memoria arduino
[1] memoria arduino
Messaggioda Foto Utentedanielealfa » 28 dic 2019, 4:43
ciao a tutti ed auguri,
ho fatto un arrocchio con arduino prendendo pezzi qui e la per un menu con lcd , rele' ed dei led ws2812.
mi funziona bene, pero' proprio sul piu ' bello mi dice che ha poca memoria, riesco a fare funzionare 106 led su 112,
ecco il codice
Codice: Seleziona tutto
#include <Adafruit_NeoPixel.h>
#include <FastLED.h>
#define PIN 13
#define COLOR_ORDER GRB
#define LED_TYPE WS2812B
#define NUM_LEDS 106
#define BRIGHTNESS 100
#define SPEED .20       // Amount to increment RGB color by each cycle
#define BG 0
#define SPARKING 50
#define COOLING  55
#define FRAMES_PER_SECOND 60
#define ARRAY_SIZE(A) (sizeof(A) / sizeof((A)[0]))
#define qsubd(x, b)  ((x>b)?wavebright:0)                   // Digital unsigned subtraction macro. if result <0, then => 0. Otherwise, take on fixed value.
#define qsuba(x, b)  ((x>b)?x-b:0)                          // Analog Unsigned subtraction macro. if result <0, then => 0
int buttonPin = 15;    // momentary push button on pin 0
int oldButtonVal = 0;
// FOR SYLON ETC
uint8_t thisbeat =  23;
uint8_t thatbeat =  28;
uint8_t thisfade =   3;                                     // How quickly does it fade? Lower = slower fade rate.
uint8_t thissat = 255;                                     // The saturation, where 255 = brilliant colours.
uint8_t thisbri = 255;
//FOR JUGGLE
uint8_t gHue = 0; // rotating "base color" used by many of the patterns
uint8_t numdots = 4;                                          // Number of dots in use.
uint8_t faderate = 2;                                         // How long should the trails be. Very low value = longer trails.
uint8_t hueinc = 16;                                          // Incremental change in hue between each dot.
uint8_t thishue = 0;                                          // Starting hue.
uint8_t curhue = 0;
uint8_t thisbright = 255;                                     // How bright should the LED/display be.
uint8_t basebeat = 5;
uint8_t max_bright = 255;
// Twinkle
float redStates[NUM_LEDS];
float blueStates[NUM_LEDS];
float greenStates[NUM_LEDS];
float Fade = 0.96;
//Ripple variables
int color;
int center = 0;
int step = -1;
int maxSteps = 16;
float fadeRate = 0.80;
int diff;
//background color
uint32_t currentBg = random(256);
uint32_t nextBg = currentBg;
int          myhue =   0;
//One sine demo
uint8_t wavebright = 128;                                     // You can change the brightness of the waves/bars rolling across the screen. Best to make them not as bright as the sparkles.
uint8_t thisrot = 0;                                          // You can change how quickly the hue rotates for this wave. Currently 0.
uint8_t allsat = 255;                                         // I like 'em fully saturated with colour.
bool thisdir = 0;                                             // You can change direction.
int8_t thisspeed = 4;                                         // You can change the speed, and use negative values.
uint8_t allfreq = 32;                                         // You can change the frequency, thus overall width of bars.
int thisphase = 0;                                            // Phase change value gets calculated.
uint8_t thiscutoff = 192;                                     // You can change the cutoff value to display this wave. Lower value = longer wave.
int thisdelay = 25;                                           // You can change the delay. Also you can change the allspeed variable above.
uint8_t bgclr = 0;                                            // A rotating background colour.
uint8_t bgbri = 64;
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUM_LEDS, PIN, NEO_GRB + NEO_KHZ800);
int spectrumAvg [7] = { 40, 45, 55, 59, 80, 70, 230};
int boost [7] = { 0, 0, 0, 0, 200, 0, 100};
const int audioOutput = A6;  //data out of MSGEQ7
const int strobePin = 15;    //strobe on MSGEQ7
const int resetPin = 16;      //reset on MSGEQ7
int doubledSpectrumValue[13];
int avg = 0;
int raincolor = 0; //starting point of rainbow
int wait = 0;//8000; //time between modes
int spectrumValue[7]; //array to hold spectrum values
int middle = strip.numPixels() / 2;  //address of middle of strand
int length = strip.numPixels() / 7;  //splits strand up into 7 sections (7 bands on MGSGEQ7
int eqColors [7][3] = {{255, 0, 0}, {0, 255, 0}, {0, 0, 255}, {120, 120, 0}, {0, 120, 120}, {255, 0, 255}, {255, 255, 255}};
int eqColors2 [7][3] = {{255, 0, 0}, {0, 255, 0}, {0, 0, 255}, {255, 255, 255}, {102, 0, 102}, {255, 0, 127}, {255, 128, 0}};
int intensityColors [3] = {0, 0, 0};
uint32_t beginTime = 0;
uint32_t endTime = 0;
int bright = 1;    //select 1 thru 10
int filterValue = 115; // MSGEQ7 always spits out a number around 60, so this filters those out
int global_brightness = 96; // Sets global brightness, i.e. 64 is 1/4 brightness.
