stazione saldante problema
[1] stazione saldante problema
Messaggioda Foto Utentedanielealfa » 4 nov 2019, 16:02
ciao a tutti e buon giorno.
mi sto facendo questa stazione saldante con arduino
https://hackermagnet.com/soldering-station/
con questo codice
Codice: Seleziona tutto
Soldering Station controller for Chinese Hakko 907
Original code by Kuro - https://hackaday.io/project/3417-hakko-907-based-soldering-station
Edited by Yannis Kari - https://hackermagnet.com/portfolio/soldering-station
# Change Log
## [0.6b:]
- ability to limit PWM_MAX below 100˚C (requested by Molodchaga)
## [0.6:]
- turn off if temp exceeds MAX+30 for more than SAFETY_OFF_TIME (5")
- turn off if sleeping for more than AUTO_OFF_TIME (5')
- boot screen that goes away after putting the iron on base stand
## [0.5:]
- sleep mode using reed switch on pin 18 and a magnet on base after AUTO_SLEEP_TIME (30")
## [0.4:]
- options to clear EEPROM and start autotune during startup with confirmation
- new progress bar
- new temp icon
- print duty cycle on screen
## [0.3:]
- sound alerts with buzzer on pin 13
## [0.2:]
- Auto turn off
## [0.1b:]
- initial release
#include <Wire.h>
#include "LiquidCrystal.h"
#include "TimerOne.h"
#include "Button.h"
#include "PID_v1.h"
#include "PID_AutoTune_v0.h"
#include "EEPROMex.h"
#include <avr/wdt.h>
#define OFF         0
#define ON         1
// PIN DEFINITIONS
#define HEATER       9
#define TEMP_PIN   21
#define POT         20
#define REED       18
#define Button1      8
#define Button2      7
#define Button3      4
#define Button4      19
#define Buzzer      13
//LCD
#define LCD_LED      10
#define LCD_RS      17
#define LCD_EN      16
#define LCD_D4      15
#define LCD_D5      14
#define LCD_D6      12
#define LCD_D7      11
//LED
const int LED_R = 6;
const int LED_G = 5;
const int LED_B = 3;
int flash_on = 0;
int flash_off = 0;
//SETTINGS
char ver[] = "0.6";
int boot_screen = 1;
#define TEMP_WO_IRON 749 // readTemp(); returns about 749 when I disconnect the iron
#define LCD_INTERVAL 200 // Time im ms between LCD updates
#define PTC_INTERVAL 100 // Time im ms between average analog readings
#define FLASH_ON 600 // Time im ms for RGB to stay on when flashing, keep it multiple of LCD_INTERVAL
#define FLASH_OFF 400 // Time im ms for RGB to stay off when flashing, keep it multiple of LCD_INTERVAL
#define RGB_EFECT_MIN 60 // degrees below temperature to start the RGB effect with blue color
#define RGB_EFECT_MAX 30 // degrees above temperature to finish the RGB effect with red color
#define BAR_STEP 4 // graph will move every 4˚C
#define AUTO_SLEEP_TIME 30000 // Auto sleep time
#define AUTO_OFF_TIME 300000// Auto OFF time if iron is in sleep mode
#define SAFETY_OFF_TIME 5000 // Auto OFF time if temp exceeds max+30
#define BUZ_DUR 10 //buzzer sound duration
// Temperature control definitions
#define MIN_TEMP   200 // Minimum setpoint temperature, sleep temp = min - 50
#define MAX_TEMP   370   // Maximum setpoint temperature, turn off temp = max + 30
#define PWM_MAX      1012 // PWM limit, max 1023
#define PWM_LIMIT   0.8 // Limit PWM_MAX below 100˚C
// Y = a*X + b, where Y is the temperature and X is the analog value read from the sensor.
#define EQUATION_A   0.907
#define EQUATION_B   -177.81
// PID VALUES
#define KP_VAL      20.00
#define KI_VAL      3.50
#define KD_VAL      25.00
// PID Autotune Variables
//Setup a High Temp for Autotune e.g. 250˚C
//Preheat the Iron at a lower temp like 200˚C and start autotune with a preheated iron.
