Metodi Sistematici
[1] Metodi Sistematici
Messaggioda Foto UtenteFrankz » 19 lug 2018, 23:24
Ciao, vorrei sapere che ne pensate di ciò che ho fatto:
CASO 1:
M=\left[\begin{matrix} 1 & -1 & -1 & 0 & 0 & 1 & 0 \\ 0 & 1 & 0 & 1 & -1 & 0 & -1 \end{matrix}\right]
R=\left[\begin{matrix} 3 & 0 & 0 & 0 & 0 & 0 & 0 \\ 0 & 8 & 0 & 0 & 0 & 0 & 0 \\ 0 & 0 & 5 & 0 & 0 & 0 & 0 \\ 0 & 0 & 0 & 4 & 0 & 0 & 0 \\ 0 & 0 & 0 & 0 & 3 & 0 & 0 \\ 0 & 0 & 0 & 0 & 0 & 0 & 0 \\ 0 & 0 & 0 & 0 & 0 & 0 & 0\end{matrix}\right]
\bar{R}=M\cdot R\cdot M^T=\left[\begin{matrix} 16 & -8 \\ -8 & 15\end{matrix}\right]
E=\left[\begin{matrix} 0 \\ 0 \\0 \\0 \\0 \\40 \\-20 \end{matrix}\right]
\bar{V}=M\cdot R\cdot A - M\cdot E= \left[\begin{matrix} 40 \\20 \end{matrix}\right]
\bar{I}^{ T}=\bar{R}^{-1}\cdot \bar{V}= \left[\begin{matrix} 4,31 & 3,63\end{matrix}\right]
I=M^{ T}\cdot \bar{I} = \left[\begin{matrix} 4,31 & -0,68 & -4,31 & 3,63 & -3,63 & 4,31 & -3,63\end{matrix}\right]
Per Rth ho fatto così:
RTh=\frac{R_2\cdot (R_4+R_5)}{R_2 + (R_4+R_5)}=11,73\Omega
Per Vth non sono sicuro:
I_{E_1}=\frac{E_1}{R_{th}}=\frac{40}{11,73}=3,41A
V_{th}=V_{x}+V_3-V_1
R_x=\frac{R_2\cdot (R_4+R_5)}{R_2+(R_4+R_5)}=3,73\Omega
V_x=R_x\cdot I_{E_1} = 12,72V
V_1=R_1\cdot I_{E_1} = 10,23V
V_3=R_3\cdot I_{E_1} = 17,05V
V_{th}=V_{x}+V_3-V_1 = 20V
CASO 2:
V_7=4\cdot V_2
V_2=I_2\cdot R_2
V_7=4 \cdot I_2\cdot R_2
R=\left[\begin{matrix} 3 & 0 & 0 & 0 & 0 & 0 & 0 \\ 0 & 8 & 0 & 0 & 0 & 0 & 0 \\ 0 & 0 & 5 & 0 & 0 & 0 & 0 \\ 0 & 0 & 0 & 4 & 0 & 0 & 0 \\ 0 & 0 & 0 & 0 & 3 & 0 & 0 \\ 0 & 0 & 0 & 0 & 0 & 0 & 0 \\ 0 & 32 & 0 & 0 & 0 & 0 & 0\end{matrix}\right]
\bar{R}=M\cdot R\cdot M^T=\left[\begin{matrix} 16 & -8 \\ 24 & -17\end{matrix}\right]
E=\left[\begin{matrix} 0 \\ 0 \\0 \\0 \\0 \\0 \\40 \end{matrix}\right]
\bar{V}=M\cdot R\cdot A - M\cdot E= \left[\begin{matrix} 0 \\ -40 \end{matrix}\right]
\bar{I}^{ T}=\bar{R}^{-1}\cdot \bar{V}= \left[\begin{matrix} 4 & 8\end{matrix}\right]
I=M^{ T}\cdot \bar{I} = \left[\begin{matrix} 4 & 4 & -4 & 8 & -8 & 4 & -8\end{matrix}\right]
Grazie.
Foto UtenteFrankz
22 5
6
[2] Re: Metodi Sistematici
Messaggioda Foto UtenteEdmondDantes » 20 lug 2018, 15:01
Ormai le regole del forum le conosci.
1) D: Cosa manca in questo tuo messaggio?
R: Il circuito iniziale.
2) D: Bravo, e poi?