int waveSize = 10; // size 4 uses 9 lights. One in the middle, 4 on each side.  (time 7 for 63 LEDs total)
//pixels used is (wave size * 2)+1)*7
int maxOverflow = 3;
// Modes
enum
} MODE;
bool reverse = true;
int BRIGHTNESS_MAX = 80;
int brightness = 20;
int nPatterns = 16;
int lightPattern = 1;
bool gReverseDirection = false;
CRGB leds[NUM_LEDS];
/*  ARDUINO MENU selezionabile con 4 OPZIONI e Display LCD I2C
    (Temperatura, Led Verde, Led Rosso, Relè)
    Per maggiori info visitate www.progettiarduino.com
    Autore Fancello Salvatore
#include <OneWire.h>
#include <DallasTemperature.h>
#include <Wire.h>
#include <LiquidCrystal_I2C.h>
LiquidCrystal_I2C lcd(0x27, 16, 2); // set the LCD address to 0x27 for a 16 chars and 2 line display
#define ONE_WIRE_BUS 2   // Data wire is plugged into pin 2 on the Arduino
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
#define butUp        11    //pulsante SU al pin 11
#define butDown     10     //Pulsante GIU al pin 10
#define butP        12       //Pulsante SELEZIONA al pin 12
#define butM          9     //non utilizzato in questo esempio
#define alim     7     //Rele' alimentatore pin 8
#define sald   4    //rele' saldatore al pin 7
#define vu    3  //Relè vu meter pin 8
#define plus  8  //Relè vu meter pin 8
#define FAN 6 //IRF520 MOS Driver SUL PIN 6
#define luce 5 //IRF520 MOS Driver SUL PIN 5
int fanSpeed;  //VARIABILE VELOCITà VENTOLA
int fanpwm;  //VARIABILE PWM
int fanSpeedPercent; //VARIABILE % VELOCITà VENTOLA
int valore;
int impulso;
//Funzioni dei vari cicli
void changeMenu();
void dispMenu();
void mostraMsg();
void alimentatore();
void saldatore();
void vumeter();
void temperatura();
void porta();
void colorWipe();
void colorWipe2();
void ripple();
void one_color_allHSV();
void ripple2();
void FirePurp();
void SineDemo();
void ChangeYou();
void one_sin();
void resetvar();
void sinelon();
void pattern3();
void juggle();
void ChangeMe();
void fireblu();
void fire();
void VuOne();
void VuThree();
void readaudio();
void VuTwo();
void VuSix();
void VuFour();
void VuFive();
void sevenWaves();
void sevenBands();
void nextLed();
void All();
void Off();
void lampa();
//Variabili globali
char menu = 0x01;
char set1 = 0x00, set2 = 0x00 , set3 = 0x00 , set4 = 0x00, set5 = 0x00,set6 = 0x00;
boolean t_butUp, t_butDown, t_butP, t_butM;
void setup() {
  FastLED.addLeds<WS2812B, PIN, COLOR_ORDER>(leds, NUM_LEDS).setCorrection( TypicalLEDStrip );
  LEDS.addLeds<LED_TYPE, PIN, COLOR_ORDER>(leds, NUM_LEDS);
  strip.begin();
  strip.setBrightness(255);
  strip.show();
  pinMode(audioOutput, INPUT);
  pinMode(strobePin, OUTPUT);
  pinMode(resetPin, OUTPUT);
  analogReference(DEFAULT);
  digitalWrite(resetPin, LOW);
  digitalWrite(strobePin, HIGH);
  pinMode(buttonPin, INPUT);
  digitalWrite(buttonPin, HIGH);  // button pin is HIGH, so it drops to 0 if pressed
  lcd.init();                      // initialize the lcd
  lcd.init();
  // Print a message to the LCD.
