é possibile overlockare questa cpu?
Linguaggi e sistemi
[1] é possibile overlockare questa cpu?
Messaggioda Foto Utenteklejdi » 11 gen 2010, 21:28
mi sapreste dire se è possibile overlockare questa cpu ,e in che modo posso fare per overlockare in modo sikuro?
Queste le caratteristiche:
Motherboard:
Property Value
Manufacturer Acer
Model Acadia
Version N/A
Serial Number LXAH30Y09872709D321601
North Bridge Intel i943/940GML Revision 03
South Bridge Intel 82801GHM (ICH7-M/U) Revision 03
CPU Intel(R) Celeron(R) M CPU 520 @ 1.60GHz
Cpu Socket Socket 479 mPGA
System Slots 2 PCI
Memory Summary
Maximum Capacity 2048 MBytes
Memory Slots 2
Error Correction None
Warning! Accuracy of DMI data cannot be guaranteed
BIOS:
Property Value
BIOS Vendor Acer
BIOS Version V1.50
BIOS Date 07/17/2007
BIOS Size 1024 KB
BIOS Starting Segment E78Eh
DMI Version 2.33
Characteristics - supports PCI
- supports PC Card (PCMCIA)
- supports Plug-and-Play
- upgradeable (Flash) BIOS
- allows BIOS shadowing
- ESCD support is available
- supports booting from CD-ROM
- supports selectable boot
- supports INT 05 print-screen
- supports INT 09 and 8042 keyboard services
- supports INT 17 printer services
- supports INT 10 CGA/Mono video services
- supports ACPI
- supports legacy USB
- supports AGP
- Smart Battery supported
- BIOS Boot Specification supported
- Enable Targeted Content Distribution
CPU:
Property Value
Number of CPU(s) One Physical Processor / One Core / One Logical Processor / 64 bits
CPU Full Name Intel(R) Celeron(R) M CPU 520 @ 1.60GHz
CPU Name Intel Celeron M 520
CPU Code Name Merom
Platform Name Socket 479 mPGA
Revision B2
Technology 65 nm
Instructions MMX, SSE, SSE2, SSE3, SSSE3, ET64, XD
Original Clock 1600 MHz
Original System Clock 133 MHz
Original Multiplier 12.1
CPU Clock 1600 MHz
System Clock 133.0 MHz
FSB 532.0 MHz
Core 0 Speed 1596.1 MHz
Core 0 Multiplier 12.0
L1 Data Cache 32 KBytes
L1 Instructions Cache 32 KBytes
L2 Cache 1024 KBytes
Foto Utenteklejdi
25 1 5
[2] Re: é possibile overlockare questa cpu?
Messaggioda Foto Utentephylum » 12 gen 2010, 14:28
se nn ric. male la famiglia celeron tra le altre cose ha il moltiplicatore bloccato
potresti giocare sul fsb : Immagine :)
se le prestazioni nn ti soddisfano cambia SO e/o installa un qt du ram suff o trova un altro uso al PC/regalalo :)
Immagine
\int_{}tella
Immagine
Foto Utentephylum
6.191 5 7 12
[3] Re: é possibile overlockare questa cpu?
Messaggioda Foto Utentelucbie » 12 gen 2010, 16:20
phylum ha ragione.
Comunque, perché dovresti overclockare il PC? Insomma, in quali applicazioni hai problemi di velocità?
A differenza degli anni '90, in molti casi non è il processore il collo di bottiglia.
Foto Utentelucbie
85 1 3 7
[4] Re: é possibile overlockare questa cpu?
Messaggioda Foto Utenteklejdi » 12 gen 2010, 22:58
allora mi sa che ascoltero il vostro consiglio e lasio stare...o al massimo cambio so come suggerito da phylum... :D :D
Foto Utenteklejdi
25 1 5
[5] Re: é possibile overlockare questa cpu?
Messaggioda Foto Utentelucbie » 13 gen 2010, 12:48
Ripeto la domanda: in che tipo di applicazioni hai problemi di performance? :wink:
Foto Utentelucbie
85 1 3 7
[6] Re: é possibile overlockare questa cpu?
Messaggioda Foto Utenteklejdi » 13 gen 2010, 15:07
lucbie ha scritto:Ripeto la domanda: in che tipo di applicazioni hai problemi di performance? :wink:
quando apro singole applicazioni non c'è un calo evidente di performance, ma il problema aumento quando apro due o tre applicazioni e molte volte vedo che firefox mi prende molta cpu e anche molta ram
Foto Utenteklejdi
25 1 5
[7] Re: é possibile overlockare questa cpu?
Messaggioda Foto Utentelucbie » 14 gen 2010, 13:18
Che Firefox allochi molta RAM è normale.
L'uso della CPU dipende dalle pagine che stai visitando; se contengono filmati o animazioni Flash è un attimo che si incrementi l'uso.
Quando sei in queste condizioni critiche il processore è costantemente al 100%?
Fai attenzione anche al LED del disco rigido. Se rimane acceso a lungo può essere che hai un problema di quantità di RAM, per cui il sistema usa la paginazione che impegna anche il processore.
Foto Utentelucbie
85 1 3 7
[8] Re: é possibile overlockare questa cpu?
Messaggioda Foto Utenteklejdi » 14 gen 2010, 15:19
lucbie ha scritto:Quando sei in queste condizioni critiche il processore è costantemente al 100%?
si infatti l'uso della cpu avviene quanto uso applicazioni flash.
si è costantemente al 100%.
Foto Utenteklejdi
25 1 5
[9] Re: é possibile overlockare questa cpu?
Messaggioda Foto Utentelucbie » 14 gen 2010, 15:40
Quindi hai ragione; è un problema di processore e dubito che un aggiornamento di OS possa cambiarti la vita.
Con una LIVE linux tipo Slax ( http://www.slax.org/get_slax.php ) potresti averne conferma senza perdere troppo tempo.
Foto Utentelucbie
85 1 3 7
Torna a PC e informatica
