Salve,
sono agli inizi con i PIC..e ho un problema. Non riesco a visualizzare una scritta su un display LCD a 2 righe. Il PIC che uso e' un 16F684. Vi allego lo schema elettrico e il programma (ho cercato di adattare un esempio di Zampilli per il 16F684).
Il problema è che non vedo niente sul display...
[img]<img%20src="http://immagini.p2pforum.it/out.php/i394986_LCD.JPG"%20alt=""%20/>[/img]
PROCESSOR 16F684
RADIX DEC
INCLUDE "P16F684.INC"
;Suppress MPASM warning message 302:
;"Register in operand not in bank 0. Ensure that bank bits are correct"
__config (_INTRC_OSC_NOCLKOUT & _WDT_OFF & _PWRTE_OFF & _MCLRE_OFF & _CP_OFF & _BOD_OFF & _IESO_OFF & _FCMEN_OFF)
;LCD Control lines
LCD_RS equ 0 ;Register Select
LCD_E equ 1 ;Enable
;LCD data line bus
LCD_DB4 equ 2 ;LCD data line DB4
LCD_DB5 equ 3 ;LCD data line DB5
LCD_DB6 equ 4 ;LCD data line DB6
LCD_DB7 equ 5 ;LCD data line DB7
ORG 020H
tmpLcdRegister res 2
msDelayCounter res 2
;Reset Vector
ORG 00H
Start
bsf STATUS,RP0 ;Swap to register bank 1
movlw 00011111B ;Set PORTA lines
movwf TRISA
movlw 00000000B ;Set PORTC lines
movwf TRISC
; bcf PORTC,LCD_DB4 ;Set as output just the LCD's lines
; bcf PORTC,LCD_DB5
; bcf PORTC,LCD_DB6
; bcf PORTC,LCD_DB7
; bcf PORTC,LCD_E
;bcf PORTC,LCD_RS
bcf STATUS,RP0 ;Swap to register bank 0
;LCD inizialization
call LcdInit
;Locate LCD cursor on row 0, col 0
movlw 10H
call LcdLocate
;Shows "HELLO WORLD" string on LCD
movlw 'H'
call LcdSendData
movlw 'E'
call LcdSendData
movlw 'L'
call LcdSendData
movlw 'L'
call LcdSendData
movlw 'O'
call LcdSendData
movlw ' '
call LcdSendData
movlw 'W'
call LcdSendData
movlw 'O'
call LcdSendData
movlw 'R'
call LcdSendData
movlw 'L'
call LcdSendData
movlw 'D'
call LcdSendData
movlw ' '
call LcdSendData
movlw '!'
call LcdSendData
foreverLoop
goto foreverLoop
; Delay subroutine
; W = Requested delay time in ms (clock = 4MHz)
msDelay
movwf msDelayCounter+1
clrf msDelayCounter+0
; 1 ms (about) internal loop
msDelayLoop
nop
decfsz msDelayCounter+0,F
goto msDelayLoop
nop
decfsz msDelayCounter+1,F
goto msDelayLoop
return
; Init LCD
; This subroutine must be called before each other lcd subroutine
LcdInit
movlw 30 ;Wait 30 ms
call msDelay
; Reset sequence
bcf PORTC,LCD_RS ;Set LCD command mode
;Send a reset sequence to LCD
bsf PORTC,LCD_DB4
bsf PORTC,LCD_DB5
bcf PORTC,LCD_DB6
bcf PORTC,LCD_DB7
bsf PORTC,LCD_E ;Enables LCD
movlw 5 ;Wait 5 ms
call msDelay
bcf PORTC,LCD_E ;Disables LCD
movlw 1 ;Wait 1ms
call msDelay
movlw 1 ;Wait 1ms
call msDelay
movlw 1 ;Wait 1ms
call msDelay
bsf PORTC,LCD_E ;Enables E
movlw 1 ;Wait 1ms
call msDelay
bcf PORTC,LCD_E ;Disables E
movlw 1 ;Wait 1ms
call msDelay
bcf PORTC,LCD_DB4
bsf PORTC,LCD_DB5
bcf PORTC,LCD_DB6
bcf PORTC,LCD_DB7
movlw 1 ;Wait 1ms
call msDelay
bcf PORTC,LCD_E ;Disabled LCD
movlw 1 ;Wait 1ms
call msDelay
;Set 4 bit data bus length
movlw 28H;
call LcdSendCommand