//Don't use a cold iron because it gives momentarely false readings at low temperatures
//and the Autotune algorithm won't calculate correct P,I,D parameters.
#define AUTOTUNE_SETPOINT      250   // Temperature around PID autotune will tune
#define AUTOTUNE_START_VALUE   (PWM_MAX/2)   // Do not change
#define AUTOTUNE_STEP_VALUE      AUTOTUNE_START_VALUE // Do not change
#define AUTOTUNE_NOISEBAND      3
#define AUTOTUNE_LOOKBACK      10
int bright = 0; //brightness of LCD (1..10)
int temp_5 = OFF; //multiples of 5
int autoTurnOFF = OFF; //
uint8_t showAnalog = ON; //show analog values in PID values view
// Global variables
uint32_t last_lcd_update = 0;
uint32_t last_ptc_update = 0;
uint8_t heater_mode = OFF;
uint8_t sleeping = OFF;
uint8_t ironLifted = OFF;
uint32_t base_time = 0;
uint32_t sleeping_time = 0;
uint32_t overshoot_time = 0;
uint8_t showPID = OFF;
uint8_t clearEEPROM = OFF;
// PID Variables
double temperature;
double setpoint = 0.0;
double duty;
double kp;
double ki;
double kd;
uint16_t autotune_address;
uint16_t kp_address;
uint16_t ki_address;
uint16_t kd_address;
uint16_t bright_address;
uint16_t temp_5_address;
uint16_t autoTurnOFF_address;
PID heaterPid(&temperature, &duty, &setpoint, 2, 5, 1, DIRECT);
PID_ATune aTune(&temperature, &duty);
LiquidCrystal lcd(LCD_RS, LCD_EN, LCD_D4, LCD_D5, LCD_D6, LCD_D7);
Button heatButton = Button(Button1, LOW); // start/stop heating, start autotune
Button increaseBrightButton = Button(Button2, LOW); // change lcd brightness
Button temp_5_Button = Button(Button3, LOW); // enable or disable showing temp as multiple of 5
Button pidButton = Button(Button4, LOW); //show PID constants, save EEPROM on exit, reset EEPROM
void setup() {
   // Autotune
   uint8_t autotune = OFF;
   uint8_t autotune_pid = 0;
   // Enable Watchdog Timer, 1 second
   wdt_enable(WDTO_1S);
   // Define the EEPROM address for Kp, Ki and Kd
   autotune_address = EEPROM.getAddress(sizeof(uint8_t));
   kp_address = EEPROM.getAddress(sizeof(double));
   ki_address = EEPROM.getAddress(sizeof(double));
   kd_address = EEPROM.getAddress(sizeof(double));
   bright_address = EEPROM.getAddress(sizeof(int));
   temp_5_address = EEPROM.getAddress(sizeof(int));
   autoTurnOFF_address = EEPROM.getAddress(sizeof(int));
   // Set up pins
   pinMode(LCD_LED, OUTPUT);
   pinMode(HEATER, OUTPUT);
   pinMode(LED_R, OUTPUT);
   pinMode(LED_G, OUTPUT);
   pinMode(LED_B, OUTPUT);
   pinMode(Buzzer, OUTPUT);
   pinMode(Button1, INPUT_PULLUP);
   pinMode(Button2, INPUT_PULLUP);
   pinMode(Button3, INPUT_PULLUP);
   pinMode(Button4, INPUT_PULLUP);
   pinMode(REED, INPUT_PULLUP);
   // Set up Heater PWM
   Timer1.PWM(HEATER, 0, 30);
   // Set up PID
   heaterPid.SetOutputLimits(0, PWM_MAX);
   heaterPid.SetSampleTime(50);         // Update PID every 50ms
   heaterPid.SetMode(AUTOMATIC);
   // Set up LCD
   setBrightness(bright);
   lcd.begin(16, 2);
   charSetup();
   //Check if reset EEPROM button is pressed at startup
   if (digitalRead(Button4) == 0) {
      clearEEPROM = ON;
   // Check if PID autotune button is pressed at startup
   else if (digitalRead(Button1) == 0) {
      autotune = ON;
   //Reset EEPROM
   if (clearEEPROM){
      setBrightness(10);
      lcd.clear();
      lcd.print(" Clear EEPROM ? ");
      lcd.setCursor(0, 1);
      lcd.print("   [YES] [NO]   ");
      while (clearEEPROM){
         if (digitalRead(Button2) == 0){
            EEPROM.writeByte(autotune_address, 0);
            EEPROM.writeDouble(kp_address, 0);
            EEPROM.writeDouble(ki_address, 0);
            EEPROM.writeDouble(kd_address, 0);
