DonJ ha scritto: un mixerino tipo XENYX 802
POWERPLAY PRO-XL HA4700
4-Channel High-Power Headphones Mixing and Distribution Amplifier
Professional, multi-purpose headphones amplifier system for stage and studio applications
Highest sonic quality with virtually all types of headphones >8 ohm even at maximum volume
4 independent high-power amplifier sections provide up to four stereo mixes with individual balance controls
Each input/aux section can be separately adjusted for 'more me' mixing
Stereo Aux input for each channel allows you to mix in any instrument or sound source
Multi-functional Stereo/2-Channel switch on each channel allows for either stereo playback or double mono operation
Ultra-musical High and Low EQ per channel for perfect sound adaptation
Output level control with accurate 8-digit LED output meter per channel
Left/right Mute switches for each channel allow two different mixes in mono mode
1 front and 2 rear TRS output connectors per channel
Direct front panel input connector for easy connection of any sound source
Parallel Main outputs allow cascading of several headphones amplifiers
Servo-balanced inputs and outputs on 1/4" TRS and gold-plated XLR connectors
Toroidal transformer for lowest noise interference and highest audio quality
High-quality components and exceptionally rugged construction ensure long life
Conceived and designed by BEHRINGER Germany
