Codice: Seleziona tutto
#include "Arduino.h"
#include <SPI.h>
#include "Wire.h"
#include "9833.h"
int k, i;
int FSYNC = 52;
int FSYNC2 = 50;
int SDATA = 11;
int SCLK = 13;
void setup()
for(k=50;k<53;k++) pinMode(k, OUTPUT);
for (i=50;i<53;i++) digitalWrite(i,HIGH);
for(k=11;k<14;k++) pinMode(k, OUTPUT);
for (i=11;i<14;i++) digitalWrite(i,HIGH);
Gen gen[10];
gen[0].reset(FSYNC);
void loop()
gen[0].reset(FSYNC); //reset
gen[0].begin(FSYNC);
gen[0].signal(2000,0x2000,FSYNC); //genera un segnale da 2000Hz sin
poi devo collegate il file 9833.cpp:
void Gen::reset(int sc)
UpdateRegister(0x2100, sc); //Controll Reg
UpdateRegister(0x0100, sc); //reset
void Gen::begin(int sc)
UpdateRegister(0xC000, sc); //fase 0 in 0
UpdateRegister(0xE000, sc); //fase 0 in 1
void Gen::signal(unsigned int freq, int shape, int sc)
FreqReg=(freq * pow(2,28))/25000000;
if(shape==0x2020) FreqReg = FreqReg << 1;
MSB = (int)((FreqREg & 0xFFFC000) >> 14);
LSB = (int)(FreqReg & 0X3FFF);
LSB |= 0X4000;
MSB |= 0x4000;
UpdateRegister(LSB, sc); //FreqREg LSB
UpdateRegister(MSB, sc); //FreqReg MSB
UpdateRegister(0xC000, sc); //phase Reg
UpdateRegister(shape, sc); //exit reset
e il relativo header 9833.h:
class Gen
public:
void begin(int);
void reset(int);
void signal(unsigned int, int, int);
void UpdateRegister(unsigned int, int );
private:
long FreqReg;
unsigned int LSB, MSB;
Ho fatto File | Nuovo per creare uno nuovo progetto poi ho fatto Sckech | Aggiungi file per il file -cpp ed il relatiov header e mi chiede se voglio sostituirlo e compilando mi da errore:
Arduino:1.7.11 (Windows 8.1), Scheda:"Arduino Due (Programming Port)"
9833.cpp:1:10: error: 'Gen' has not been declared
9833.cpp: In function 'void reset(int)':
9833.cpp:3:33: error: 'UpdateRegister' was not declared in this scope
9833.cpp: At global scope:
9833.cpp:7:10: error: 'Gen' has not been declared
9833.cpp: In function 'void begin(int)':
9833.cpp:9:33: error: 'UpdateRegister' was not declared in this scope
9833.cpp:14:10: error: 'Gen' has not been declared
9833.cpp: In function 'void signal(unsigned int, int, int)':
9833.cpp:16:8: error: 'FreqReg' was not declared in this scope
9833.cpp:16:32: error: 'pow' was not declared in this scope
9833.cpp:18:13: error: 'MSB' was not declared in this scope
9833.cpp:18:26: error: 'FreqREg' was not declared in this scope
9833.cpp:19:8: error: 'LSB' was not declared in this scope
9833.cpp:22:33: error: 'UpdateRegister' was not declared in this scope
Errore durante la compilazione
Aiutatemi a capire perche non linka e compila i file che lo compongono.