            EEPROM.writeInt(bright_address, 0);
            EEPROM.writeInt(temp_5_address, 0);
            EEPROM.writeInt(autoTurnOFF_address, 0);
            lcd.clear();
            lcd.print("Cleared!");
            lcd.print(">Press 3 to exit");
            for (int i = 0; i < 2; i++){
               digitalWrite(Buzzer, HIGH);
               delay(BUZ_DUR);
               digitalWrite(Buzzer, LOW);
               delay(BUZ_DUR*15);
         else if (digitalRead(Button3) == 0){
            clearEEPROM = OFF;
         wdt_reset();
   // Start PID autotune
   else if (autotune){
      setBrightness(10);
      lcd.clear();
      lcd.print(" Autotune PID ? ");
      while (autotune){
            // Configure PID autotune
            setpoint = AUTOTUNE_SETPOINT;
            duty = AUTOTUNE_START_VALUE;
            aTune.SetNoiseBand(AUTOTUNE_NOISEBAND);
            aTune.SetOutputStep(AUTOTUNE_STEP_VALUE);
            aTune.SetLookbackSec(AUTOTUNE_LOOKBACK);
            aTune.SetControlType(1);
            // Print some autotune info
            lcd.clear();
            lcd.print("Autotune PID at:");
            lcd.print((uint16_t)setpoint);
            lcd.print((char)223);
            lcd.print("C");
            // Heat to the setpoint, temperature will rise above it
            Timer1.setPwmDuty(HEATER, duty);
            while(readTemp() < setpoint) {
               // Reset the watchdog timer to prevent rebooting
               wdt_reset();
            // Wait for temperature to drop to setpoint
            Timer1.setPwmDuty(HEATER, 0);
            while(readTemp() > setpoint) {
               wdt_reset();
            // Start the autotune
            while(autotune) {
               // Get the current temperature
               temperature = readTemp();
               // Check if the autotune is finished
               if(aTune.Runtime() != 0) {
                  autotune = OFF;
               else {
               // If finished, set up the PID and EEPROM values
               if(!autotune) {
                  // Turn off the heater
                  // Get the values from autotune
                  kp = aTune.GetKp();
                  ki = aTune.GetKi();
                  kd = aTune.GetKd();
                  // Write them to the EEPROM
                  EEPROM.writeDouble(kp_address, kp);
                  EEPROM.writeDouble(ki_address, ki);
                  EEPROM.writeDouble(kd_address, kd);
                  EEPROM.writeByte(autotune_address, 1);
                  // Reset the setpoint
                  setpoint = 0.0;
               wdt_reset();
               delay(BUZ_DUR);
               delay(BUZ_DUR*15);
            autotune = OFF;
         wdt_reset();
   bright = EEPROM.readInt(bright_address);
   if(boot_screen){
      if (digitalRead(REED)){
         lcd.clear();
         lcd.print(char(162));
         lcd.print("Soldering Iron");
         lcd.print(" Controller ");
         lcd.print(ver);
         lcd.print(char(163));
   while (boot_screen){
      if (!digitalRead(REED)){
         boot_screen = 0;
         delay(BUZ_DUR);
      wdt_reset();
   temp_5 =  EEPROM.readInt(temp_5_address);
   autoTurnOFF = EEPROM.readInt(autoTurnOFF_address);
   // Get the PID constant values from EEPROM if autotune was run
   autotune_pid = EEPROM.readByte(autotune_address);
   if(autotune_pid == 1) {
      kp = EEPROM.readDouble(kp_address);
      ki = EEPROM.readDouble(ki_address);
      kd = EEPROM.readDouble(kd_address);
   else{
      kp = KP_VAL;
      ki = KI_VAL;
      kd = KD_VAL;
   heaterPid.SetTunings(kp,ki,kd);