  lcd.backlight();
  lcd.setCursor(0, 0);
  lcd.print("ALIMENTATORE");
  delay(500);
  for (char i = 9; i < 13; i++) {            //Ingresso dei pulsanti
    pinMode(i, INPUT_PULLUP);
  pinMode(luce, OUTPUT);
  pinMode(alim, OUTPUT);               //LED ROSSO
  pinMode(sald, OUTPUT);        //LED VERDE
  pinMode(vu, OUTPUT);            //RELÈ
  pinMode(plus, OUTPUT);
  digitalWrite (alim, LOW);    //Imposto inizialmente il relè allo stato Alto (Attivo)
  digitalWrite (sald, LOW);
  digitalWrite (vu, LOW);
  digitalWrite (plus, LOW);
  analogWrite (luce, 240);
  t_butUp    = 0x00;                     //Inizializza le variabili come ZERO
  t_butDown = 0x00;
  t_butP    = 0x00;
  t_butM    = 0x00;
void loop() {
  sensors.requestTemperatures(); // Send the command to get tem
  float TEMP = sensors.getTempCByIndex(0);  //VARIABILE FLOTTANTE PER LETTURA TEMPERATURA
  if (TEMP < 24) { //SE TEMP è < 23.8 °C LA VENTOLA è FERMA
    analogWrite(FAN, 0);  // comando pin off
    fanSpeed = 0;
  if ((TEMP >= 24.1) && (TEMP <= 38)) {   // setta temp min/max
    fanSpeed = map(TEMP, 24, 38, 100, 255);
    fanpwm = map(TEMP, 24, 38, 128, 255);
    fanSpeedPercent = (TEMP - 24) * 100 / (38 - 24); // Solo per essere sicuri di non avere valori incongruenti
    fanSpeedPercent = constrain(fanSpeedPercent, 0, 100);
    analogWrite(FAN, fanpwm);
  changeMenu();                        //Menu di scambio
  dispMenu();                        //Selezionare il menu
//Funzioni
void changeMenu() {
  if (digitalRead(butUp) == 0x00) {            //Setta la variabile in 1 se si preme il pulsante UP
    t_butUp = 0x01;
  if (digitalRead(butDown) == 0x00) {         //Setta la variabile in 1 se si preme il pulsante DOWN
    t_butDown = 0x01;
  if (digitalRead(butUp) && t_butUp) {
    t_butUp = 0x00;
    lcd.clear();        //Cancella Schermo lcd
    menu++;
    if (menu > 0x06) {
      menu = 0x01;
  if (digitalRead(butDown) && t_butDown) {
    t_butDown = 0x00;
    lcd.clear();
    menu--;
    if (menu < 0x01) {
      menu = 0x06;
void dispMenu() {
  switch (menu) {
    case 0x01:
      temperatura();  //Funzione controllo  temperatura
      break;
    case 0x02:
      vumeter();      //Funzione controllo  vumeter
      break;
    case 0x03:
      alimentatore();  //Funzione controllo  alimentatore
      break;
    case 0x04:
      saldatore();     //Funzione controllo  saldatore
      break;
    case 0x05:
      porta ();  //Funzione controllo  alimentatore
      break;
    case 0x06:
      lampa ();  //Funzione controllo  alimentatore
      break;
/*Ciclo per la funzione controllo LED1*/
void lampa(){
  lcd.clear();
    lcd.print("luce");  //scrivo su lcd
  int buttonVal = digitalRead(12);
  if (buttonVal == LOW && oldButtonVal == HIGH) {// button has just been pressed
    lightPattern = lightPattern + 1;
  if (lightPattern > nPatterns) lightPattern = 1;
  oldButtonVal = buttonVal;
  switch(lightPattern) {
    case 1:
     VuOne();
       break;
       case 2:
      VuTwo();
       break;
      case 3:
      VuThree();
     break;
     case 4:
      VuFour();
      break;
    case 5:
     VuFive();
      break;
    case 6:
      VuSix();
      break;
    case 7:
     All();
     break;
     case 8:
     SineDemo();
     break;
     case 9:
     ripple();
     break;
     case 10:
   ripple2();
      break;
     case 11:
   sinelon();
      break;
       case 12:
   pattern3();
      break;
      case 13:
      fire();
      break;
      case 14:
     fireblu();
      break;
       case 15:
     FirePurp();
      break;
      case 16:
       Off();
      break;
void alimentatore() {
  lcd.clear();
  if (digitalRead(alim)   == HIGH) { //leggo lo stato del rele' alim
    lcd.print("Alimentatore ON"); // scrivo su lcd
  else {
    lcd.print("Alimentatore Off");  // scrivo su lcd
  if (digitalRead(butP) == 0x00) {
    t_butP = 0x01;
  if (digitalRead(butM) == 0x00) {
    t_butM = 0x01;
  if (digitalRead(butP) && t_butP) {
    t_butP = 0x00;
    set1++;
    if (set1 > 2) {
      set1 = 0x01;
    switch (set1) {
      case 0x01:
        digitalWrite (alim, HIGH);  //attivo rele' alimentatore
        break;
      case 0x02:
        digitalWrite (alim, LOW);  //Spengo rele' alimentatore
        break;
/*Ciclo per la funzione controllo Relè*/
void vumeter() {
  lcd.clear();
  if (digitalRead(vu)   == HIGH) { //leggo lo stato del rele'
    lcd.print("vu ON");  //scrivo su lcd
  } else {
    lcd.print("vu OOff"); //scrivo su lcd
    t_butP = 0x01;
    t_butM = 0x01;
    t_butP = 0x00;
    set2++;
    if (set2 > 2) {
      set2 = 0x01;
    switch (set2) {
      case 0x01:
        digitalWrite (vu, HIGH); //attivo rele' alimentatore
        break;
      case 0x02:
        digitalWrite (vu, LOW); //Spengo rele' alimentatore
        break;
/*Ciclo per la funzione controllo TEMPERATURA*/
void temperatura()
  lcd.setCursor(0, 1);
  lcd.print((char)316);
  lcd.setCursor(8, 1);
  lcd.print((char)767);
