai visti insieme sembrano la copertina bagnata di un harmony .
una specie di la bella e la bestia al contrario.
PS dimostrazione che non funziona:
nel video valanga di foto e poi il filmato dell' accrocco che gira con un milione di cavi attorno...
a voi scoprire a quale di questi ultimi era attaccata la batteria o visto il tipo di ventola la
scheda madre
3.760 5 11 13
