"Mixer" per audio XboX
[11] Re: "Mixer" per audio XboX
Messaggioda extrems » 13 set 2011, 19:25
DonJ ha scritto: un mixerino tipo XENYX 802
POWERPLAY PRO-XL HA4700
4-Channel High-Power Headphones Mixing and Distribution Amplifier
Professional, multi-purpose headphones amplifier system for stage and studio applications
Highest sonic quality with virtually all types of headphones >8 ohm even at maximum volume
4 independent high-power amplifier sections provide up to four stereo mixes with individual balance controls
Each input/aux section can be separately adjusted for 'more me' mixing
Stereo Aux input for each channel allows you to mix in any instrument or sound source
Multi-functional Stereo/2-Channel switch on each channel allows for either stereo playback or double mono operation
Ultra-musical High and Low EQ per channel for perfect sound adaptation
Output level control with accurate 8-digit LED output meter per channel
Left/right Mute switches for each channel allow two different mixes in mono mode
1 front and 2 rear TRS output connectors per channel
Direct front panel input connector for easy connection of any sound source
Parallel Main outputs allow cascading of several headphones amplifiers
Servo-balanced inputs and outputs on 1/4" TRS and gold-plated XLR connectors
Toroidal transformer for lowest noise interference and highest audio quality
High-quality components and exceptionally rugged construction ensure long life
Conceived and designed by BEHRINGER Germany
extrems
327 2 4 5
[12] Re: "Mixer" per audio XboX
Messaggioda Foto UtenteDonJ » 13 set 2011, 21:47
HA4700 -> 88€
XENYX 802 -> 48€
@fasterthanlime
Foto UtenteDonJ
4.611 6 10 13
[13] Re: "Mixer" per audio XboX
Messaggioda Foto Utentefuturedj95 » 13 set 2011, 21:52
BEHRINGER MX400 direi che anche questo va bene.. ha entrate stereo.. :shock: (ancora non ci credo) me se è per i 40 euro.. xenyx 802 volando.. :mrgreen:
11 1 5
[14] Re: "Mixer" per audio XboX
Messaggioda Foto UtenteDonJ » 13 set 2011, 21:55
Uhm, in realtà considerando quello che serve a Foto Utentefabio978 il MX400 non va bene.
Ecco perché io e [user]XStreme[/user] abbiamo consigliato qualcosa di un po' più serio e versatile.
@fasterthanlime
Foto UtenteDonJ
4.611 6 10 13
[15] Re: "Mixer" per audio XboX
Messaggioda Foto Utentefuturedj95 » 13 set 2011, 22:15
penso che con le entrate stereo si eviti un sacco di adattatori e viadicendo..però lo xenyx è un prodotto superiore :D
11 1 5
[16] Re: "Mixer" per audio XboX
Messaggioda Foto UtenteDonJ » 13 set 2011, 22:26
Beh considera che ci sono tre entrate stereo e due mono, più che sufficienti per quello che vuole fare il nostro amico.
edit: anzi, volendo sono anche 4 ingressi stereo.
@fasterthanlime
Foto UtenteDonJ
4.611 6 10 13
[17] Re: "Mixer" per audio XboX
Messaggioda extrems » 13 set 2011, 22:41
futuredj95 ha scritto:BEHRINGER MX400 direi che anche questo va bene.. ha entrate stereo.. :shock: (ancora non ci credo) me se è per i 40 euro.. xenyx 802 volando.. :mrgreen:
Comprati 40 euro di rumore di fondo....corri..corri... :mrgreen:
Scherzi a parte, io li ho provato tutti e due, l'802 l'ho fatto volare dalla finestra.
extrems
327 2 4 5
[18] Re: "Mixer" per audio XboX
Messaggioda Foto UtenteDonJ » 13 set 2011, 22:43
Vabè ma un conto è tenerselo in casa, un conto in uno studio di registrazione.
@fasterthanlime
Foto UtenteDonJ
4.611 6 10 13
[19] Re: "Mixer" per audio XboX
Messaggioda extrems » 13 set 2011, 23:28
DonJ ha scritto:Vabè ma un conto è tenerselo in casa, un conto in uno studio di registrazione.
In quella fascia di prezzo preferisco questo, meno spartano e audio molto più discreto.
SAMSON S-MIX Personal mixer 5 ingressi
60 €
extrems
327 2 4 5
[20] Re: "Mixer" per audio XboX
Messaggioda Foto UtenteDonJ » 13 set 2011, 23:35
Giusto.
Ma tu hai l'orecchio allenato, non penso che Foto Utentefabio978 tra la chat e i PEW! PEW! dei giochi della Xbox si preoccupi del fruscio di fondo :mrgreen:
@fasterthanlime
Foto UtenteDonJ
4.611 6 10 13