  lcd.setCursor(15, 1);
  lcd.print((char)318);
  lcd.print("Temperatura: ");
  lcd.setCursor(1, 1);
  lcd.print(sensors.getTempCByIndex(0)); // chiamo lettura sensore
  lcd.print((char)223);
  if (fanSpeedPercent > 9) lcd.print(" ");
  lcd.setCursor(10, 1);
  if (fanSpeedPercent < 10) lcd.print(" ");
  lcd. print(fanSpeedPercent);
/*Ciclo per la funzione controllo Led Verde*/
void saldatore() {
  if (digitalRead(sald)   == HIGH) { //leggo lo stato del rele'
    lcd.print("saldatore On ");  // srivo su lcd
  } else {
    lcd.print("saldatore OFF");  //scrivo su lcd
    t_butP = 0x01;
    t_butM = 0x01;
    t_butP = 0x00;
    set3++;
    if (set3 > 2) {
      set3 = 0x01;
    switch (set3) {
      case 0x01:
        digitalWrite (sald, HIGH); //attivo rele' alimentatore
        break;
      case 0x02:
        break;
void porta() {
  if (digitalRead(plus)   == HIGH) { //leggo lo stato del rele' alim
    lcd.print("porta ON"); // scrivo su lcd
  } else {
    lcd.print("porta off");  // scrivo su lcd
    t_butP = 0x01;
    t_butM = 0x01;
    t_butP = 0x00;
    set4++;
    if (set4 > 2) {
      set4 = 0x01;
    switch (set4) {
      case 0x01:
        digitalWrite (plus, HIGH);  //attivo rele' alimentatore
        break;
      case 0x02:
        digitalWrite (plus, LOW);  //Spengo rele' alimentatore
        break;
void colorWipe(uint32_t c, uint8_t wait) {
  for(uint16_t i=0; i<strip.numPixels(); i++) {
    strip.setPixelColor(i, c);
    strip.show();
    delay(wait);
void colorWipe2(uint32_t c, uint8_t wait) {
      strip.show();
       delay(wait);
// Pattern 5 - black / off
    void Off() {
     colorWipe2(strip.Color(  0, 0, 0), 1); // black
      strip.show();
void ripple() {
    if (currentBg == nextBg) {
      nextBg = random(256);
    else if (nextBg > currentBg) {
      currentBg++;
    } else {
      currentBg--;
    for(uint16_t l = 0; l < NUM_LEDS; l++) {
      leds[l] = CHSV(currentBg, 255, 50);         // strip.setPixelColor(l, Wheel(currentBg, 0.1));
  if (step == -1) {
    center = random(NUM_LEDS);
    color = random(256);
    step = 0;
  if (step == 0) {
    leds[center] = CHSV(color, 255, 255);         // strip.setPixelColor(center, Wheel(color, 1));
    step ++;
  else {
    if (step < maxSteps) {
      Serial.println(pow(fadeRate,step));
      leds[wrap(center + step)] = CHSV(color, 255, pow(fadeRate, step)*255);       //   strip.setPixelColor(wrap(center + step), Wheel(color, pow(fadeRate, step)));
      leds[wrap(center - step)] = CHSV(color, 255, pow(fadeRate, step)*255);       //   strip.setPixelColor(wrap(center - step), Wheel(color, pow(fadeRate, step)));
      if (step > 3) {
        leds[wrap(center + step - 3)] = CHSV(color, 255, pow(fadeRate, step - 2)*255);     //   strip.setPixelColor(wrap(center + step - 3), Wheel(color, pow(fadeRate, step - 2)));
        leds[wrap(center - step + 3)] = CHSV(color, 255, pow(fadeRate, step - 2)*255);     //   strip.setPixelColor(wrap(center - step + 3), Wheel(color, pow(fadeRate, step - 2)));
      step ++;
    else {
      step = -1;
  LEDS.show();
  delay(50);
int wrap(int step) {
  if(step < 0) return NUM_LEDS + step;
  if(step > NUM_LEDS - 1) return step - NUM_LEDS;
  return step;
void one_color_allHSV(int ahue, int abright) {                // SET ALL LEDS TO ONE COLOR (HSV)
  for (int i = 0 ; i < NUM_LEDS; i++ ) {
    leds[i] = CHSV(ahue, 255, abright);
void ripple2() {
   if (BG){
      currentBg++;
    } else {
      currentBg--;
  } else {
      strip.setPixelColor(l, 0, 0, 0);
  if (step == -1) {
    step = 0;
  if (step == 0) {
    step ++;
  else {
        if (step > 3) {
      step ++;
    else {
      step = -1;
  strip.show();
   delay(50);
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos, float opacity) {
  if(WheelPos < 85) {
    return strip.Color((WheelPos * 3) * opacity, (255 - WheelPos * 3) * opacity, 0);
  else if(WheelPos < 170) {
    WheelPos -= 85;
    return strip.Color((255 - WheelPos * 3) * opacity, 0, (WheelPos * 3) * opacity);
  else {
    WheelPos -= 170;
    return strip.Color(0, (WheelPos * 3) * opacity, (255 - WheelPos * 3) * opacity);
void FirePurp()
// Array of temperature readings at each simulation cell
  static byte heat[NUM_LEDS];
  // Step 1.  Cool down every cell a little
    for( int i = 0; i < NUM_LEDS; i++) {
      heat[i] = qsub8( heat[i],  random8(0, ((COOLING * 10) / NUM_LEDS) + 2));
    // Step 2.  Heat from each cell drifts 'up' and diffuses a little
    for( int k= NUM_LEDS - 1; k >= 2; k--) {
      heat[k] = (heat[k - 1] + heat[k - 2] + heat[k - 2] ) / 3;
    // Step 3.  Randomly ignite new 'sparks' of heat near the bottom
    if( random8() < SPARKING ) {
      int y = random8(7);
      heat[y] = qadd8( heat[y], random8(160,255) );
    // Step 4.  Map from heat cells to LED colors
    for( int j = 0; j < NUM_LEDS; j++) {
      // Scale the heat value from 0-255 down to 0-240
      // for best results with color palettes.