R: Ehm... i calcoli?
D: Stai migliorando, continua cosi'. Anche qualche commento che illustra i vari passaggi. Non siamo macchine.
3) D: Come mai inizi con la pseudo soluzione e inserisci il testo del problema alla fine?
R: Non lo so, ho pensato di fare cosi'...
D: Non ci siamo!
4) D: Ho visto che non inserisci mai i calcoli, eppure ti ho detto piu' volte che devi iniziare con la parte simbolica, poi sostituire i valori numerici, eseguire un minimo di calcolo intermedio e poi scrivere il risultato. Perche' non lo fai?
R: Sai, e' noioso inserire i calcoli e mi annoio. Non ho tempo.
D: Beh, allora neanch'io ho tempo di vedere certi obbrobri, sai? LaTeX rende magnifica la parte tipografica del testo, ma non corregge gli errori.
5) D: Sai che non devi mai applicare bovinamente i concetti fisici, teoremi, regole e cosi' via? L'ho scritto piu' volte. Perche' lo fai?
R: Pensare e' piu' noioso di scrivere i calcoli... ma a cosa ti riferisci?
D: Ho dato una lettura veloce al tuo messaggio, saltando tutti i papiri matriciali e l'occhio si e' fermato sul circuito base per il calcolo della Rth del caso 1. Mi hai quasi accecato. Mi vuoi male?
R: Ma perche' dici questo? Ho spento tutti i generatori. Che ho fatto?
D: Cosa non hai fatto, vorrai dire! Non hai studiato! Inutile scrivere m2 di matrici e poi sbagli i concetti base. Vai a studiare!
Il Conte di Montecristo
Abraham Lincoln
11,9k 8 11 13
Disattivato su sua richiesta
[3] Re: Metodi Sistematici
Messaggioda Foto UtenteFrankz » 20 lug 2018, 15:41
EdmondDantes ha scritto:Ormai le regole del forum le conosci.
D: Non ci siamo!
Non hai azzeccato la risposta [-X . Il motivo è che non ho capito come mettere l'immagine all'inizio del post.
EdmondDantes ha scritto: D: Ho dato una lettura veloce al tuo messaggio, saltando tutti i papiri matriciali e l'occhio si e' fermato sul circuito base per il calcolo della Rth del caso 1. Mi hai quasi accecato. Mi vuoi male?
D: Cosa non hai fatto, vorrai dire! Non hai studiato! Inutile scrivere m2 di matrici e poi sbagli i concetti base. Vai a studiare.
Ma non pensi che se uno studiasse, capisse e risolvesse gli esercizi da solo non chiederebbe aiuto qui?!?! E' probabile (dato che a te non sembra) che io abbia studiato ma non abbia capito bene, dunque è per questo che provo comunque a farlo e a postarlo qui...non sto chiedendo di risolvermi un esercizio perché non ho voglia.
Comunque, ora arricchisco calcoli, commenti e circuiti. La Rth a me sembra giusta (no capisco l'errore), hai voglia di spiegarmi cosa non va?
Foto UtenteFrankz
22 5
[4] Re: Metodi Sistematici
Messaggioda Foto UtenteEdmondDantes » 20 lug 2018, 15:45
Hai scritto la Rth, inserendo il risultato senza fare conti.
A chi vuoi prendere in giro?
Continua così e inizierò a bloccare qualsiasi tuo 3D.