   lcd.clear();
void loop() {
   uint32_t current_time = millis(); // Get the current time
   wdt_reset();
   checkButton();
   // Automatic turn-off
   if(heater_mode) {
      //if left on base and lifted at least once
      if(!(digitalRead(REED)) && (ironLifted)){
         if (autoTurnOFF) {
            if (sleeping){
               if ((millis() - sleeping_time) >= AUTO_OFF_TIME){
                  heater_mode = OFF;
                  delay(BUZ_DUR);
            else if ((millis() - base_time) >= AUTO_SLEEP_TIME) {
               sleeping = ON;
               setpoint = MIN_TEMP - 50;
               sleeping_time = millis();
               delay(BUZ_DUR);
      //lifted from base or hasn't lifted at least once
      else{
         if (sleeping){
            sleeping = OFF;
            delay(BUZ_DUR);
         else if (digitalRead(REED)) ironLifted = ON;
         base_time = millis();
         setpoint = readPot();
   else setpoint = readPot();
   // Read Analog data for PTC
   if(current_time - last_ptc_update > PTC_INTERVAL) {
      if(heater_mode){
         if (temperature > MAX_TEMP + 30){
            if (millis() - overshoot_time >= SAFETY_OFF_TIME){
               heater_mode = OFF;
               delay(BUZ_DUR);
         else overshoot_time = millis();
         lightRGB(setpoint, temperature);
         if(temperature < 100) heaterPid.SetOutputLimits(0, PWM_MAX * PWM_LIMIT);
         else heaterPid.SetOutputLimits(0, PWM_MAX);
      last_ptc_update = current_time;
   heaterPid.Compute(); // Calculate PID value
   // Adjust PWM Duty based on the PID
   if(heater_mode) {
   } else {
   //Check if it's time to update the LCD
   if(current_time - last_lcd_update > LCD_INTERVAL) {
      lcd.setCursor(0, 0);
      if((temperature > TEMP_WO_IRON-5) && (temperature < TEMP_WO_IRON+5)){
         heater_mode = OFF;
         lcd.print("     Please     ");
         lcd.print("  Connect Iron  ");
         if (flash_on < FLASH_ON/LCD_INTERVAL){ // stay on for FLASH_ON ms
            setColor(255, 0, 0);  // red
            flash_on++;
            flash_off = 0;
         else{
            if(flash_off < FLASH_OFF/LCD_INTERVAL){ // stay off for FLASH_OFF ms
               setColor(0, 0, 0);
               flash_off++;
            else flash_on = 0;
      else{
         if (!showPID) {
            //1st Row
            lcd.write(byte(0));
            lcd.print(' ');
            if (temp_5){
               if (temperature < 98) lcd.print(' ');
               if (int(temperature) % 5 < 3){
                  lcd.print(int(temperature / 5) * 5);
               else{
                  lcd.print(int(temperature / 5 + 1) * 5);
            else{
               if (temperature < 100) lcd.print(' ');
               lcd.print(temperature, 0);
            lcd.print("C ");
            printGraph(setpoint, temperature);
            //2nd Row
            if (!digitalRead(REED)) lcd.print(char(219));
            else lcd.print(" ");
            lcd.print(" ");
            lcd.print(setpoint, 0);
            lcd.print("C ");
            //print duty
            int power;
            if (heater_mode) power = duty * (100.0/1023);
            //if (heater_mode) power = duty * (100.0/PWM_MAX);
            else power = 0;
            if (power < 10) lcd.print("  ");
            else if (power < 100) lcd.print(" ");
            lcd.print(power);
            lcd.print("% ");
            if (heater_mode){
               if (sleeping) lcd.print("_zZ");
               else{
                  lcd.print(" ");
                  lcd.write(byte(1));
                  lcd.print("N");