      byte colorindex = scale8( heat[j], 240);
      CRGB color = ColorFromPalette( CRGBPalette16( CRGB::Black, CRGB::Purple, CRGB::Purple, CRGB::White), colorindex);
      int pixelnumber;
      if( gReverseDirection ) {
        pixelnumber = (NUM_LEDS-1) - j;
      } else {
        pixelnumber = j;
      leds[pixelnumber] = color;
     FastLED.show(BRIGHTNESS);
void SineDemo() {
  ChangeYou();                                                 // Muck those variables around.
  EVERY_N_MILLISECONDS(thisdelay) {                           // FastLED based non-blocking delay to update/display the sequence.
    one_sin();
    bgclr++;
  show_at_max_brightness_for_power();
} // loop()
void ChangeYou() {
  uint8_t secondHand = (millis() / 1000) % 60;                // Increase this if you want a longer demo.
  static uint8_t lastSecond = 99;                             // Static variable, means it's only defined once. This is our 'debounce' variable.
  // You can change variables, but remember to set them back in the next demo, or they will stay as is.
  if(lastSecond != secondHand) {
    lastSecond = secondHand;
    switch (secondHand) {
      case  0: thisrot = 1; thiscutoff=252; allfreq=8; break; // Both rotating hues
      case  5: thisrot = 0; thisspeed=-4; break;              // Just 1 rotating hue
      case 10: thishue = 255; break;                          // No rotating hues, all red.
      case 15: thisrot = 1; thisspeed=2; break;               //
      case 20: allfreq = 16; break;                           // Time to make a wider bar.
      case 25: thishue=100; thiscutoff = 96; break;           // Change width of bars.
      case 30: thiscutoff = 96; thisrot = 1; break;           // Make those bars overlap, and rotate a hue
      case 35: thisspeed = 3; break;                          // Change the direction.
      case 40: thiscutoff = 128; wavebright = 64; break;      // Yet more changes
      case 45: wavebright = 128; thisspeed = 3; break;        // Now, we change speeds.
      case 50: thisspeed = -2; break;                         // Opposite directions
      case 55: break;                                         // Getting complicated, let's reset the variables.
} // ChangeMe()
void one_sin() {        // This is the heart of this program. Sure is short.
//  if (thisdir == 0) thisphase+=thisspeed; else thisphase-=thisspeed;          // You can change direction and speed individually.
    thisphase += thisspeed;
    thishue += thisrot;                                                         // Hue rotation is fun for thiswave.
  for (int k=0; k<NUM_LEDS-1; k++) {
    int thisbright = qsubd(cubicwave8((k*allfreq)+thisphase), thiscutoff);      // qsub sets a minimum value called thiscutoff. If < thiscutoff, then bright = 0. Otherwise, bright = 128 (as defined in qsub)..
    leds[k] = CHSV(bgclr, 255, bgbri);
    leds[k] += CHSV(thishue, allsat, thisbright);                               // Assigning hues and brightness to the led array.
} // one_sin()
void resetvar() {                                             // Reset the variable back to the beginning.
  thishue = 0;                                                // You can change the starting hue value for the first wave.
  bgbri = 16;
} // resetvar()
void sinelon() {
  // a colored dot sweeping back and forth, with fading trails
  fadeToBlackBy( leds, NUM_LEDS, thisfade);
  int pos1 = beatsin16(thisbeat,0,NUM_LEDS);
  int pos2 = beatsin16(thatbeat,0,NUM_LEDS);
    leds[(pos1+pos2)/2] += CHSV( myhue++/64, thissat, thisbri);
FastLED.show();
    void pattern3() {
       ChangeMe();
  juggle();
  show_at_max_brightness_for_power();                         // Power managed display of LED's.
} // loop()
void juggle() {                                               // Several colored dots, weaving in and out of sync with each other
  curhue = thishue;                                          // Reset the hue values.
  fadeToBlackBy(leds, NUM_LEDS, faderate);
  for( int i = 0; i < numdots; i++) {
    leds[beatsin16(basebeat+i+numdots,0,NUM_LEDS)] += CHSV(curhue, thissat, thisbright);   //beat16 is a FastLED 3.1 function
    curhue += hueinc;
} // juggle()
void ChangeMe() {                                             // A time (rather than loop) based demo sequencer. This gives us full control over the length of each sequence.
  uint8_t secondHand = (millis() / 1000) % 30;                // IMPORTANT!!! Change '30' to a different value to change duration of the loop.
  if (lastSecond != secondHand) {                             // Debounce to make sure we're not repeating an assignment.
    if (secondHand ==  0)  {numdots=1; faderate=2;}  // You can change values here, one at a time , or altogether.
    if (secondHand == 10)  {numdots=4; thishue=128; faderate=8;}
    if (secondHand == 20)  {hueinc=48; thishue=random8();}                               // Only gets called once, and not continuously for the next several seconds. Therefore, no rainbows.
