Errore programmazione PIC16F874A
Raccolta di codici sorgenti
[1] Errore programmazione PIC16F874A
Messaggioda Foto Utentenicolas97 » 2 apr 2014, 15:03
Ciao a tutti sto cercando di programmare questo PIC solo che in fase di compilazione mi vengono restituiti degli errori di cui non ne capisco il significato, spero che possiate aiutarmi.
di seguito ci sono i miei codici:
Codice: Seleziona tutto
#define _LEGACY_HEADERS
#include <htc.h>
__CONFIG (HS & WDTDIS & PWRTEN & BORDIS & LVPDIS & DUNPROT & WRTEN & UNPROTECT);
#include "delay.c"
#include "lcd_busy.c"
void main (void)
    TRISA=0b00000000;
    TRISB=0b00000000;
    TRISC=0b00000000;
    TRISD=0b00000000;
    LCD_INIT();
    DelayMs(250);
    LCD_CLEAR();
    DelayUs(200);
    while(1)
        LCD_GOTO(1,1);
        LCD_PUTS("CIAO A TUTTI");
        LCD_GOTO(2,1);
        LCD_PUTS("RIGA 2");
file lcd
Use this includes if these files are not included in your main code
//#include "PIC.h"
//#include "delay.c"
Use the following defines to set the lines as your hardware requires
You can use ANY output line of the MCU, even on several ports :)
#define   LCD_RW   RD1         // Read / Write register (19/10/2011 by Gabriel)
#define   LCD_RS   RD2         // Register select
#define   LCD_EN   RD3         // Enable
#define   LCD_D4   RD4         // LCD data 4
#define   LCD_D4_TRIS   TRISD4   // LCD data 4 tris   (19/10/2011 by Gabriel)
#define   LCD_D5   RD5         // LCD data 5
#define   LCD_D5_TRIS   TRISD5   // LCD data 5 tris   (19/10/2011 by Gabriel)
#define   LCD_D6   RD6         // LCD data 6
#define   LCD_D6_TRIS   TRISD6   // LCD data 6 tris   (19/10/2011 by Gabriel)
#define   LCD_D7   RD7         // LCD data 7
#define   LCD_D7_TRIS   TRISD7   // LCD data 7 tris   (19/10/2011 by Gabriel)
Now you have only to write LCD Rows and Columns number
and the cursor behaviour
!!! NOTE !!!
Some 1x16 LCD works as 2x8!!! ...be sure how to configure
yours, see its datasheet!!!
#define LCD_ROWS 2 // valid numbers are: 1,2 (set to 2 for 2 or more rows)
#define LCD_COLS 20 // valid numbers are: 8,16,20
#define LCD_CURSOR_VISIBLE 0 // 1:cursor on 0:cursor off
#define LCD_CURSOR_BLINK 0 // 1:cursor blinks 0:cursor doesn't blinks
#define LCD_TYPEWRITE 0 // 1:delay between characters
#define LCD_TW_DELAY 50 // milliseconds between characters
YOUR LCD IS NOW READY TO WORK!!! :)
YOU CAN IGNORE THE FOLLOWING CODE
ENJOY !!!
// define the right control value to set the cursor behavior
#if LCD_CURSOR_VISIBLE==1
   #if LCD_CURSOR_BLINK==1
   #define LCD_CONTROL 0b00001111
   #else
   #define LCD_CONTROL 0b00001110
   #endif
#else
   #define LCD_CONTROL 0b00001100
#endif
Use the following defines to send fast command to the LCD
Ex.: LCD_CMD(LCD_line2); will set the cursor on line 2
You can add fast command of your own!!!
!!! NOTE !!!
