LCD con 16F684
Raccolta di codici sorgenti
[1] LCD con 16F684
Messaggioda Foto Utentestepsan78 » 16 dic 2008, 17:40
Salve,
sono agli inizi con i PIC..e ho un problema. Non riesco a visualizzare una scritta su un display LCD a 2 righe. Il PIC che uso e' un 16F684. Vi allego lo schema elettrico e il programma (ho cercato di adattare un esempio di Zampilli per il 16F684).
Il problema è che non vedo niente sul display...
[img]<img%20src="http://immagini.p2pforum.it/out.php/i394986_LCD.JPG"%20alt=""%20/>[/img]
PROCESSOR 16F684
RADIX DEC
INCLUDE "P16F684.INC"
;Suppress MPASM warning message 302:
;"Register in operand not in bank 0. Ensure that bank bits are correct"
__config (_INTRC_OSC_NOCLKOUT & _WDT_OFF & _PWRTE_OFF & _MCLRE_OFF & _CP_OFF & _BOD_OFF & _IESO_OFF & _FCMEN_OFF)
;LCD Control lines
LCD_RS equ 0 ;Register Select
LCD_E equ 1 ;Enable
;LCD data line bus
LCD_DB4 equ 2 ;LCD data line DB4
LCD_DB5 equ 3 ;LCD data line DB5
LCD_DB6 equ 4 ;LCD data line DB6
LCD_DB7 equ 5 ;LCD data line DB7
ORG 020H
tmpLcdRegister res 2
msDelayCounter res 2
;Reset Vector
ORG 00H
Start
bsf STATUS,RP0 ;Swap to register bank 1
movlw 00011111B ;Set PORTA lines
movwf TRISA
movlw 00000000B ;Set PORTC lines
movwf TRISC
; bcf PORTC,LCD_DB4 ;Set as output just the LCD's lines
; bcf PORTC,LCD_DB5
; bcf PORTC,LCD_DB6
; bcf PORTC,LCD_DB7
; bcf PORTC,LCD_E
;bcf PORTC,LCD_RS
bcf STATUS,RP0 ;Swap to register bank 0
;LCD inizialization
call LcdInit
;Locate LCD cursor on row 0, col 0
movlw 10H
call LcdLocate
;Shows "HELLO WORLD" string on LCD
movlw 'H'
call LcdSendData
movlw 'E'
call LcdSendData
movlw 'L'
call LcdSendData
movlw 'L'
call LcdSendData
movlw 'O'
call LcdSendData
movlw ' '
call LcdSendData
movlw 'W'
call LcdSendData
movlw 'O'
call LcdSendData
movlw 'R'
call LcdSendData
movlw 'L'
call LcdSendData
movlw 'D'
call LcdSendData
movlw ' '
call LcdSendData
movlw '!'
call LcdSendData
foreverLoop
goto foreverLoop
; Delay subroutine
; W = Requested delay time in ms (clock = 4MHz)
msDelay
movwf msDelayCounter+1
clrf msDelayCounter+0
; 1 ms (about) internal loop
msDelayLoop
nop
decfsz msDelayCounter+0,F
goto msDelayLoop
nop
decfsz msDelayCounter+1,F
goto msDelayLoop
return
; Init LCD
; This subroutine must be called before each other lcd subroutine
LcdInit
movlw 30 ;Wait 30 ms
call msDelay
; Reset sequence
bcf PORTC,LCD_RS ;Set LCD command mode
;Send a reset sequence to LCD
bsf PORTC,LCD_DB4
bsf PORTC,LCD_DB5
bcf PORTC,LCD_DB6
bcf PORTC,LCD_DB7
bsf PORTC,LCD_E ;Enables LCD
movlw 5 ;Wait 5 ms
call msDelay
bcf PORTC,LCD_E ;Disables LCD
movlw 1 ;Wait 1ms
call msDelay
movlw 1 ;Wait 1ms
call msDelay
movlw 1 ;Wait 1ms
call msDelay
bsf PORTC,LCD_E ;Enables E
movlw 1 ;Wait 1ms
call msDelay
bcf PORTC,LCD_E ;Disables E
movlw 1 ;Wait 1ms
call msDelay
bcf PORTC,LCD_DB4
bsf PORTC,LCD_DB5
bcf PORTC,LCD_DB6
bcf PORTC,LCD_DB7
movlw 1 ;Wait 1ms
call msDelay
bcf PORTC,LCD_E ;Disabled LCD
movlw 1 ;Wait 1ms
call msDelay
;Set 4 bit data bus length
movlw 28H;
call LcdSendCommand
;Entry mode set, increment, no shift
movlw 06H;
call LcdSendCommand
;Display ON, Curson ON, Blink OFF
movlw 0EH
call LcdSendCommand
;Clear display