} // ChangeMe()
void fireblu(){
#define FRAMES_PER_SECOND 40
random16_add_entropy( random());
      int y = random8(7);
      CRGB color = ColorFromPalette( CRGBPalette16( CRGB::Black, CRGB::Blue, CRGB::Aqua,  CRGB::White), colorindex);
      int pixelnumber;
      } else {
        pixelnumber = j;
  void fire(){
      int y = random8(7);
      CRGB color = ColorFromPalette( CRGBPalette16( CRGB::Black, CRGB::Red, CRGB::Yellow,  CRGB::White), colorindex);
      int pixelnumber;
      } else {
        pixelnumber = j;
void VuOne(){
  readaudio();
  int y=0;
  for(int i=0; i<7; i++){
    int intensity = map(spectrumValue[i], 0, 900, 0, 9);
    for(int j=(length*i); j<(length*(i+1)); j++){
      if(intensity > (j-(length*i))){
        //strip.setPixelColor(j, strip.Color(eqColors[i][0], eqColors[i][1], eqColors[i][2]));
         strip.setPixelColor(y, (Wheel(y*4)));
         y++;
      else{
        strip.setPixelColor(j, strip.Color(0,0,0));
  strip.setBrightness(100);
  strip.show();
void VuThree(){
  readaudio();
  int intensity[7];
  int total;
  int y=0;
    intensity[i] = map(spectrumValue[i], 0, 900, 0, 9);
    total+= intensity[i];
  for(int m=0; m<7; m++){
    for(int p=0; p<intensity[m]; p++){
      strip.setPixelColor(y, strip.Color(eqColors2[m][0], eqColors2[m][1], eqColors2[m][2]));
      //strip.setPixelColor(y, (Wheel(y*4)));
      y++;
  for(int k=total; k<strip.numPixels(); k++){
    strip.setPixelColor(k, strip.Color(0,0,0));
  strip.show();
  for(int j=0; j<strip.numPixels(); j++){
  delay(30);
void readaudio(){
  digitalWrite(resetPin, HIGH);
    digitalWrite(strobePin, LOW);
    delayMicroseconds(30); //allow output levels to settle
    spectrumValue[i]=analogRead(audioOutput) - spectrumAvg[i];
uint32_t Wheel(byte WheelPos) {
  if(WheelPos < 85) {
   return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
  } else if(WheelPos < 170) {
   WheelPos -= 85;
   return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
  } else {
   WheelPos -= 170;
   return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
void VuTwo()
  //Measure the magnitudes of the 7 frequency bins
  avg = 0;
  for (int i = 0; i < 7; i++){
    delayMicroseconds(30); // to allow the output to settle
    spectrumValue[i] = analogRead(audioOutput);
    avg += spectrumValue[i];
  avg = avg/7;
  //Clear out the NeoPixel String
  for(int i = 0; i < 60; i++){
    strip.setPixelColor(i, strip.Color(0, 0, 0));
  //Draw the meter on the NeoPixel string
  for(int i = 0; i < map(avg, 0, 1023, 0, 60); i++){
    strip.setPixelColor(i, strip.Color(i*4, 60 - i, map(spectrumValue[0], 0, 1023, 0, 60))); //Added blue flash for bass hit
    //strip.setPixelColor(i, strip.Color(i*4, 60 - i, 0)); //Without blue flash
  strip.setBrightness(225);
  strip.show();
void VuSix(){
  int i;
  int j;
  int loopEnd;
  int numPixels = strip.numPixels() - 5;
  double pixRatio = (float)numPixels / 255;
  double channelRatio = pixRatio / 7;
  float weight =1;
//grabs readings from chip
  for (i = 0; i < 7; i++)
    //weight = 1;
    if (i < 3)
     weight = 1.5;
    else
      weight = 1;
      //makes 10 bit value 8 bit
    spectrumValue[i] /= 4;
    spectrumValue[i] = (int)( (double)spectrumValue[i] * (channelRatio * weight) );
    if(spectrumValue[i] > 255)
     spectrumValue[i] = 255;
for (i = 0;i<spectrumValue[0] && i< numPixels; i++)
  strip.setPixelColor(i, 255, 0, 0);
loopEnd = i + spectrumValue[1];
for (;i<loopEnd && i< numPixels; i++)
  strip.setPixelColor(i,0, 255, 0);
loopEnd = i + spectrumValue[2];
  strip.setPixelColor(i,0,0, 255);
loopEnd = i + spectrumValue[3];
  strip.setPixelColor(i,255, 0,255);
loopEnd = i + spectrumValue[4];
  strip.setPixelColor(i,255, 255, 0);
loopEnd = i + spectrumValue[5];
  strip.setPixelColor(i,255, 128, 0);
loopEnd = i + spectrumValue[6];
  strip.setPixelColor(i,255,255,255);
  for(;i<numPixels; i++)
  strip.setPixelColor(i,0,0,0);
  for (i = numPixels;i>numPixels-spectrumValue[0] && i>0; i--)
loopEnd = i - spectrumValue[1];
for (;i>loopEnd && i>0; i--)
loopEnd = i - spectrumValue[2];
loopEnd = i - spectrumValue[3];
loopEnd = i - spectrumValue[4];
loopEnd = i - spectrumValue[5];
loopEnd = i - spectrumValue[6];
