Problema con programma OpenCV per rilevamento porte aperte
Linguaggi e sistemi
[1] Problema con programma OpenCV per rilevamento porte aperte
Messaggioda Foto Utentealien75 » 2 apr 2025, 12:31
Ho copiato in rete il seguente codice per il rilevemento di porte aperte o chiuse:
Codice: Seleziona tutto
import cv2
from numpy import *
test_imgs = ['day_open.jpg','day_closed.jpg','night_open.jpg','night_closed.jpg']
for imgFile in test_imgs:
    img = cv2.imread(imgFile)
    height, width, channels = img.shape
    mask = zeros((height+2, width+2), uint8)
    #the starting pixel for the floodFill
    start_pixel = (510,110)
    #maximum distance to start pixel:
    diff = (2,2,2)
    retval = cv2.floodFill(img, mask, start_pixel,(0,255,0),diff,diff)
    print(retval)
    #check the size of the floodfilled area, if its large the door is closed:
    if retval > 10000:
        print(imgFile + ": garage door closed")
    else:
        print(imgFile + ": garage door open")
    cv2.imwrite(imgFile.replace(".jpg", "") + "_result.jpg", img)
Se eseguo ottengo:
(3633211, array([[[ 48,  64,  77],
        [ 43,  59,  72],
        [ 40,  53,  67],
        [ 23,  37,  59],
        [ 24,  41,  62],
        [ 29,  46,  67]],
       [[ 49,  65,  78],
        [ 46,  62,  75],
        [ 43,  56,  70],
        [ 26,  40,  62],
        [ 23,  40,  61],
        [ 25,  42,  63]],
       [[ 49,  65,  77],
        [ 48,  64,  76],
        [ 46,  60,  72],
        [ 28,  41,  63],
        [ 19,  33,  55],
        [ 19,  33,  55]],
       [[ 66, 161, 204],
        [ 63, 161, 203],
        [ 58, 158, 200],
        [227, 241, 237],
        [227, 241, 237],
        [227, 241, 237]],
       [[ 68, 163, 207],
        [ 64, 161, 205],
        [ 58, 158, 200],
        [224, 238, 234],
        [225, 239, 235],
        [226, 241, 237]],
       [[ 68, 163, 207],
        [ 64, 161, 205],
        [ 58, 158, 200],
        [225, 239, 235],
        [225, 240, 236],
        [227, 242, 238]]], shape=(4000, 1800, 3), dtype=uint8), array([[1, 1, 1, ..., 1, 1, 1],
       [1, 0, 0, ..., 0, 0, 1],
       [1, 1, 1, ..., 1, 1, 1]], shape=(4002, 1802), dtype=uint8), (0, 0, 1800, 4000))
Traceback (most recent call last):
  File "/home/fabio/Scrivania/prova.py", line 21, in <module>
    if retval > 10000:
TypeError: '>' not supported between instances of 'tuple' and 'int'
Non accetta > perché ? Non capisco.
Devo fargli riconoscere porte aperte o chiuse.
Foto Utentealien75
1 1 4 8
[2] Re: Problema con programma opencv per rilevamento porte aper
Messaggioda Foto Utentexyz » 2 apr 2025, 13:14
Ti consiglio, se vuoi continuare a scrivere in Python, di studiarti bene il linguaggio, altrimenti sarei sempre bloccato al primo errore banale. C'è chiaramente scritto: non puoi confrontare una tuple con un intero.
Foto Utentexyz
6.864 2 4 6
Torna a PC e informatica