call LcdClear
return
; Clear LCD
LcdClear
;Clear display
movlw 01H
call LcdSendCommand
movlw 2 ;Wait 2 ms
call msDelay
;DD RAM address set 1st digit
movlw 80H;
call LcdSendCommand
return
; Locate cursor on LCD
; W = D7-D4 row, D3-D0 col
LcdLocate
movwf tmpLcdRegister+0
movlw 80H
movwf tmpLcdRegister+1
movf tmpLcdRegister+0,W
andlw 0FH
iorwf tmpLcdRegister+1,F
btfsc tmpLcdRegister+0,4
bsf tmpLcdRegister+1,6
movf tmpLcdRegister+1,W
call LcdSendCommand
return
; Send a data to LCD
LcdSendData
bsf PORTC,LCD_RS
call LcdSendByte
return
; Send a command to LCD
LcdSendCommand
bcf PORTC,LCD_RS
call LcdSendByte
return
; Send a byte to LCD by 4 bit data bus
LcdSendByte
;Save value to send
;Send highter four bits
bcf PORTC,LCD_DB4
bcf PORTC,LCD_DB5
bcf PORTC,LCD_DB6
bcf PORTC,LCD_DB7
btfsc tmpLcdRegister,4
bsf PORTC,LCD_DB4
btfsc tmpLcdRegister,5
bsf PORTC,LCD_DB5
btfsc tmpLcdRegister,6
bsf PORTC,LCD_DB6
btfsc tmpLcdRegister,7
bsf PORTC,LCD_DB7
movlw 1 ;Wait 1ms
call msDelay
movlw 1 ;Wait 1ms
call msDelay
;Send lower four bits
bcf PORTC,LCD_DB4
bcf PORTC,LCD_DB5
bcf PORTC,LCD_DB6
bcf PORTC,LCD_DB7
btfsc tmpLcdRegister,0
bsf PORTC,LCD_DB4
btfsc tmpLcdRegister,1
bsf PORTC,LCD_DB5
btfsc tmpLcdRegister,2
bsf PORTC,LCD_DB6
btfsc tmpLcdRegister,3
bsf PORTC,LCD_DB7
movlw 1 ;Wait 1ms
call msDelay
movlw 1 ;Wait 1ms
call msDelay
return
END
0 3
[2] Re: LCD con 16F684
Messaggioda Foto Utentestepsan78 » 16 dic 2008, 17:42
provo a visualizzare l'immagine..
Immagine
0 3
[3] Re: LCD con 16F684
Messaggioda Foto UtentePaolino » 16 dic 2008, 19:16
Hai provato a regolare il contrasto con il trimmer R2? Di solito il trimmer deve avere una resistenza da 5k o da 10k; da 2k mi sembra un po' pochino...
Regolando il contrasto dovresti aver modo di visualizzare qualcosa, anche solo dei quadrati "neri".
Ciao.
Paolo.
Foto UtentePaolino
32,6k 8 12 13
[4] Re: LCD con 16F684
Messaggioda Foto Utentestepsan78 » 16 dic 2008, 20:01
c'è un trimmer da 1K che nello schema non si vede il valore. Regolandolo, vedo una riga di quadrati neri, ma non la scritta "hello world" ...
0 3
[5] Re: LCD con 16F684
Messaggioda Foto UtentePaolino » 17 dic 2008, 9:36
Guardando il datasheet ho notato che nella configurazione delle porte del tuo codice manca una parte:
Codice: Seleziona tutto
PROCESSOR 16F684
RADIX DEC
;LCD Control lines
LCD_E equ 1 ;Enable
;LCD data line bus
ORG 020H
;Reset Vector
ORG 00H
Start
; Codice preso dal DATASHEET
; Disattivazione del comparatore
BCF STATUS,RP0 ;Bank 0
CLRF PORTA ;Init PORTA
MOVLW 07h ;Set RA<2:0> to
MOVWF CMCON0 ;digital I/O
BSF STATUS,RP0 ;Bank 1
CLRF ANSEL ;digital I/O
movwf TRISA
; Disattivazione degli ingressi analogici
BANKSEL PORTC ;
CLRF PORTC ;Init PORTC
;MOVLW 07h ;Set RC<4,1:0> to
;MOVWF CMCON0 ;digital I/O
BANKSEL ANSEL ;
MOVLW 00h ;IMPOSTAZIONE DI PORTC COME OUTPUT
MOVWF TRISC ;
Il dispositivo PIC16F684 ha gli ingressi analogici e il comparatore che vanno disattivati. Prova così e poi fammi sapere.
Ciao.
Paolo.
Foto UtentePaolino
32,6k 8 12 13
[6] Re: LCD con 16F684
Messaggioda Foto Utentestepsan78 » 17 dic 2008, 11:36
Funziona! adesso vedo finalmente la scritta. Grazie mille!!
0 3