  strip.show();
void VuFour(){
int i = 0, j= 0,k =0;
//    delayMicroseconds(30); // to allow the output to settle
      if (spectrumValue[i] <= 55)
       spectrumValue[i] = 0;
     spectrumValue[i] = (int)(spectrumValue[i] / 7);
     if (i == 0)
      spectrumValue[i] *= 1.5;
     else
      spectrumValue[i] *= 1.2;
    for (j=0; j<27; j++)
    if (i == 0 && spectrumValue[i] >=j)
     strip.setPixelColor(k++,255, 0,0);
    else if (i == 1 && spectrumValue[i] >=j)
     strip.setPixelColor(k++,0, 255, 0);
    else if (i == 2 && spectrumValue[i] >=j)
     strip.setPixelColor(k++,0,0, 255);
    else if (i == 3 && spectrumValue[i] >=j)
     strip.setPixelColor(k++,255, 0, 255);
    else if (i == 4 && spectrumValue[i] >=j)
     strip.setPixelColor(k++,0, 255,255);
    else if (i == 5 && spectrumValue[i] >=j)
     strip.setPixelColor(k++,255, 255,0);
    else if (i == 6 && spectrumValue[i] >=j)
     strip.setPixelColor(k++,255,255,255);
    else
     strip.setPixelColor(k++,0,0,0);
    delay(2);
      strip.show();
void VuFive() {
   sevenWaves();
void sevenWaves(){
  int i;
  int k;
  int tmpVal;
  int r;
  int g;
  int b;
  int j;
  int x;
  int q;
  int middlePin;
  //int overflow[77];
  //get readings from chip
    //delayMicroseconds(30); // to allow the output to settle
    if (i==0)
      middlePin = waveSize +1;
    else
      middlePin =  waveSize + 1 + (  (1 + waveSize * 2) * i);
    for (k = (middlePin - waveSize); k <= (middlePin + waveSize); k++)
      int pinOutValue = 0;
      int reading;
       reading = round( spectrumValue[i]*5 / (600) );
      int placeInWave = abs(k - middlePin);
      if( reading >= placeInWave)
        pinOutValue = 1;
      if( spectrumValue[i] < filterValue)
        pinOutValue = 0;
     if(pinOutValue==1)
       pinOutValue = 255;
      // RGB for bands 1-7
      if(i==0)
        r = 0; g = 0; b = 255;
      if(i==1)
        r = 0; g = 255; b= 0;
      if(i==2)
        r = 255; g = 255; b = 0;
      if(i==3)
        r = 0; g = 255; b = 0;
      if(i==4)
        r = 0; g = 255; b = 255;
      if(i==5)
        r = 0; g = 0 ; b = 255;
      if(i==6)
        r = 255; g = 0; b = 153;
      if (pinOutValue == 0)
        r = 0; g = 0; b = 0;
      strip.setPixelColor(k-1, r, g, b);
  strip.setBrightness(global_brightness);
  strip.show();
void sevenBands(){
  int i;
  if(spectrumValue[i] < filterValue)
spectrumValue[i] = spectrumValue[i] / (1024/255);
  strip.setPixelColor(0, spectrumValue[6], 0, 0);
  strip.setPixelColor(1, spectrumValue[5], 0, 0);
  strip.setPixelColor(2, spectrumValue[4], 0, 0);
  strip.setPixelColor(3, spectrumValue[3], 0, 0);
  strip.setPixelColor(4, spectrumValue[2], 0, 0);
  strip.setPixelColor(5, spectrumValue[1], 0, 0);
  strip.setPixelColor(6, spectrumValue[0], 0, 0);
  strip.show();
void nextLed(int r, int g, int b, int wait){
static int currentLed = 0;
strip.setPixelColor(currentLed, r, g, b);
delay(wait);
//if (currentLed % 4 == 0)
// strip.show();
currentLed++;
if (currentLed >= strip.numPixels() ){
  currentLed = 0;
  strip.show();
// List of patterns to cycle through.  Each is defined as a separate function below.
typedef void (*SimplePatternList[])();
SimplePatternList gPatterns = {SineDemo, pattern3, ripple, ripple2, sinelon, fire, fireblu, FirePurp};
uint8_t gCurrentPatternNumber = 0; // Index number of which pattern is current
void nextPattern()
  // add one to the current pattern number, and wrap around at the end
  gCurrentPatternNumber = (gCurrentPatternNumber + 1) % ARRAY_SIZE( gPatterns);
void All()
  // Call the current pattern function once, updating the 'leds' array
  gPatterns[gCurrentPatternNumber]();
  EVERY_N_SECONDS( 30 ) { nextPattern(); } // change patterns periodically
credo che possa risparmiare qualcosa modificando questo"
ma non ne sono sicuro, se qualcuno gentilmente mi sa rarmi un aiuto su come aggiustare il programma mi farebbe un enorme piacere...sicuramente ho fatto tanti errori,ma come ho detto sono pezzi presi qui e la...
per il momento vi ringrazio
e vi auguro buone feste
243 2 4 7
[2] Re: memoria arduino
Messaggioda Foto Utenteluxinterior » 28 dic 2019, 10:00
Immagino succeda quando cerchi di compilare il prgramma.