            else{
               lcd.print("OFF");
         else displayPid();
         if (!heater_mode) setColor(255, 255, 255);  // white
      last_lcd_update = current_time;
// Read Iron temperature
uint16_t readTemp() {
   uint16_t temp = 0;
   // Discard first reading
   analogRead(TEMP_PIN);
   // Read temperature eight times
   for (int i = 0; i < 8; i++){
      temp += analogRead(TEMP_PIN);
   temp = (temp >> 3);
   temp = (EQUATION_A*temp) + EQUATION_B;
   return temp;
uint16_t readPot() {
   uint16_t pot = 0;
   analogRead(POT);
   // Read the potentiometer four times
   pot += analogRead(POT);
   // Map the value read to the temperature range
   pot = map(pot, 0, 4092, MIN_TEMP, MAX_TEMP);
   if (pot % 5 < 3) return pot / 5 * 5;
   else return (pot / 5 + 1) * 5;
// Check if heater start button was pressed
void checkButton() {
   heatButton.listen();
   increaseBrightButton.listen();
   temp_5_Button.listen();
   pidButton.listen();
   //Button1
   if(heatButton.onPress()) {
      if (showPID) autoTurnOFF = !autoTurnOFF;
      else{
         if (heater_mode){
            heater_mode = OFF;
         else{
            ironLifted = OFF;
            heater_mode = ON;
      delay(BUZ_DUR);
   //Button2
   if (increaseBrightButton.onPress()){
      if (++bright > 10) bright = 1;
      delay(BUZ_DUR);
   //Button3
   if (temp_5_Button.onPress()){
      temp_5 = !temp_5;
      delay(BUZ_DUR);
   //Button4
   if (pidButton.onPress()){
      if (!showPID){
         showPID = ON;
      else{
         showPID = OFF;
         EEPROM.writeInt(bright_address, bright);
         EEPROM.writeInt(temp_5_address, temp_5);
         EEPROM.writeInt(autoTurnOFF_address, autoTurnOFF);
      delay(BUZ_DUR);
// Display PID Constants
void displayPid() {
   lcd.clear();
   lcd.print("P:");
   lcd.print(kp, 2);
   lcd.print(" I:");
   lcd.print(ki, 2);
   if(temp_5) lcd.print(" 5");
   else lcd.print(" 1");
   lcd.print("D:");
   lcd.print(kd, 2);
   lcd.print(" slp");
   if (autoTurnOFF) lcd.print("Y");
   else lcd.print("N");
   lcd.print(" ");
   if (showAnalog){
      uint16_t temp_analog = 0;
      for (int i=0; i<5; i++){
         temp_analog += analogRead(TEMP_PIN);
      lcd.print(temp_analog/5);
void setBrightness(int light){
   light = map(light, 0, 10, 245, 10);
   analogWrite(LCD_LED, light);
void setColor(int red, int green, int blue){
   analogWrite(LED_R, 255-red);
   analogWrite(LED_G, 255-green);
   analogWrite(LED_B, 255-blue);
void lightRGB(double setpoint, double termperature){
   double diff = setpoint - temperature;
   if (diff > RGB_EFECT_MIN) diff = RGB_EFECT_MIN;
   else if (diff < -RGB_EFECT_MAX) diff = -RGB_EFECT_MAX;
   if (diff < 0){
      diff = map(diff, -RGB_EFECT_MAX, 0, 255, 0);
      setColor(diff, 255-diff, 0);
   else{
      diff = map(diff, 0, RGB_EFECT_MIN, 0, 255);
      setColor(0, 255-diff, diff);
void printGraph(double setpoint, double termperature){
   double diff = temperature - setpoint;
   int boxes;
   if (diff > BAR_STEP*7) boxes = 7;
   else if (diff < -BAR_STEP*7) boxes = -7;
   else boxes = diff / BAR_STEP;
   int blanks = -abs(boxes)/2+3.5;
   //if temp = setpoint
   if (boxes == 0){
      for (int i = 0; i < 3; i++){
         lcd.write(byte(2));
      lcd.write(byte(3));
      lcd.write(byte(4));
         lcd.write(byte(2));
   //if temp < setpoint
   else if (boxes < 0) {
      //print blanks
      for (int i = 0; i < blanks; i++){
         lcd.write(byte(2));
      //print first box
      if (boxes %2 == 0) lcd.write(byte(3));
      else lcd.write(byte(5));
      //print full box/es