DON'T CHANGE THE DEFINES WITHIN #if-#endif
#define LCD_CLR  0x01 // Clears Display
#define LCD_HOME 0x02 // Cursor to Home position
#define LCD_line1 0x80 // Cursor to Line 1 position 1
#define LCD_line2 0xC0 // Cursor to Line 2 position 1
#if (LCD_COLS==20)
   #define LCD_line3 0x94 // Cursror to Line 3 position 1 (20 char LCD)
   #define LCD_line4 0xD4 // Cursor to Line 4 position 1 (20 char LCD)
#else
   #define LCD_line3 0x90 // Cursor to Line 3 position 1 (16 char LCD)
   #define LCD_line4 0xD0 // Cursor to Line 4 position 1 (16 char LCD)
#endif
Enable LCD to read data
void LCD_STROBE (void)
   LCD_EN = 1;
   DelayUs(1);
   LCD_EN=0;
   DelayUs(1);
LCD BUSY
bit LCD_BUSY (void)
   static bit          busyFlag;
   static bit         tempRS;
   LCD_D4_TRIS = 1;   // Set data lines D7-D4 as input
   LCD_D5_TRIS = 1;
   LCD_D6_TRIS = 1;
   LCD_D7_TRIS = 1;
   tempRS = LCD_RS;   // Save the LCD_RS value
   LCD_RW = 1;         // Set Read mode
   LCD_RS = 0;         // Command mode
   LCD_EN = 1;         // read bits 4-7 (bit7 = busy status)
   DelayUs(1);
   busyFlag = LCD_D7;  // copy busy status in busyFlag var
   LCD_EN = 0;
   DelayUs(1);
   LCD_STROBE();      // read bit 0-3 (not used)
   LCD_D4_TRIS = 0;   // Set data lines D7-D4 as output
   LCD_D5_TRIS = 0;
   LCD_D6_TRIS = 0;
   LCD_D7_TRIS = 0;
   LCD_RW = 0;         // Set write mode
   LCD_RS = tempRS;   // Load LCD_RS with the value saved
   return busyFlag;
Write a nibble to the LCD
void LCD_NIBBLE_OUT (unsigned char c)
   if (c & 0b10000000)
      LCD_D7=1;
   else LCD_D7=0;
   if (c & 0b01000000)
      LCD_D6=1;
   else LCD_D6=0;
   if (c & 0b00100000)
      LCD_D5=1;
   else LCD_D5=0;
   if (c & 0b00010000)
      LCD_D4=1;
   else LCD_D4=0;
   LCD_STROBE();
Write a byte to the LCD (4 bit mode)
void LCD_WRITE (unsigned char c)
   while(LCD_BUSY());
   LCD_RW = 0; // write mode
   LCD_NIBBLE_OUT(c);
   c <<= 4;
   LCD_NIBBLE_OUT(c);
   DelayUs(50);
   #if LCD_TYPEWRITE==1
   if (LCD_RS)
      DelayMs(LCD_TW_DELAY); // Delay between characters
   #endif
Sends a command to the LCD
void LCD_CMD (char c)
   LCD_RS = 0; // writes command
   LCD_WRITE(c);
GoTo specified line and position
void LCD_GOTO (char line,char pos)
   switch(line)
      case 1: LCD_CMD((LCD_line1-1)+pos);
      break;
      case 2: LCD_CMD((LCD_line2-1)+pos);
      break;
      case 3: LCD_CMD((LCD_line3-1)+pos);
      break;
      case 4: LCD_CMD((LCD_line4-1)+pos);
Clears and Home LCD
void LCD_CLEAR (void)
   LCD_CMD(LCD_CLR);
   DelayMs(3);
Writes one character (ASCII) to LCD
void LCD_PUTCH (char c)
   LCD_RS = 1; // write characters
   LCD_WRITE(c);
  Writes unsigned numbers to the LCD
void LCD_PUTUN (unsigned int c)
   unsigned char t1,i,wrote;
   unsigned int k;
   wrote = 0;
   for (i=4;i>=1;i--)
      switch(i)
         case 4: k=10000;
         break;
         case 3: k=1000;
         break;
         case 2: k=100;
         break;
         case 1: k=10;
      t1=c/k;
      if((wrote)||(t1!=0))
         LCD_PUTCH(t1+'0');
         wrote=1;
      c-=(t1*k);
   LCD_PUTCH(c+'0');
  Writes signed numbers to the LCD
void LCD_PUTSN (signed int c)
   if(c<0)
      LCD_PUTCH('-');
      c*=(-1);
   LCD_PUTUN(c);
Writes a string to the LCD
void LCD_PUTS (const char * s)