Non uso arduino perciò non sono in grado di aiutarti vedo però nel tuo listato una quantità industriale di variabili.
esamina il codice con attenzione dovresti ruiscire in qualche modo a ridurre le variabili.
Ho visto che usi dei float "a naso" usare i float per controllare la luminosità dei led (se ho capito bene l'utilizzo) mi sembra eccessivo se passi a intero dimezzi subito la memoria necessaria. Passare a intero significa lavorare con virgola in posizione fissa, ad esempio i centesimi, il tuo Fade=0,96 diventa Fade=96 ma poi devi stare attento a come fai i conti per non avere overflow. Insomma non è facile spiegare
4.311 3 4 9
[3] Re: memoria arduino
Messaggioda Foto Utentedanielealfa » 28 dic 2019, 11:44
ciao e grazie della tua risposta.
si succede mentre lo carico, lo ho gia' preso fatto il programma, io non riuscirei a farlo io...
vedo se riesco come mi hai detto te...
243 2 4 7
5
[4] Re: memoria arduino
Messaggioda Foto Utenteboiler » 28 dic 2019, 12:23
danielealfa ha scritto:ho fatto un arrocchio con arduino prendendo pezzi qui e la per un menu con lcd , rele' ed dei led ws2812.
E qui cominciano i problemi.
Non lo farà nessuno. Non ha niente a che vedere con gentilezza, disponibilità o simpatia.
Ho dato il "tuo" codice in pasto a CCCC, che mi ha sputato una complessità ciclomatica di 228 :-
Per capirci, il significato di questo numero s'ha da interpretare come segue:
< 10: programma ben strutturato, testabile e mantenibile
10 < 20: programma con una struttura complessa, accettabile a certe condizioni
20 < 50: programma poco testabile e mantenibile, refactoring necessario
> 50: programma non testabile e non mantenibile. Sintomo di erosione avanzata
Ci sono anche altre metriche interessanti. Per esempio il tuo file ha 1029 linee di codice e 51 funzioni. Una roba così va imperativamente suddivisa in piú moduli!
Quello che tu hai fatto equivale a prendere un centinaio di cavi, ingarbugliarli e chiedere se c'è qualcuno che ha la gentilezza di snodarli e riavvolgerli. L'unica soluzione è il tronchesino.
Boiler
Foto Utenteboiler
26,4k 5 9 13
[5] Re: memoria arduino
Messaggioda Foto Utentedanielealfa » 28 dic 2019, 12:50
grazie della risposta, in parole semplici, per riuscite ad guadagnare quel poco di memoria per mettere in funzione gli altri pochi led, come potrei fare ?
243 2 4 7
[6] Re: memoria arduino
Messaggioda Foto Utenteboiler » 28 dic 2019, 12:56
Capire cosa fa il codice che hai copiato e adattarlo alle tue esigenze.
Boiler
Foto Utenteboiler
26,4k 5 9 13
-2
[7] Re: memoria arduino
Messaggioda Foto Utentedanielealfa » 28 dic 2019, 13:38
troppo complicato per me...
se mettessi 2 nano in seriale e quando vado nel void lamp dal master , invio il comando del tasto allo slave, che mi risponde il void che effettua sarebbe piu' facile?
243 2 4 7
[8] Re: memoria arduino
Messaggioda Foto Utenteboiler » 28 dic 2019, 14:09
danielealfa ha scritto:troppo complicato per me...
Anche per me... anche per me...
Boiler
Foto Utenteboiler
26,4k 5 9 13
[9] Re: memoria arduino
Messaggioda Foto Utentexyz » 28 dic 2019, 14:42
Ti faccio un semplice elenco di cose che ho notato nel codice che hai allegato:
    ▪ Come ti è stato detto usi il float quando basta un unsigned char con un fattore di scala e lo hai fatto per un array, peggio ancora, consumi tanta RAM.
    ▪ Include e define messi in mezzo al codice, indentazione confusa e fatta male, rende tutto il codice poco leggibile.
    ▪ Troppe variabili globali, si consuma RAM e poi sono fonti di possibili bug.
    ▪ Dichiari un enum vuoto, è inutile.
    ▪ Utilizzo di numeri per stati senza l'utilizzo di un define con nome adeguato, rende difficile comprendere il codice.
    ▪ Utilizzo della funzione pow, è molto lenta e esistono alternative più efficienti visto che l'esponente è intero.
    ▪ Parti di codice replicate senza utilizzare funzioni generiche, il codice diventa molto voluminoso e rischia di non entrare nella memoria flash
Sei libero di tenerlo, io ti consiglio di studiare meglio la programmazione, esaminare i programmi scritti dagli altri e di riscriverlo. Il codice per i microcontrollori deve essere semplice ed efficiente, altrimenti le poche risorse a disposizione non sono sufficienti e non puoi lamentati del consumo eccessivo di RAM.
Foto Utentexyz
6.864 2 4 6
[10] Re: memoria arduino
Messaggioda Foto Utenterugweri » 28 dic 2019, 14:44
COSA? ?%
Per decenza, chiudo questo topic.
Foto Utenterugweri
5.948 2 8 13
Torna a Arduino