Abraham Lincoln
11,9k 8 11 13
[5] Re: Metodi Sistematici
Messaggioda Foto UtenteFrankz » 20 lug 2018, 17:44
CASO 1:
\bar{R}=M\cdot R\cdot M^T= \left[\begin{matrix} 1 & -1 & -1 & 0 & 0 & 1 & 0 \\ 0 & 1 & 0 & 1 & -1 & 0 & -1\end{matrix}\right]\left[\begin{matrix} 3 & 0 & 0 & 0 & 0 & 0 & 0 \\ 0 & 8 & 0 & 0 & 0 & 0 & 0 \\ 0 & 0 & 5 & 0 & 0 & 0 & 0 \\ 0 & 0 & 0 & 4 & 0 & 0 & 0 \\ 0 & 0 & 0 & 0 & 3 & 0 & 0 \\ 0 & 0 & 0 & 0 & 0 & 0 & 0 \\ 0 & 0 & 0 & 0 & 0 & 0 & 0\end{matrix}\right]\left[\begin{matrix} 1 & 0 \\ -1 & 1 \\ -1 & 0 \\ 0 & 1 \\ 0 & -1 \\ 1 & 0 \\ 0 & -1\end{matrix}\right]==\left[\begin{matrix} 16 & -8 \\ -8 & 15\end{matrix}\right]
\bar{V}=M\cdot R\cdot A - M\cdot E= \left[\begin{matrix} 1 & -1 & -1 & 0 & 0 & 1 & 0 \\ 0 & 1 & 0 & 1 & -1 & 0 & -1\end{matrix}\right]\left[\begin{matrix} 3 & 0 & 0 & 0 & 0 & 0 & 0 \\ 0 & 8 & 0 & 0 & 0 & 0 & 0 \\ 0 & 0 & 5 & 0 & 0 & 0 & 0 \\ 0 & 0 & 0 & 4 & 0 & 0 & 0 \\ 0 & 0 & 0 & 0 & 3 & 0 & 0 \\ 0 & 0 & 0 & 0 & 0 & 0 & 0 \\ 0 & 0 & 0 & 0 & 0 & 0 & 0\end{matrix}\right]\left[\begin{matrix} 0 \\ 0 \\0 \\0 \\0 \\0 \\0 \end{matrix}\right]-- \left[\begin{matrix} 1 & -1 & -1 & 0 & 0 & 1 & 0 \\ 0 & 1 & 0 & 1 & -1 & 0 & -1\end{matrix}\right]\left[\begin{matrix} 0 \\ 0 \\0 \\0 \\0 \\40 \\-20 \end{matrix}\right] = \left[\begin{matrix} 40 \\20 \end{matrix}\right]
\bar{I}^{ T}=\bar{R}^{-1}\cdot \bar{V}= \left[\begin{matrix} 0,085 & 0,045 \\ 0,045 & 0,090\end{matrix}\right]\left[\begin{matrix} 40 \\20 \end{matrix}\right] =\left[\begin{matrix} 4,31 & 3,63\end{matrix}\right]
I=M^{ T}\cdot \bar{I} = \left[\begin{matrix} 1 & -1 & -1 & 0 & 0 & 1 & 0 \\ 0 & 1 & 0 & 1 & -1 & 0 & -1\end{matrix}\right]\left[\begin{matrix} 4,31 & 3,63\end{matrix}\right] =
=\left[\begin{matrix} 4,31 & -0,68 & -4,31 & 3,63 & -3,63 & 4,31 & -3,63\end{matrix}\right]
RTh=R_1+R_3+\frac{R_2\cdot (R_4+R_5)}{R_2 + (R_4+R_5)}=3+5+\frac{8\cdot 7}{8 + 7}=11,73\Omega
R_x=\frac{R_2\cdot (R_4+R_5)}{R_2+(R_4+R_5)}=\frac{8\cdot (5+3)}{8+(5+3)}=3,73\Omega
V_x=R_x\cdot I_{E_1} =3,73\cdot 3,41 = 12,72V
V_1=R_1\cdot I_{E_1} =3\cdot 3,41 = 10,23V
V_3=R_3\cdot I_{E_1} =5\cdot 3,41 =17,05V
V_{th}=V_{x}+V_3-V_1 = 12,72+17,05-10,23 =20V
CASO 2:
V_7=4\cdot V_2 \Longrightarrow V_7: tensione del lato del gen. comandato
V_2=I_2\cdot R_2 \Longrightarrow V_2: legge di ohm lato che comanda
V_7=4 \cdot I_2\cdot R_2 \Longrightarrow 4\cdot R2=4\cdot 8 = 32\Omega: resistenza da inserire nella matrice delle R
\bar{R}=M\cdot R\cdot M^T= \left[\begin{matrix} 1 & -1 & -1 & 0 & 0 & 1 & 0 \\ 0 & 1 & 0 & 1 & -1 & 0 & -1\end{matrix}\right]\left[\begin{matrix} 3 & 0 & 0 & 0 & 0 & 0 & 0 \\ 0 & 8 & 0 & 0 & 0 & 0 & 0 \\ 0 & 0 & 5 & 0 & 0 & 0 & 0 \\ 0 & 0 & 0 & 4 & 0 & 0 & 0 \\ 0 & 0 & 0 & 0 & 3 & 0 & 0 \\ 0 & 0 & 0 & 0 & 0 & 0 & 0 \\ 0 & 32 & 0 & 0 & 0 & 0 & 0\end{matrix}\right]\left[\begin{matrix} 1 & 0 \\ -1 & 1 \\ -1 & 0 \\ 0 & 1 \\ 0 & -1 \\ 1 & 0 \\ 0 & -1\end{matrix}\right]= =\left[\begin{matrix} 16 & -8 \\ 24 & -17\end{matrix}\right]