      for (int i=0; i < 3-blanks; i++){
         lcd.write(byte(7));
      //print 4 blanks
      for (int i=0; i < 4; i++){
         lcd.write(byte(2));
   //if temp > setpoint
   else{
      //print 4 blanks
      for (int i = 0; i < 4; i++){
         lcd.write(byte(2));
      //print full box/es
         lcd.write(byte(7));
      //print last box
      if (boxes %2 == 0) lcd.write(byte(4));
      else lcd.write(byte(6));
      //print blanks
         lcd.write(byte(2));
|    2    |    3    |    4    |    5    |    6     |    7    |
void charSetup() {
   byte therm[8] = {0b10010,0b11010,0b10010,0b11010,0b10010,0b11110,0b11110,0b11110};
   byte on[8] = {0b00100,0b00100,0b10101,0b10001,0b10001,0b10001,0b01110,0b00000};
   byte bar[7][8] = {
      {0b11011,  0b00000,  0b00000,  0b00000,  0b00000,  0b00000,  0b00000,  0b11011 },
      {0b11011,  0b00000,  0b00000,  0b00011,  0b00011,  0b00000,  0b00000,  0b11011 },
      {0b11011,  0b00000,  0b00000,  0b11000,  0b11000,  0b00000,  0b00000,  0b11011 },
      {0b11011,  0b00000,  0b00011,  0b11011,  0b11011,  0b00011,  0b00000,  0b11011 },
      {0b11011,  0b00000,  0b11000,  0b11011,  0b11011,  0b11000,  0b00000,  0b11011 },
      {0b11011,  0b00000,  0b11011,  0b11011,  0b11011,  0b11011,  0b00000,  0b11011 }
   lcd.createChar(0, therm);
   lcd.createChar(1, on);
   lcd.createChar(2, bar[0]);
   lcd.createChar(3, bar[1]);
   lcd.createChar(4, bar[2]);
   lcd.createChar(5, bar[3]);
   lcd.createChar(6, bar[4]);
   lcd.createChar(7, bar[5]);
e l ho leggermente modificato cosi per mettere un lcd ic2
# Change Log
## [0.6b:]
## [0.6:]
## [0.5:]
## [0.4:]
- new progress bar
- new temp icon
## [0.3:]
## [0.2:]
- Auto turn off
## [0.1b:]
- initial release
#include <LiquidCrystal_I2C.h>
#include <Wire.h>
#include "Button.h"
#include "PID_v1.h"
#define OFF         0
#define ON         1
// PIN DEFINITIONS
#define HEATER       3
#define TEMP_PIN   0
#define POT         A7
#define REED       2
#define Button1      4
#define Button2      5
#define Button3      6
#define Button4      7
#define Buzzer      13
//LCD
#define LCD_LED      10
//LED
int flash_on = 0;
int flash_off = 0;
//SETTINGS
char ver[] = "0.6";
// PID VALUES
#define KI_VAL      3.50
// Global variables
// PID Variables
double temperature;
double duty;
double kp;
double ki;
double kd;
LiquidCrystal_I2C lcd(0x27,16,2);
void setup() {
   lcd.init();
  lcd.backlight();
   // Autotune
   // Set up pins
   // Set up PID
   // Set up LCD
   charSetup();
      clearEEPROM = ON;
      autotune = ON;
   //Reset EEPROM
   if (clearEEPROM){
      setBrightness(10);
      lcd.clear();
            lcd.clear();
               delay(BUZ_DUR);
               delay(BUZ_DUR*15);
            clearEEPROM = OFF;
         wdt_reset();
   else if (autotune){
      setBrightness(10);
      lcd.clear();
      while (autotune){
            lcd.clear();
            lcd.print("C");
               wdt_reset();
               wdt_reset();
            while(autotune) {
                  autotune = OFF;
               else {
               if(!autotune) {
                  kp = aTune.GetKp();
                  ki = aTune.GetKi();
                  kd = aTune.GetKd();
                  setpoint = 0.0;
               wdt_reset();
               delay(BUZ_DUR);
               delay(BUZ_DUR*15);
            autotune = OFF;
         wdt_reset();
   if(boot_screen){
         lcd.clear();
         lcd.print(ver);
         boot_screen = 0;
         delay(BUZ_DUR);
      wdt_reset();
   else{
      kp = KP_VAL;
      ki = KI_VAL;
      kd = KD_VAL;
   lcd.clear();
void loop() {
