Problema display arduino
Moderatore:
Paolino
5 messaggi
devi:
->scrivere il link o fornire il datasheet del display LCD
->dal titolo capisco che stai usando arduino, quindi dovresti postare lo schema elettrico dei collegamenti ed il codice sorgente che stai utilizzando.
->mettere il punto di domanda alla fine della frase
AjKDAP
1.255 2 6 9 - Expert EY
questo è il codice!
LiquidCrystal Library - Hello World
Demonstrates the use a 16x2 LCD display. The LiquidCrystal
library works with all LCD displays that are compatible with the
Hitachi HD44780 driver. There are many of them out there, and you
can usually tell them by the 16-pin interface.
This sketch prints "Hello World!" to the LCD
and shows the time.
The circuit:
* LCD RS pin to digital pin 12
* LCD Enable pin to digital pin 11
* LCD D4 pin to digital pin 5
* LCD D5 pin to digital pin 4
* LCD D6 pin to digital pin 3
* LCD D7 pin to digital pin 2
* LCD R/W pin to ground
* 10K resistor:
* ends to +5V and ground
* wiper to LCD VO pin (pin 3)
Library originally added 18 Apr 2008
by David A. Mellis
library modified 5 Jul 2009
by Limor Fried (http://www.ladyada.net)
example added 9 Jul 2009
by Tom Igoe
modified 22 Nov 2010
by Tom Igoe
This example code is in the public domain.
http://www.arduino.cc/en/Tutorial/LiquidCrystal
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
void setup() {
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
// Print a message to the LCD.
lcd.print("hello, world!");
void loop() {
// set the cursor to column 0, line 1
// (note: line 1 is the second row, since counting begins with 0):
lcd.setCursor(0, 1);
// print the number of seconds since reset:
lcd.print(millis()/1000);
and shows the time.
The circuit:
* 10K resistor:
by David A. Mellis
by Tom Igoe
by Tom Igoe
void setup() {
lcd.begin(16, 2);
void loop() {
Ultima modifica di
marco438 il 12 giu 2013, 18:47, modificato 1 volta in totale.
Motivazione: Ridimensionata l'immagine.
Il codice dovresti racchiuderlo nei tags CODE, io non posso modificare il post, ma la prossima volta ricordatelo.
Non hai postato il link al datasheet, penso sia questo.
Se il datasheet corrisponde esattamente al tuo modulo LCD allora lo schema presente nell'immagine che hai postato sembra coerente.
I consigli che ti posso dare sono
1) controlla di aver messo il pin R/W a massa
2) ricontrolla tutti i collegamenti se sono corretti.
AjKDAP
Potrebbe anche solo essere la regolazione del contrasto.
Immagino che l' autore della discussione abbia dapprima analizzato a fondo il datasheet del display.
TardoFreak
73,9k 8 12 13 - -EY Legend-
5 messaggi
