Ad ogni modo se fai un riassunto sull'uso di questi due vettori, si può vedere se un ottimizzazione è possibile...
Questo è un esempio del font 8x5.h:
- Codice: Seleziona tutto
#ifndef STANDARD_FONT
#define STANDARD_FONT
#else
#error Multiple standard font defined!
#endif
#define FONT_WIDTH 5
#define FONT_START 32
#define FONT_END 127
// every char is defined from left to right
// every column is defined from MSB (bottom) to LSB (top)
#pragma idata OurVectSec
volatile char ASCII2[765] = { //numeri di caratteri reali 680
0x00, 0x00, 0x00, 0x00, 0x00, // 20 [SPACE]
0x00, 0x00, 0x5f, 0x00, 0x00, // 21 !
0x00, 0x07, 0x00, 0x07, 0x00, // 22 "
0x14, 0x7f, 0x14, 0x7f, 0x14, // 23 #
0x24, 0x2a, 0x7f, 0x2a, 0x12, // 24 $
0x23, 0x13, 0x08, 0x64, 0x62, // 25 %
0x36, 0x49, 0x55, 0x22, 0x50, // 26 &
0x00, 0x05, 0x03, 0x00, 0x00, // 27 '
0x00, 0x1c, 0x22, 0x41, 0x00, // 28 (
0x00, 0x41, 0x22, 0x1c, 0x00, // 29 )
0x14, 0x08, 0x3e, 0x08, 0x14, // 2a *
0x08, 0x08, 0x3e, 0x08, 0x08, // 2b +
0x00, 0x50, 0x30, 0x00, 0x00, // 2c ,
0x08, 0x08, 0x08, 0x08, 0x08, // 2d -
0x00, 0x60, 0x60, 0x00, 0x00, // 2e .
0x20, 0x10, 0x08, 0x04, 0x02, // 2f /
0x3e, 0x51, 0x49, 0x45, 0x3e, // 30 0
0x00, 0x42, 0x7f, 0x40, 0x00, // 31 1
0x42, 0x61, 0x51, 0x49, 0x46, // 32 2
0x21, 0x41, 0x45, 0x4b, 0x31, // 33 3
0x18, 0x14, 0x12, 0x7f, 0x10, // 34 4
0x27, 0x45, 0x45, 0x45, 0x39, // 35 5
0x3c, 0x4a, 0x49, 0x49, 0x30, // 36 6
0x01, 0x71, 0x09, 0x05, 0x03, // 37 7
0x36, 0x49, 0x49, 0x49, 0x36, // 38 8
0x06, 0x49, 0x49, 0x29, 0x1e, // 39 9
0x00, 0x36, 0x36, 0x00, 0x00, // 3a :
0x00, 0x56, 0x36, 0x00, 0x00, // 3b ;
0x08, 0x14, 0x22, 0x41, 0x00, // 3c <
0x14, 0x14, 0x14, 0x14, 0x14, // 3d =
0x00, 0x41, 0x22, 0x14, 0x08, // 3e >
0x02, 0x01, 0x51, 0x09, 0x06, // 3f ?
0x32, 0x49, 0x79, 0x41, 0x3e, // 40 @
0x7e, 0x11, 0x11, 0x11, 0x7e, // 41 A
0x7f, 0x49, 0x49, 0x49, 0x36, // 42 B
0x3e, 0x41, 0x41, 0x41, 0x22, // 43 C
0x7f, 0x41, 0x41, 0x22, 0x1c, // 44 D
0x7f, 0x49, 0x49, 0x49, 0x41, // 45 E
0x7f, 0x09, 0x09, 0x09, 0x01, // 46 F
0x3e, 0x41, 0x49, 0x49, 0x7a, // 47 G
0x7f, 0x08, 0x08, 0x08, 0x7f, // 48 H
0x00, 0x41, 0x7f, 0x41, 0x00, // 49 I
0x20, 0x40, 0x41, 0x3f, 0x01, // 4a J
0x7f, 0x08, 0x14, 0x22, 0x41, // 4b K
0x7f, 0x40, 0x40, 0x40, 0x40, // 4c L
0x7f, 0x02, 0x0c, 0x02, 0x7f, // 4d M
0x7f, 0x04, 0x08, 0x10, 0x7f, // 4e N
0x3e, 0x41, 0x41, 0x41, 0x3e, // 4f O
0x7f, 0x09, 0x09, 0x09, 0x06, // 50 P
0x3e, 0x41, 0x51, 0x21, 0x5e, // 51 Q
0x7f, 0x09, 0x19, 0x29, 0x46, // 52 R
0x46, 0x49, 0x49, 0x49, 0x31, // 53 S
0x01, 0x01, 0x7f, 0x01, 0x01, // 54 T
0x3f, 0x40, 0x40, 0x40, 0x3f, // 55 U
0x1f, 0x20, 0x40, 0x20, 0x1f, // 56 V
0x3f, 0x40, 0x38, 0x40, 0x3f, // 57 W
0x63, 0x14, 0x08, 0x14, 0x63, // 58 X
0x07, 0x08, 0x70, 0x08, 0x07, // 59 Y
0x61, 0x51, 0x49, 0x45, 0x43, // 5a Z
0x00, 0x7f, 0x41, 0x41, 0x00, // 5b [
0x06, 0x09, 0x09, 0x06, 0x00, // 5c [DEGREE]
0x00, 0x41, 0x41, 0x7f, 0x00, // 5d ]
0x04, 0x02, 0x01, 0x02, 0x04, // 5e ^
0x40, 0x40, 0x40, 0x40, 0x40, // 5f _
0x00, 0x01, 0x02, 0x04, 0x00, // 60 `
0x20, 0x54, 0x54, 0x54, 0x78, // 61 a
0x7f, 0x48, 0x44, 0x44, 0x38, // 62 b
0x38, 0x44, 0x44, 0x44, 0x20, // 63 c
0x38, 0x44, 0x44, 0x48, 0x7f, // 64 d
0x38, 0x54, 0x54, 0x54, 0x18, // 65 e
0x08, 0x7e, 0x09, 0x01, 0x02, // 66 f