   wdt_reset();
   checkButton();
   if(heater_mode) {
         if (autoTurnOFF) {
            if (sleeping){
                  heater_mode = OFF;
                  delay(BUZ_DUR);
               sleeping = ON;
               delay(BUZ_DUR);
      else{
         if (sleeping){
            sleeping = OFF;
            delay(BUZ_DUR);
      if(heater_mode){
               heater_mode = OFF;
               delay(BUZ_DUR);
   if(heater_mode) {
   } else {
         heater_mode = OFF;
            flash_on++;
            flash_off = 0;
         else{
               setColor(0, 0, 0);
               flash_off++;
            else flash_on = 0;
      else{
         if (!showPID) {
            //1st Row
            lcd.write(byte(0));
            lcd.print(' ');
            if (temp_5){
               else{
            else{
            lcd.print("C ");
            //2nd Row
            lcd.print(" ");
            lcd.print("C ");
            //print duty
            int power;
            else power = 0;
            lcd.print(power);
            lcd.print("% ");
            if (heater_mode){
               else{
                  lcd.print(" ");
                  lcd.write(byte(1));
                  lcd.print("N");
            else{
               lcd.print("OFF");
         else displayPid();
   uint16_t temp = 0;
   temp = (temp >> 3);
   return temp;
   uint16_t pot = 0;
   analogRead(POT);
   pidButton.listen();
   //Button1
      else{
         if (heater_mode){
            heater_mode = OFF;
         else{
            ironLifted = OFF;
            heater_mode = ON;
      delay(BUZ_DUR);
   //Button2
      delay(BUZ_DUR);
   //Button3
      temp_5 = !temp_5;
      delay(BUZ_DUR);
   //Button4
      if (!showPID){
         showPID = ON;
      else{
         showPID = OFF;
      delay(BUZ_DUR);
void displayPid() {
   lcd.clear();
   lcd.print("P:");
   lcd.print(kp, 2);
   lcd.print(" I:");
   lcd.print(ki, 2);
   lcd.print("D:");
   lcd.print(kd, 2);
   lcd.print(" slp");
   lcd.print(" ");
   if (showAnalog){
   if (diff < 0){
   else{
   int boxes;
   if (boxes == 0){
         lcd.write(byte(2));
      lcd.write(byte(3));
      lcd.write(byte(4));
         lcd.write(byte(2));
      //print blanks
         lcd.write(byte(2));
      //print first box
      //print full box/es
         lcd.write(byte(7));
      //print 4 blanks
         lcd.write(byte(2));
   else{
      //print 4 blanks
         lcd.write(byte(2));
      //print full box/es
         lcd.write(byte(7));
      //print last box
      //print blanks
         lcd.write(byte(2));
void charSetup() {
   byte bar[7][8] = {
funziona, cioe' in parte..(in entrambi i modi), quando vado ad accendere il saldatore, mi scrive on ma non esce segnale e non mi riscalda la punta.
la temperatura e corretta, e mi da circa quella dell ambiente, ma se lo scaldo con la mado o con un altro saldatore la temperatura sale
pero non funziona , arduino nuovo mosfet nuovo, provato ad mettere segnale sul gate e funziona
ho provato con autotune, mettendo la punta in temperatura piu o meno a 250 gradi.ma nulla...scondo voi cosa sto sbagliando...
a questo punto vi chiedo se esiste un semplicissimo controller per lo stilo 907,che funzioni..visto che ne ho messi di vari ma o perche non riesco a convertirli a ic2 o perche non riesco a farli andare mi sono scoraggiato...
mi potreste dare qualche dritta?
grazie mille
243 2 4 7
[2] Re: stazione saldante problema
Messaggioda Foto UtentePaolino » 4 nov 2019, 18:31
Hai eseguito tutti i passaggi, compresi quelli indicati nella guida? Nessun problema riscontrato?