;Entry mode set, increment, no shift
movlw 06H;
call LcdSendCommand
;Display ON, Curson ON, Blink OFF
movlw 0EH
call LcdSendCommand
;Clear display
call LcdClear
return
; Clear LCD
LcdClear
;Clear display
movlw 01H
call LcdSendCommand
movlw 2 ;Wait 2 ms
call msDelay
;DD RAM address set 1st digit
movlw 80H;
call LcdSendCommand
return
; Locate cursor on LCD
; W = D7-D4 row, D3-D0 col
LcdLocate
movwf tmpLcdRegister+0
movlw 80H
movwf tmpLcdRegister+1
movf tmpLcdRegister+0,W
andlw 0FH
iorwf tmpLcdRegister+1,F
btfsc tmpLcdRegister+0,4
bsf tmpLcdRegister+1,6
movf tmpLcdRegister+1,W
call LcdSendCommand
return
; Send a data to LCD
LcdSendData
bsf PORTC,LCD_RS
call LcdSendByte
return
; Send a command to LCD
LcdSendCommand
bcf PORTC,LCD_RS
call LcdSendByte
return
; Send a byte to LCD by 4 bit data bus
LcdSendByte
;Save value to send
;Send highter four bits
bcf PORTC,LCD_DB4
bcf PORTC,LCD_DB5
bcf PORTC,LCD_DB6
bcf PORTC,LCD_DB7
btfsc tmpLcdRegister,4
bsf PORTC,LCD_DB4
btfsc tmpLcdRegister,5
bsf PORTC,LCD_DB5
btfsc tmpLcdRegister,6
bsf PORTC,LCD_DB6
btfsc tmpLcdRegister,7
bsf PORTC,LCD_DB7
movlw 1 ;Wait 1ms
call msDelay
movlw 1 ;Wait 1ms
call msDelay
;Send lower four bits
bcf PORTC,LCD_DB4
bcf PORTC,LCD_DB5
bcf PORTC,LCD_DB6
bcf PORTC,LCD_DB7
btfsc tmpLcdRegister,0
bsf PORTC,LCD_DB4
btfsc tmpLcdRegister,1
bsf PORTC,LCD_DB5
btfsc tmpLcdRegister,2
bsf PORTC,LCD_DB6
btfsc tmpLcdRegister,3
bsf PORTC,LCD_DB7
movlw 1 ;Wait 1ms
call msDelay
movlw 1 ;Wait 1ms
call msDelay
return
END
LCD con 16F684
Moderatore:
Paolino
6 messaggi
Hai provato a regolare il contrasto con il trimmer R2? Di solito il trimmer deve avere una resistenza da 5k o da 10k; da 2k mi sembra un po' pochino...
Regolando il contrasto dovresti aver modo di visualizzare qualcosa, anche solo dei quadrati "neri".
Ciao.
Paolo.
Ciao.
Paolo.
Paolino
32,6k 8 12 13 - G.Master EY
c'è un trimmer da 1K che nello schema non si vede il valore. Regolandolo, vedo una riga di quadrati neri, ma non la scritta "hello world" ...
Guardando il datasheet ho notato che nella configurazione delle porte del tuo codice manca una parte:
Il dispositivo PIC16F684 ha gli ingressi analogici e il comparatore che vanno disattivati. Prova così e poi fammi sapere.
Ciao.
Paolo.
- Codice: Seleziona tutto
PROCESSOR 16F684
RADIX DEC
;LCD Control lines
LCD_E equ 1 ;Enable
;LCD data line bus
ORG 020H
;Reset Vector
ORG 00H
Start
; Codice preso dal DATASHEET
; Disattivazione del comparatore
BCF STATUS,RP0 ;Bank 0
CLRF PORTA ;Init PORTA
MOVLW 07h ;Set RA<2:0> to
MOVWF CMCON0 ;digital I/O
BSF STATUS,RP0 ;Bank 1
CLRF ANSEL ;digital I/O
movwf TRISA
; Disattivazione degli ingressi analogici
BANKSEL PORTC ;
CLRF PORTC ;Init PORTC
;MOVLW 07h ;Set RC<4,1:0> to
;MOVWF CMCON0 ;digital I/O
BANKSEL ANSEL ;
MOVLW 00h ;IMPOSTAZIONE DI PORTC COME OUTPUT
MOVWF TRISC ;
Ciao.
Paolo.
Paolino
6 messaggi
Torna a Firmware e programmazione
