Problema mancanza messaggio di errore di tofile()
Linguaggi e sistemi
[1] Problema mancanza messaggio di errore di tofile()
Messaggioda Foto Utentealien75 » 30 mar 2025, 13:08
Ho il seguente codice python che utilizza le funzioni membro tofile() e fromfile() di numpy per salvare e leggere
i due file sinaptici di nome who.dat e wih.dat:
Codice: Seleziona tutto
import numpy as np
import cv2
import cv2 as cv
import sys
class NeuralNetwork:
    def __init__(self, input_size, hidden_size, output_size):
        self.input_size = input_size
        self.hidden_size = hidden_size
        self.output_size = output_size
        self.weights_input_hidden = np.random.randn(self.input_size, self.hidden_size)
        self.weights_hidden_output = np.random.randn(self.hidden_size, self.output_size)
        self.bias_hidden = np.zeros((1, self.hidden_size))
        self.bias_output = np.zeros((1, self.output_size))
    def sigmoid(self, x):
        return 1 / (1 + np.exp(-x))
    def sigmoid_derivative(self, x):
        return x * (1 - x)
    def feedforward(self, X):
        self.hidden_activation = np.dot(X, self.weights_input_hidden) + self.bias_hidden
        self.hidden_output = self.sigmoid(self.hidden_activation)
        self.output_activation = np.dot(self.hidden_output, self.weights_hidden_output) + self.bias_output
        self.predicted_output = self.sigmoid(self.output_activation)
        return self.predicted_output
    def backward(self, X, y, learning_rate):
        output_error = y - self.predicted_output
        output_delta = output_error * self.sigmoid_derivative(self.predicted_output)
        hidden_error = np.dot(output_delta, self.weights_hidden_output.T)
        hidden_delta = hidden_error * self.sigmoid_derivative(self.hidden_output)
        self.weights_hidden_output += np.dot(self.hidden_output.T, output_delta) * learning_rate
        self.bias_output += np.sum(output_delta, axis=0, keepdims=True) * learning_rate
        self.weights_input_hidden += np.dot(X.T, hidden_delta) * learning_rate
        self.bias_hidden += np.sum(hidden_delta, axis=0, keepdims=True) * learning_rate
    def train(self, X, y, epochs, learning_rate):
        for epoch in range(epochs):
            output = self.feedforward(X)
            self.backward(X, y, learning_rate)
            if epoch % 4000 == 0:
                loss = np.mean(np.square(y - output))
                print(f"Epoch {epoch}, Loss:{loss}")
IMAGE1 = 'day_open.jpg'
IMAGE2 = 'day_closed.jpg'
IMAGE3 = 'night_open.jpg'
IMAGE4 = 'night_closed.jpg'
IMAGE5 = 'DX.jpg'
IMAGE6 = 'SX.jpg'
IMAGE7 = 'day_open.jpg'
image1 = cv2.imread(IMAGE1)
image2 = cv2.imread(IMAGE2)
image3 = cv2.imread(IMAGE3)
image4 = cv2.imread(IMAGE4)
image5 = cv2.imread(IMAGE5)
image6 = cv2.imread(IMAGE6)
image7 = cv2.imread(IMAGE7)
gray_image1 = cv2.cvtColor(image1, cv2.COLOR_BGR2GRAY)
gray_image1 = cv2.resize(gray_image1,(100, 100), interpolation = cv2.INTER_CUBIC)
gray_image2 = cv2.cvtColor(image2, cv2.COLOR_BGR2GRAY)
gray_image2 = cv2.resize(gray_image2,(100, 100), interpolation = cv2.INTER_CUBIC)
gray_image3 = cv2.cvtColor(image3, cv2.COLOR_BGR2GRAY)
gray_image3 = cv2.resize(gray_image3,(100, 100), interpolation = cv2.INTER_CUBIC)
gray_image4 = cv2.cvtColor(image4, cv2.COLOR_BGR2GRAY)