   while(*s)
      LCD_WRITE(*s++);
Customizes the CGRAM characters (0-7)
void LCD_CUSTOMCHAR(unsigned char pos,unsigned char byte0,unsigned char byte1,unsigned char byte2,unsigned char byte3,unsigned char byte4,unsigned char byte5,unsigned char byte6,unsigned char byte7)
   LCD_CMD(0b00001000); // display off
   LCD_CLEAR();
   LCD_CMD(64+(pos*8)); // goto the right CGRAM location
   LCD_PUTCH(byte0);
   LCD_PUTCH(byte1);
   LCD_PUTCH(byte2);
   LCD_PUTCH(byte3);
   LCD_PUTCH(byte4);
   LCD_PUTCH(byte5);
   LCD_PUTCH(byte6);
   LCD_PUTCH(byte7);
   LCD_CMD(LCD_CONTROL); // display on with preferred settings
Initializes LCD
void LCD_INIT (void)
   LCD_RS = 0; // write control bytes
   LCD_EN = 0;
   LCD_RW = 0;
   DelayMs(50); // power on delay orig 50
   LCD_D4=1;
   LCD_D5=1;
   LCD_D6=0;
   LCD_D7=0;
   LCD_STROBE();
   DelayMs(6);
   LCD_STROBE();
   DelayUs(150);
   LCD_STROBE();
   DelayMs(6);
   LCD_D4=0; // set 4 bit mode
   LCD_STROBE();
   DelayUs(100);
   #if (LCD_ROWS==1)
      LCD_WRITE(0b00100000);   // 4 bit mode, 1 line, 5x8 font
   #else
      LCD_WRITE(0b00101000);   // 4 bit mode, 2 or more lines, 5x8 font
   #endif
   LCD_WRITE(0b00001000); // display off
   LCD_WRITE(0b00000000); // clear display
   LCD_WRITE(LCD_CONTROL); // display on, set the cursor behavior as specified
   LCD_WRITE(0b00000110); // entry mode, display not shifted, cursor increments
#undef LCD_ROWS
#undef LCD_COLS
#undef LCD_CURSOR_BLINK
#undef LCD_CURSOR_VISIBLE
!!! END !!!
THANKS FOR EXAMINING MY CODE ;)
Please report any bug or suggestion at zypkin@inwind.it
inoltre ci sono i file di delay ma quelli non danno problemi.
gli errori che riporta il compilatore sono i seguenti:
CLEAN SUCCESSFUL (total time: 583ms)
make -f nbproject/Makefile-default.mk SUBPROJECTS= .build-conf
make[1]: Entering directory `C:/Users/imac/Desktop/ADC_PIC16F874A/adc_pic16f874a.X'
make  -f nbproject/Makefile-default.mk dist/default/production/adc_pic16f874a.X.production.hex
make[2]: Entering directory `C:/Users/imac/Desktop/ADC_PIC16F874A/adc_pic16f874a.X'
"C:\Program Files\HI-TECH Software\PICC\9.83\bin\picc.exe" --pass1 ../delay.c  -q --chip=16F874A -P  --outdir="build/default/production\_ext\1472" -D_LEGACY_HEADERS -N31 --warn=0 --runtime=default,+clear,+init,-keep,+osccal,-resetbits,-download,-stackcall,+clib --summary=default,-psect,-class,+mem,-hex --opt=default,+asm,-asmfile,-speed,+space,-debug,9  --double=24 --float=24 --addrqual=ignore --mode=pro -g --asmlist "--errformat=%%f:%%l: error: %%s" "--msgformat=%%f:%%l: advisory: %%s" "--warnformat=%%f:%%l warning: %%s"
"C:\Program Files\HI-TECH Software\PICC\9.83\bin\picc.exe" --pass1 ../lcd_busy.c  -q --chip=16F874A -P  --outdir="build/default/production\_ext\1472" -D_LEGACY_HEADERS -N31 --warn=0 --runtime=default,+clear,+init,-keep,+osccal,-resetbits,-download,-stackcall,+clib --summary=default,-psect,-class,+mem,-hex --opt=default,+asm,-asmfile,-speed,+space,-debug,9  --double=24 --float=24 --addrqual=ignore --mode=pro -g --asmlist "--errformat=%%f:%%l: error: %%s" "--msgformat=%%f:%%l: advisory: %%s" "--warnformat=%%f:%%l warning: %%s"
../lcd_busy.c:177: error: undefined identifier "RD3"
../lcd_busy.c:178 warning: function declared implicit int
