sto programmando un LCD 1x40 , ma le scritte si fermano tutte alla prima metà del LCD
i l codice inputato:
- Codice: Seleziona tutto
#if LCD_CURSOR_VISIBLE==1
#if LCD_CURSOR_BLINK==1
#define LCD_CONTROL 0b00001111
#else
#define LCD_CONTROL 0b00001110
#endif
#else
#define LCD_CONTROL 0b00001100
#endif
#define LCD_CLR 0x01 // Clears Display
#define LCD_HOME 0x02 // Cursor to Home position
#define LCD_line1 0x80 // Cursor to Line 1 position 1
#define LCD_line2 0xC0 // Cursor to Line 2 position 1
#if (LCD_COLS==20)
#define LCD_line3 0x94 // Cursror to Line 3 position 1 (20 char LCD)
#define LCD_line4 0xD4 // Cursor to Line 4 position 1 (20 char LCD)
#else
#define LCD_line3 0x90 // Cursor to Line 3 position 1 (16 char LCD)
#define LCD_line4 0xD0 // Cursor to Line 4 position 1 (16 char LCD)
#endif
void LCD_GOTO (char line,char pos)
switch(line)
case 1: LCD_CMD((LCD_line1-1)+pos);
break;
case 2: LCD_CMD((LCD_line2-1)+pos);
break;
case 3: LCD_CMD((LCD_line3-1)+pos);
break;
case 4: LCD_CMD((LCD_line4-1)+pos);
break;
void LCD_PUTS (const char * s)
LCD_RS = 1; // write characters
while(*s)
LCD_WRITE(*s++);
void LCD_INIT (void)
LCD_RS = 0; // write control bytes
DelayMs(50); // power on delay
LCD_D4=1;
LCD_D5=1;
LCD_D6=0;
LCD_D7=0;
LCD_STROBE();
DelayMs(6);
LCD_STROBE();
DelayUs(150);
LCD_STROBE();
DelayMs(6);
LCD_D4=0; // set 4 bit mode
LCD_STROBE();
DelayUs(100);
#if (LCD_ROWS==1)
LCD_WRITE(0b00100000); // 4 bit mode, 1 line, 5x8 font
#else
LCD_WRITE(0b00101000); // 4 bit mode, 2 or more lines, 5x8 font
#endif
LCD_WRITE(0b00001000); // display off
LCD_WRITE(0b00000000); // clear display
LCD_WRITE(LCD_CONTROL); // display on, set the cursor behavior as specified
LCD_WRITE(0b00000110); // entry mode, display not shifted, cursor increments
void main()
int i=0;
settings();
LCD_INIT(); // inizializzo l'LCD
LCD_CLEAR(); // ripulisco il display
// Preparo le scritte sul display
LCD_GOTO(1,1);
LCD_PUTS("Controllo Temp. Caldaia BELLIGOLI");
DelayMs(5000);
In questo punto (1,20) mi si fermano tutte le stringhe.
se qualcuno ha un po' di pazienza da controllare dove sbaglio....!!!! vi sarei molto grato....!!!
