Power Supplies
ECL outputs are referenced to the most positive supply rail [1]. This means that any
noise appearing on the most positive supply rail will be directly coupled onto the
output signal. For example, if the power supply is 5V and GND, then all outputs
would be referenced to 5V, and any noise on the 5V supply would also be seen at the
ECL outputs. Therefore, the older literature calls for ECL chips to be powered by a
negative power supply, such as -5V and GND [1]. By using GND as the most
positive supply rail, it is easier to maintain cleaner signals at the ECL outputs. GND
is generally found to be less noisy as compared to a non-GND potential. This does
not mean it is impossible to use a positive power supply. It does mean that
precautions must be taken to ensure very little noise is coupled onto the most positive supply rail in order to maintain clean outputs.
Sul fatto che per avere una uscita tra 0 e Vcc in una coppia differenziale ci debba essere per forza una alimentazione negativa da qualche parte sono d'accordo