../lcd_busy.c:191: error: undefined identifier "TRISD4"
../lcd_busy.c:192: error: undefined identifier "TRISD5"
../lcd_busy.c:193: error: undefined identifier "TRISD6"
../lcd_busy.c:194: error: undefined identifier "TRISD7"
../lcd_busy.c:196: error: undefined identifier "RD2"
../lcd_busy.c:197: error: undefined identifier "RD1"
../lcd_busy.c:200: error: undefined identifier "RD3"
../lcd_busy.c:202: error: undefined identifier "RD7"
../lcd_busy.c:224: error: undefined identifier "RD7"
../lcd_busy.c:228: error: undefined identifier "RD6"
../lcd_busy.c:232: error: undefined identifier "RD5"
../lcd_busy.c:236: error: undefined identifier "RD4"
../lcd_busy.c:249: error: undefined identifier "RD1"
../lcd_busy.c:267: error: undefined identifier "RD2"
../lcd_busy.c:297 warning: function declared implicit int
../lcd_busy.c:305: error: undefined identifier "RD2"
../lcd_busy.c:366: error: undefined identifier "RD2"
../lcd_busy.c:396: error: undefined identifier "RD2"
../lcd_busy.c:397: error: undefined identifier "RD3"
../lcd_busy.c:398: error: undefined identifier "RD1"
../lcd_busy.c:402: error: undefined identifier "RD4"
../lcd_busy.c:402: advisory: too many errors (21)
make[2]: Leaving directory `C:/Users/imac/Desktop/ADC_PIC16F874A/adc_pic16f874a.X'
make[1]: Leaving directory `C:/Users/imac/Desktop/ADC_PIC16F874A/adc_pic16f874a.X'
make[2]: *** [build/default/production/_ext/1472/lcd_busy.p1] Error 1
make[1]: *** [.build-conf] Error 2
make: *** [.build-impl] Error 2
BUILD FAILED (exit value 2, total time: 1s)
5 2
[2] Re: Errore programmazione PIC16F874A
Messaggioda Foto Utentec1b8 » 3 apr 2014, 9:21
Secondo me il problema è che il file lcd_busy.c non deve essere compilato, non saprei dirti come escluderlo dalla lista dei file compilabili.
Non deve essere compilato perché viene incluso nel file principale.
Altrimenti potresti definire in un file .h le funzioni presenti nel file lcd, includere nel file principale il nuova .h e quindi compilare alche il file lcd dopo aver ripristinato le include al suo interno che sono state commentate.
Fabio
Foto Utentec1b8
3.595 3 8 13
[3] Re: Errore programmazione PIC16F874A
Messaggioda Foto Utenteobiuan » 3 apr 2014, 10:20
Innanzitutto, includere un file .c è una pratica che mi sento di sconsigliare sempre. Esistono i file di header apposta, se includi codice poi nonappena il programma ti si complica un po' e magari hai bisogno di più moduli non compila più.
per il problema specifico...ti sta dando errori di "undefined identifier" su identificatori che sono del PIC stesso. In una delle prime righe del file lcd vedi:
//#include "PIC.h"
nel tuo file main non è incluso PIC.h, direi che il problema è quello.
_______________________________________________________
Gli oscillatori non oscillano mai, gli amplificatori invece sempre
Io HO i poteri della supermucca, e ne vado fiero!
Foto Utenteobiuan
5.894 3 10 13
[4] Re: Errore programmazione PIC16F874A
Messaggioda Foto Utentenicolas97 » 3 apr 2014, 20:17
Prima di tutto grazie ad entrambi per i consigli!! Ho risolto il problema non compilando il file LCD, includendolo però nel main, ho compilato il tutto ed è andato tutto a buon fine! Ho provato il circuito su bread board e tutto funziona correttamente!! Grazie di cuore ad entrambi!!
5 2
