daniele1996 ha scritto:9. Bus Loading
Adding transceivers and failsafe circuits to an RS-485 bus increases the total load current required because the
output of a driver depends on the current it must supply into a load. To estimate the maximum number of bus
loads possible, RS-485 defines a unit load (UL), which represents a load impedance of approximately 12kΩ.
Standard compliant drivers can drive up to 32 of these unit loads. Some modern transceivers provide reduced unit
loading, such as 1/8 UL, which allows the connection of up to 256 transceivers on the bus.
Cosa dice ESATTAMENTE questo passaggio riguardo le resistenze di polarizzazione?
Boiler