gray_image4 = cv2.resize(gray_image4,(100, 100), interpolation = cv2.INTER_CUBIC)
gray_image5 = cv2.cvtColor(image5, cv2.COLOR_BGR2GRAY)
gray_image5 = cv2.resize(gray_image5,(100, 100), interpolation = cv2.INTER_CUBIC)
gray_image6 = cv2.cvtColor(image6, cv2.COLOR_BGR2GRAY)
gray_image6 = cv2.resize(gray_image6,(100, 100), interpolation = cv2.INTER_CUBIC)
gray_image7 = cv2.cvtColor(image7, cv2.COLOR_BGR2GRAY)
gray_image7 = cv2.resize(gray_image7,(100, 100), interpolation = cv2.INTER_CUBIC)
gray_image1 = gray_image1 / 255
gray_image2 = gray_image2 / 255
gray_image3 = gray_image3 / 255
gray_image4 = gray_image4 / 255
gray_image5 = gray_image5 / 255
gray_image6 = gray_image6 / 255
gray_image7 = gray_image7 / 255
X=np.array([gray_image1.reshape(10000),gray_image2.reshape(10000),gray_image3.reshape(10000),gray_image4.reshape(10000),gray_image5.reshape(10000),gray_image6.reshape(10000)])
y=np.array([[0,1,0,0],[0,0,0,0],[0,1,0,0],[0,0,0,0],[0,1,1,0],[0,1,0,1]])
print("output = ", y)
print(X.shape)
nn = NeuralNetwork(input_size=10000, hidden_size=300, output_size=4)
nn.train(X, y, epochs=700, learning_rate=0.8)
#caricamento pesi tra ingresso e strato di uscita
nn.weights_input_hidden = np.fromfile("wih.dat", dtype=float)
nn.weights_hidden_output = np.fromfile("who.dat", dtype=float)
print(len(nn.weights_input_hidden))
print(len(nn.weights_hidden_output))
print(f'training')
#salvataggio pesi tra ingresso e strato hidden
wih=np.dot(nn.weights_input_hidden, )
wih.tofile("wih.dat")
#salvataggio pesi tra strato hidden e uscita
who=np.dot(nn.weights_hidden_output)
who.tofile("who.dat")
print("Predictions after training:")
print(f'  image1 {nn.feedforward(gray_image1.reshape(1,10000))}')
print(f'  image2 {nn.feedforward(gray_image2.reshape(1,10000))}')
print(f'  image3 {nn.feedforward(gray_image3.reshape(1,10000))}')
print(f'  image4 {nn.feedforward(gray_image4.reshape(1,10000))}')
print(f'  image5 {nn.feedforward(gray_image5.reshape(1,10000))}')
print(f'  image6 {nn.feedforward(gray_image6.reshape(1,10000))}')
print(f'  image7 {nn.feedforward(gray_image7.reshape(1,10000))}')
Devo cercare di gestire eventuali errori dovuti dalla eventuale mancanza di tali file.
In sostanza voglio far si che l' addestramento e tofile() partano solo se mancano i file who.dat e wih.dat, se invece i file sono presenti deve solo leggerli e "caricare" le sinapsi con tali valori.
Ho cercato in rete ma la gestione di errori per fromfile() e tofile() non esiste.
Come posso fare?
Foto Utentealien75
1 1 4 8
[2] Re: Problema mancanza messaggio di errore di tofile()
Messaggioda Foto UtenteGoofy » 30 mar 2025, 13:14
Avevo letto trofie #-o
Foto UtenteGoofy
14,6k 4 5 9
[3] Re: Problema mancanza messaggio di errore di tofile()
Messaggioda Foto UtenteGioArca67 » 30 mar 2025, 13:28
Colpa dell'ora...
prova con il costrutto base:
try:
      # Code that might raise an exception
except SomeException:
      # Code to handle the exception
else:
     # Code to run if no exception occurs
finally:
    # Code to run regardless of whether an exception occurs
4.565 4 6 9
[4] Re: Problema mancanza messaggio di errore di tofile()
Messaggioda Foto Utentealien75 » 30 mar 2025, 14:20
GioArca67 ha scritto:Colpa dell'ora...
