- Codice: Seleziona tutto
root@server:~# lvs
Couldn't find device with uuid '4vxLQv-19ma-96ue-oCbC-rUhn-W1JM-cIVyeI'.
root@server:~# vgs
VG #PV #LV #SN Attr VSize VFree
home 6 0 0 wz-pn- 1,39t 1,39t
root@server:~#
Problema con montaggio di un gruppo di unita' LVM
Paolino,
fairyvilje
Ecco:
lvremove --noudevsync /dev/mapper/home-home
vgremove --noudevsync home
root@server:~# lvremove --noudevsync /dev/mapper/home-home
One or more specified logical volume(s) not found.
root@server:~# vgremove --noudevsync home
Cannot change VG home while PVs are missing!
root@server:~#
root@server:~# vgremove --noudevsync -f home
root@server:~#
Scusami ma facendo un "fdisk -l" mi dice che non rileva il disco da SATA da 500Gb :
root@server:~# fdisk -l
Disk /dev/sda: 82.0 GB, 81964302336 bytes
255 heads, 63 sectors/track, 9964 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x7461bf6e
Device Boot Start End Blocks Id System
/dev/sda1 * 1 9965 80040961 5 Extended
/dev/sda5 1 1531 12288000 83 Linux
/dev/sda6 1531 1624 747520 82 Linux swap / Solaris
/dev/sda7 6488 9965 27929600 8e Linux LVM
/dev/sda8 1624 6488 39067648 83 Linux
Partition table entries are not in disk order
Disk /dev/sdb: 82.0 GB, 81964302336 bytes
Disk identifier: 0x0002b9be
/dev/sdb1 1 9964 80035798+ 8e Linux LVM
Disk /dev/sdc: 300.1 GB, 300069052416 bytes
255 heads, 63 sectors/track, 36481 cylinders
Disk identifier: 0x00072e18
/dev/sdc1 1 36482 293033985 5 Extended
/dev/sdc5 1 36482 293033984 8e Linux LVM
Disk /dev/sdd: 320.1 GB, 320072933376 bytes
255 heads, 63 sectors/track, 38913 cylinders
Disk identifier: 0x0001412b
/dev/sdd1 1 38914 312568833 5 Extended
/dev/sdd5 1 38914 312568832 8e Linux LVM
Disk /dev/sde: 300.1 GB, 300069052416 bytes
Disk identifier: 0xc860c860
/dev/sde1 1 36482 293033985 5 Extended
/dev/sde5 1 36482 293033984 8e Linux LVM
root@server:~#
Ultima modifica di
alien75 il 26 ott 2011, 16:08, modificato 1 volta in totale.
root@server:~# pvdisplay
--- Physical volume ---
PV Name /dev/sdb1
VG Name home
PV Size 76,33 GiB / not usable 3,96 MiB
Allocatable yes
PE Size 4,00 MiB
Total PE 19539
Free PE 19539
Allocated PE 0
PV UUID 8AcJUW-zguN-6iM1-ml2y-Zc7K-3z1d-sdwZOv
PV Name /dev/sdc5
VG Name home
PV Size 279,46 GiB / not usable 2,00 MiB
Allocatable yes
PE Size 4,00 MiB
Total PE 71541
Free PE 71541
Allocated PE 0
PV UUID 2PFdTq-FjOT-NbX9-Tiak-07X6-7bdp-hdeBft
PV Name /dev/sdd5
VG Name home
PV Size 298,09 GiB / not usable 3,00 MiB
Allocatable yes
PE Size 4,00 MiB
Total PE 76310
Free PE 76310
Allocated PE 0
PV UUID HjgmgV-3gab-Fza3-26Di-ihoj-lsNj-05Pj20
PV Name /dev/sde5
VG Name home
Allocatable yes
PE Size 4,00 MiB
Total PE 71541
Free PE 71541
Allocated PE 0
PV UUID iI2BOU-vA6V-XUGh-I1ll-kqKj-ec3m-pfrDob
PV Name unknown device
VG Name home
PV Size 465,76 GiB / not usable 3,00 MiB
Allocatable yes
PE Size 4,00 MiB
Total PE 119234
Free PE 119234
Allocated PE 0
PV UUID 4vxLQv-19ma-96ue-oCbC-rUhn-W1JM-cIVyeI
PV Name /dev/sda7
VG Name home
PV Size 26,64 GiB / not usable 3,00 MiB
Allocatable yes
PE Size 4,00 MiB
Total PE 6818
Free PE 6818
Allocated PE 0
PV UUID 2rfP9e-64io-Pc3q-nIrW-SfuR-CXpQ-Q3JwSj
root@server:~#
L' altro ce l' hai gia.
alien75 ha scritto:Scusami ma facendo un "fdisk -l" mi dice che non rileva il disco da SATA da 500Gb :
root@server:~#
Infatti, mi pareva che ci fosse qualcosa di strano.
Che fine ha fatto quel disco
P.S: Se dimentichi di rispondere, poco male, ma se modifichi il messaggio, modifica quello giusto, mi sono accorto per caso della tua risposta
Che fine ha fatto quel disco![]()
Domanda da un milione di dollari: molto probabilmente non viene rilevata in fase di boot
(non e' la prima volta che non rileva un disco causa probabilmente del cavetto di alimentazione).
Controllo il cavetto poi riferisco.
Disk /dev/sdf: 500.1 GB, 500107862016 bytes
255 heads, 63 sectors/track, 60801 cylinders
Disk identifier: 0x000ccf43
/dev/sdf1 1 60802 488385536 8e Linux LVM
Ho risolto il problema ora il disco da 550Gb viene visto.
Avresti tempo ora?
'sto ubuntu mi fa
