- Codice: Seleziona tutto
import numpy as np
import cv2
import cv2 as cv
import sys
class NeuralNetwork:
def __init__(self, input_size, hidden_size, output_size):
self.input_size = input_size
self.hidden_size = hidden_size
self.output_size = output_size
self.weights_input_hidden = np.random.randn(self.input_size, self.hidden_size)
self.weights_hidden_output = np.random.randn(self.hidden_size, self.output_size)
self.bias_hidden = np.zeros((1, self.hidden_size))
self.bias_output = np.zeros((1, self.output_size))
def sigmoid(self, x):
return 1 / (1 + np.exp(-x))
def sigmoid_derivative(self, x):
return x * (1 - x)
def feedforward(self, X):
self.hidden_activation = np.dot(X, self.weights_input_hidden) + self.bias_hidden
self.hidden_output = self.sigmoid(self.hidden_activation)
self.output_activation = np.dot(self.hidden_output, self.weights_hidden_output) + self.bias_output
self.predicted_output = self.sigmoid(self.output_activation)
return self.predicted_output
def backward(self, X, y, learning_rate):
output_error = y - self.predicted_output
output_delta = output_error * self.sigmoid_derivative(self.predicted_output)
hidden_error = np.dot(output_delta, self.weights_hidden_output.T)
hidden_delta = hidden_error * self.sigmoid_derivative(self.hidden_output)
self.weights_hidden_output += np.dot(self.hidden_output.T, output_delta) * learning_rate
self.bias_output += np.sum(output_delta, axis=0, keepdims=True) * learning_rate
self.weights_input_hidden += np.dot(X.T, hidden_delta) * learning_rate
self.bias_hidden += np.sum(hidden_delta, axis=0, keepdims=True) * learning_rate
def train(self, X, y, epochs, learning_rate):
for epoch in range(epochs):
output = self.feedforward(X)
self.backward(X, y, learning_rate)
if epoch % 4000 == 0:
loss = np.mean(np.square(y - output))
print(f"Epoch {epoch}, Loss:{loss}")
IMAGE1 = 'day_open.jpg'
IMAGE2 = 'day_closed.jpg'
IMAGE3 = 'night_open.jpg'
IMAGE4 = 'night_closed.jpg'
image1 = cv2.imread(IMAGE1)
image2 = cv2.imread(IMAGE2)
image3 = cv2.imread(IMAGE3)
image4 = cv2.imread(IMAGE4)
gray_image1 = cv2.cvtColor(image1, cv2.COLOR_BGR2GRAY)
res1 = cv.resize(gray_image1,(1800, 1800), interpolation = cv.INTER_CUBIC)
gray_image2 = cv2.cvtColor(image2, cv2.COLOR_BGR2GRAY)
res2 = cv.resize(gray_image2,(1800, 1800), interpolation = cv.INTER_CUBIC)
gray_image3 = cv2.cvtColor(image3, cv2.COLOR_BGR2GRAY)
res3 = cv.resize(gray_image3,(1800, 1800), interpolation = cv.INTER_CUBIC)
gray_image4 = cv2.cvtColor(image4, cv2.COLOR_BGR2GRAY)
res4 = cv.resize(gray_image4,(1800, 1800), interpolation = cv.INTER_CUBIC)
res1 = res1 / 255
res2 = res2 / 255
res3 = res3 / 255
res4 = res4 / 255
X = np.array(res1)
y= np.array([0,0])
nn = NeuralNetwork(input_size=1800, hidden_size=500, output_size=2)
nn.train(X, y, epochs=200, learning_rate=1)
output = nn.feedforward(X)
print(output[1])
X = np.array(res2)
y= np.array([0,1])
nn.train(X, y, epochs=20000, learning_rate=1)
print(output[1])
X= np.array(res3)
y= np.array([1,0])
print(output[1])
X = np.array(res4)
y= np.array([1,1])
print(output[1])
risultato:
Epoch 0, Loss:7.960687921508862e-06
[2.53768053e-13 1.32046885e-12]
Epoch 0, Loss:0.49999999597993483
/home/fabio/Scrivania/backpropagation.py:20: RuntimeWarning: overflow encountered in exp
Epoch 4000, Loss:1.2217864469508828e-20
ed il risultato non è ancora completo: è ancora fermo all epoca 4000