try:
else:
finally:
Questa parte l' ho risolta con:
try:
    print(f'caricamento')
    #nn.weights_hidden_output = np.fromfile("who.dat", dtype=float)
except:
    print(f'training')
    wih=np.dot(nn.weights_input_hidden, nn.weights_hidden_output)
    #who=np.dot(nn.weights_hidden_output, nn.weights_input_hidden)
    #who.tofile("who.dat")
ora mi rimane questo problema:
Non posso passare con np.dot() due array al file wih.dat altrimenti la volta sucessiva che avvio BP.py
mi da errore su try: perché carica le prime sinapsi con due array ed eccede e quindi mi da errore.
Devo far si che np.dot() mi carichi un solo array, come faccio?
np.dot() accetta due array putroppo.
Foto Utentealien75
1 1 4 8
[5] Re: Problema mancanza messaggio di errore di tofile()
Messaggioda Foto UtenteGioArca67 » 30 mar 2025, 15:22
Potrebbe essere meglio usare exists()
import os
file_path = "example.txt"
if os.path.exists(file_path):
    print("File exists")
else:
    print("File does not exist")
4.565 4 6 9
[6] Re: Problema mancanza messaggio di errore di tofile()
Messaggioda Foto Utentealien75 » 30 mar 2025, 19:49
GioArca67 ha scritto:Potrebbe essere meglio usare exists()
import os
else:
Ok e riguardo il post sopra che mi dici?
Mi serve una libreria che mi possa accettare un solo array e mi dia come ritorno un oggetto,
come la np.dot().
Foto Utentealien75
1 1 4 8
[7] Re: Problema mancanza messaggio di errore di tofile()
Messaggioda Foto UtenteGioArca67 » 30 mar 2025, 21:47
Il prodotto è fra due elementi.
4.565 4 6 9
[8] Re: Problema mancanza messaggio di errore di tofile()
Messaggioda Foto Utentealien75 » 30 mar 2025, 21:57
GioArca67 ha scritto:Il prodotto è fra due elementi.
Ho trovato np.array() che può accettare pure un solo array.
Foto Utentealien75
1 1 4 8
[9] Re: Problema mancanza messaggio di errore di tofile()
Messaggioda Foto UtenteGioArca67 » 30 mar 2025, 22:29
Per favore eponi meglio quello che vuoi fare perché, almeno a me, non è chiaro.
Il programma ad un certo punto fa un prodotto interno e per questo servono due array ed np.dot fa questo.
np.array è un costruttore di ndarray (l'oggetto array usato da numpy) , tutt'altro rispetto al prodotto.
Qual è il problema che ti blocca?
4.565 4 6 9
[10] Re: Problema mancanza messaggio di errore di tofile()
Messaggioda Foto Utentealien75 » 31 mar 2025, 7:05
codice:
import numpy as np
import cv2
import cv2 as cv
import sys
import os
        return x * (1 - x)
IMAGE5 = 'DX.jpg'
IMAGE6 = 'SX.jpg'
print(X.shape)
if os.path.exists("wih.dat"):
    #caricamento pesi tra ingresso e strato di hidden
    print(f'caricamento wih')
else:
    print(f'training')
    wih=np.array(nn.weights_input_hidden)
if os.path.exists("who.dat"):
    #caricamento pesi tra strato di hidden ed uscita
    print(f'caricamento who')
else:
    print(f'training')
    who=np.array(nn.weights_hidden_output)
errore:
output =  [[0 1 0 0]
[0 0 0 0]
[0 1 0 0]
[0 0 0 0]
[0 1 1 0]
[0 1 0 1]]
(6, 10000)
caricamento wih
caricamento who
Traceback (most recent call last):
  File "/home/fabio/Scrivania/BP.py", line 126, in <module>
  File "/home/fabio/Scrivania/BP.py", line 27, in feedforward
ValueError: shapes (1,10000) and (3000000,) not aligned: 10000 (dim 1) != 3000000 (dim 0)
Non capisco perché mi da errore in fase di caricamento file.
Foto Utentealien75
1 1 4 8
Torna a PC e informatica