Ciao.
Paolo.
Foto UtentePaolino
32,6k 8 12 13
[3] Re: stazione saldante problema
Messaggioda Foto Utenteedgar » 4 nov 2019, 19:24
Ho realizzato un controller per quel tipo di stilo preso da un altro progetto. Il controller funziona, però lo stilo (presi 3 su aliexpress a un prezzo infimo) fa pena. La punta raggiunge la temperatura impostata ma quando fai una saldatura su un componente appena appena un po' più grande di un reoforo, la temperatura della punta crolla e vengono saldature inguardabili. Cerca piuttosto saldatori basati sullo stilo T12 da 50 o meglio ancora il T13 da 70 watt. Uso il 50 W da tempo e va decentemente. Quando devo fare saldature impegnative ho una vecchia stazione Weller TCP da 50W che uso con parsimonia perché le punte hanno prezzi da gioielleria e, non so se a causa della lega sn/pb, durano poco. :-|
Foto Utenteedgar
10,0k 4 5 8
[4] Re: stazione saldante problema
Messaggioda Foto Utentepusillus » 4 nov 2019, 21:55
Una volta ho provato a realizzare Anche io una stazione saldante
viewtopic.php?f=15&t=67050&p=684323&hilit=Stazione#p684323
ma, come anche altri ti hanno detto, ho riscontrato che questo prodotto cinese è di pessima fattura.
Ho comunque acquistato su aliexpress una staziona bakon 950d che è compatibile con le punte t13 della hakko, ma di possono montare anche le t12 che su Aliexpress si trovano a pochi euro.
Foto Utentepusillus
3.207 3 6 11
[5] Re: stazione saldante problema
Messaggioda Foto Utentedanielealfa » 4 nov 2019, 23:22
grazie delle vostre preziosissime informazioni, ho guardato ma il t13 non e' cosi tanto commerciale che non ho trovato nulla ...invece il t12 ce ne a iosa.
allora lascio stare e vado di t12.
che voi sappiate esiste qualcosa con ardiuno con lcd per il saldatore con la t12?
243 2 4 7
[6] Re: stazione saldante problema
Messaggioda Foto Utenteedgar » 4 nov 2019, 23:31
Ho preferito prendere il controller già fatto con diplay a 7 segmenti, costava una sciocchezza.
Foto Utenteedgar
10,0k 4 5 8
[7] Re: stazione saldante problema
Messaggioda Foto Utentedanielealfa » 4 nov 2019, 23:49
ok un modello vale l altro?
perche tipo su banggood , quello piu fornito , (su amazon non ci sono e su ebay sono tutti in cina)ve ne sono vari tipi
243 2 4 7
[8] Re: stazione saldante problema
Messaggioda Foto Utenteedgar » 5 nov 2019, 0:12
Anche Banggood spedisce dalla Cina buona parte degli articoli. Ha prezzi leggermente più alti di Aliexpress ma spesso il materiale arriva prima, specie se si usa "priority direct line".
Ci sono vari kit, dal controller alla stazione completa, a te valutare quale può fare al caso tuo.
Se non avessi la stazione Weller farei un pensiero anche a questo basato sullo stilo T13
Foto Utenteedgar
10,0k 4 5 8
[9] Re: stazione saldante problema
Messaggioda Foto Utentedanielealfa » 5 nov 2019, 0:22
questa semplice semplice che ne dici?
il box non mi serve
https://www.banggood.com/it/STC-T12-Dig ... rehouse=CN
243 2 4 7
[10] Re: stazione saldante problema
Messaggioda Foto Utenteedgar » 5 nov 2019, 0:28
Con questa risparmi i soldi per un caffè :mrgreen:
Foto Utenteedgar
10,0k 4 5 8
Torna a Arduino