0x0c, 0x52, 0x52, 0x52, 0x3e, // 67 g
0x7f, 0x08, 0x04, 0x04, 0x78, // 68 h
0x00, 0x44, 0x7d, 0x40, 0x00, // 69 i
0x20, 0x40, 0x44, 0x3d, 0x00, // 6a j
0x7f, 0x10, 0x28, 0x44, 0x00, // 6b k
0x00, 0x41, 0x7f, 0x40, 0x00, // 6c l
0x7c, 0x04, 0x18, 0x04, 0x78, // 6d m
0x7c, 0x08, 0x04, 0x04, 0x78, // 6e n
0x38, 0x44, 0x44, 0x44, 0x38, // 6f o
0x7c, 0x14, 0x14, 0x14, 0x08, // 70 p
0x08, 0x14, 0x14, 0x18, 0x7c, // 71 q
0x7c, 0x08, 0x04, 0x04, 0x08, // 72 r
0x48, 0x54, 0x54, 0x54, 0x20, // 73 s
0x04, 0x3f, 0x44, 0x40, 0x20, // 74 t
0x3c, 0x40, 0x40, 0x20, 0x7c, // 75 u
0x1c, 0x20, 0x40, 0x20, 0x1c, // 76 v
0x3c, 0x40, 0x30, 0x40, 0x3c, // 77 w
0x44, 0x28, 0x10, 0x28, 0x44, // 78 x
0x0c, 0x50, 0x50, 0x50, 0x3c, // 79 y
0x44, 0x64, 0x54, 0x4c, 0x44, // 7a z
0x00, 0x08, 0x36, 0x41, 0x00, // 7b {
0x00, 0x00, 0x7f, 0x00, 0x00, // 7c |
0x00, 0x41, 0x36, 0x08, 0x00, // 7d }
0x08, 0x1C, 0x2A, 0x08, 0x08, // 7e [LEFT ARROW]
0x08, 0x08, 0x2A, 0x1C, 0x08, // 7f [RIGHT ARROW]
#pragma idata
E questa è la funzione principale che identifica il caratte:
// print a char from char FONT_START
void oled_putch(unsigned char c)
char i;
#if defined USE_BIG_FONT
// use oled_putbigch if big font selected
if (oled_font==FONT_BIG)
oled_putbigch(c);
else
#endif
unsigned int u; // char index in the array
// ascii chars out of limits becomes '?'
if ((c<FONT_START) || (c>FONT_END))
c='?';
u=c-FONT_START;
u*=FONT_WIDTH;
for (i=0; i<FONT_WIDTH; i++)
if (oled_inverted)
_oled_send(~(ASCII2[u+i]), OLED_DATA);
else
_oled_send(ASCII2[u+i], OLED_DATA);
// adding a 0-page to the right if font is 5 pixel, since
// I've not included a space in this font
#if FONT_WIDTH==5
_oled_send(0xFF*oled_inverted, OLED_DATA);
curX++;
#endif
curX+=FONT_WIDTH;
if (curX>(DISPLAY_WIDTH-1))
curX=curX-DISPLAY_WIDTH;
curY++;
if (curY>(DISPLAY_HEIGHT-1))
curY=0;
} // standard font
#endif
Da quello che capisco quando utilizzo la funzione oled_putch(unsigned char c), esegue queste operazioni:
u=c-FONT_START; dove "c" è l'equivalente valore decimale del carattere da stampare,
if (oled_inverted)
else
poi invia 5 bites presi dall'arrary ASCII2 con l'utilizzo di un puntatore di valore pari a u+i.
é corretta la mia interpretazione?
Hanno bisogno di coesistere?
Direi di si, visto che devo usare entrambi i font contemporaneamente.
Possono essere serializzati (il loro contenuto può essere creato/letto/esaminato byte per byte)?
Se no, possono essere spezzati in sotto-vettori riutilizzabili?
Penso di si, anche se non riesco a comprendere al 100% il funzionamento della libreria.
Hai progetti sulla RAM restante?
Vorrei integrare il display oled su un vecchio progetto di un antifurto con gps e modulo gsm, quindi dovrei provare ad unire i software e vedere se la memoria ram è sufficente.
Io ho usato con piacere QUESTA RAM SPI
Costa pochissimo ed hai 32KB a disposizione e la puoi far funzionare alla massima velocità visto che accetta un clock di 20 MHz.
Ho visto che microchip fornisce delle librerie gia pronte per l'uso di questa ram spi.
Quello che non capisco e se, una volta istallata, diventa un tutt'uno con la ram interna del PIC o la gestione è più similare ad una eprom esterna?
Nel mio esempio dovrei dichiarare una array di 500 bytes, come faccio a gestirlo con la RAM esterna?
Marcello