\bar{V}=M\cdot R\cdot A - M\cdot E= \left[\begin{matrix} 1 & -1 & -1 & 0 & 0 & 1 & 0 \\ 0 & 1 & 0 & 1 & -1 & 0 & -1\end{matrix}\right]\left[\begin{matrix} 3 & 0 & 0 & 0 & 0 & 0 & 0 \\ 0 & 8 & 0 & 0 & 0 & 0 & 0 \\ 0 & 0 & 5 & 0 & 0 & 0 & 0 \\ 0 & 0 & 0 & 4 & 0 & 0 & 0 \\ 0 & 0 & 0 & 0 & 3 & 0 & 0 \\ 0 & 0 & 0 & 0 & 0 & 0 & 0 \\ 0 & 32 & 0 & 0 & 0 & 0 & 0\end{matrix}\right]\left[\begin{matrix} 0 \\ 0 \\0 \\0 \\0 \\0 \\0 \end{matrix}\right]-- \left[\begin{matrix} 1 & -1 & -1 & 0 & 0 & 1 & 0 \\ 0 & 1 & 0 & 1 & -1 & 0 & -1\end{matrix}\right]\left[\begin{matrix} 0 \\ 0 \\0 \\0 \\0 \\0 \\40 \end{matrix}\right] =\left[\begin{matrix} 40 \\ 0 \end{matrix}\right]
\bar{I}^{ T}=\bar{R}^{-1}\cdot \bar{V}= \left[\begin{matrix} 0,212 & -0,1 \\ 0,3 & -0,2\end{matrix}\right]\left[\begin{matrix} 40 \\ 0 \end{matrix}\right] = \left[\begin{matrix} 8,5 & 12\end{matrix}\right]
I=M^{ T}\cdot \bar{I} = \left[\begin{matrix} 1 & 0 \\ -1 & 1 \\ -1 & 0 \\ 0 & 1 \\ 0 & -1 \\ 1 & 0 \\ 0 & -1\end{matrix}\right]\left[\begin{matrix} 8,5 \\ 12\end{matrix}\right] =\left[\begin{matrix} 8,5 & 3,5 & -8,5 & 12 & -12 & 8,5 & -12\end{matrix}\right]
Per R_{th} il risultato era giusto. Nel riportare i conti non ho scritto la somma con R_1 ed R_3
Foto UtenteFrankz
22 5
[6] Re: Metodi Sistematici
Messaggioda Foto UtenteEdmondDantes » 20 lug 2018, 18:56
Ho dato una lettura veloce.
Caso 1.
Per il calcolo delle matrici e dei vettori hai applicato le definizioni, eseguendo molti conti. Potevi risparmiare molti passaggi, applicando le proprietà fondamentali delle varie matrici.
Resistenza equivalente Rth.
Formulazione e risultato corretto, ma mi fai capire come sei arrivato all'espressione
partendo da questo schema?
Abraham Lincoln
11,9k 8 11 13
[7] Re: Metodi Sistematici
Messaggioda Foto UtenteFrankz » 20 lug 2018, 19:04
Foto UtenteFrankz
22 5
[8] Re: Metodi Sistematici
Messaggioda Foto UtenteEdmondDantes » 20 lug 2018, 19:07
Si', ma almeno capisci l'enorme differenza in termini fisici e numerici?
Non e' che meglio cosi', lo schema precedente e' errato. Punto.
Fai poco lo spiritoso...
Abraham Lincoln
11,9k 8 11 13
[9] Re: Metodi Sistematici
Messaggioda Foto UtenteFrankz » 20 lug 2018, 19:21
Per gli altri valori riesci a dirmi se sono giusti?
Foto UtenteFrankz
22 5
[10] Re: Metodi Sistematici
Messaggioda Foto UtenteEdmondDantes » 20 lug 2018, 19:50
Non sono in grado. Con questo ho chiuso.
Abraham Lincoln
11,9k 8 11 13
